    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 651.9k Views 135 Watching
    • GarethG
      Gareth
      Great book....love it....!!
      Well done.
      • genki.ttG
        genki.tt
        I found a small miss type on The D'oh! Book P61(ver.1.0) P63(ver.1.1)
        [20mm, 10mm, 30mm] absolute move -> <20mm, 10mm, 30mm> relative move
        By the way I could find Doh about Array Command, we can change operation 'x' to '/' with using 'x1' , or we can change '/' to 'x' with using '/1'.
        copy(move + 'alt') some object and type VCB
        <1000,,>
        x4
        10000
        x1
        /4
        20000
        /1
        <1000, 1000, 1000>
        x10
        .... we can continue 'x', '/', distance value, relative vertics, absolute vertics.
        'x1' or '/1' is important.
        Thank you for GREAT BOOK!!
          Doh of the day! Surely trivial but never remarked! ๐Ÿ’š
          Saving a file with objects who are not Components and Groups
          New File
          Import this file : it's converted in a Component! ๐Ÿ˜ฎ
            New File
            And if you create a component and save it using File>Save as... and then import it, it'll be double wrapped.
              And Making a Component creates a new context menu on the Right Click Menu!
              "Save As" (+ "Reload" + "Detach")
              So more speed than the menu "File Save as" ! ๐Ÿ˜‰
              • E
                Ecuadorian
                I've just spent one hour asking myself why I could not copy-paste from an old SKP file to a new SKP file with a newly imported AutoCAD drawing. I run SketchUp's checkup, GPU-Z, Repaired SketchUp, reinstalled SketchUp... Nothing. Until I remembered these guys send me the AutoCAD drawings in milimeters instead of meters, but I imported it as meters... So the new drawing was gigantic and anything I copy-pasted from the old file was just too tiny to be seen.
                -Miguel Lescano
                  Why not use the "Zoom Extended" in a new file ? ๐Ÿ˜ฎ ๐Ÿ˜„
                    rv1974
                    Today Penny has Dropped:
                    XnView is way better BP2 library explorer then a built-in one.
                    As well I use XnView as Component explorer for years now. Excellent with 2nd disply + drag'n'drop.
                      Sleipnir
                      New to this program, looking for a good extension for cabinet building and or wood working draw up.
                      Odin's Favorite Eight Legged Horse'
                        Super Doh of the day! Thanks Dave! ๐Ÿ‘
                        The arc Circle "Knife"! Make a Double Click at the end of the Arc Drawing! ๐Ÿค“
                        Excellent! ๐Ÿ˜Ž โ˜€
                        Never made the Double Click! (just simple click: as it was not writed on the bottom help line! ๐Ÿ˜ณ
                        And I surrely missed it on the manual! ๐Ÿ˜ณ
                        Animation by Dave
                        https://sketchucation.com/forums/download/file.php?id=148790&mode=view/rokbox.jpg
                          You probably missed this, too. If you want to place the same radius on other corners, double click near them.
                          Click on pic if it doesn't move.
                            Very cool! โ˜€ ๐Ÿ‘
                            I suppose I am not the only one! ๐Ÿ’š
                            • K
                              kaas
                              I don't know if this is a new feature but I was pleasantly surprised to learn about it:
                              In the 3dWarehouse, select a model, look at the statistics in the panel on the right, if you hover / click on a tag (materials/components) you can import just one of those elements instead of the whole model.
                              Great feature if you just need 1 material of 1 element from a collection.
                              • boofredlayB
                                boofredlay
                                https://media.giphy.com/media/EldfH1VJdbrwY/giphy.gif
                                • HornOxxH
                                  HornOxx
                                  @pilou said:
                                  ...I suppose I am not the only one! ๐Ÿ’š
                                  ๐Ÿ˜„ ๐Ÿ˜„ I'm also a member of this unsuspecting club...
                                  never trust a skinny cook
                                    rv1974
                                    At last we have a fastest\easiest tool for ramps/stairs/roads!
                                    Check s4u Stair() in Plugin Store.
                                    Absolutely worth every penny.
                                    โ˜€
                                    • L
                                      Thank you, thank you, thank you!
                                      • david_hD
                                        david_h
                                        I know I should know this (being a top sketchukator and all--- ๐Ÿ’š Yeah, I am having a hard time containing my laughter too. . .)but as I said. .I know I should know this but I don't:
                                        as I go between scenes with sections how can I toggle between them and keep the section plane window off so I dont have to manually turn them off each time? I have always found the scene menu in SU very confusing and conveluted and I can't seem to get this to work as I want. Help please? Thanks.
                                        David_H
                                          David, you can access them in the Outliner. Right click on the desired section cut in Outliner and activate it or deactivate as needed.
                                          • david_hD
                                            david_h
                                            Dave. . thanks for the response and please excuse the follow up. . . I guess I'm not following, or i didn't make my question clear and I don't use outliiner that much. . .is there a way to save the scene updates so that the windows just stay off? I don't see how Outline does that for me.
                                            Thx,
                                            D
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 33 / 35
