    [Plugin] Animator - v4.5a - 22 Jul 25
    renderpluginsextensions
    544 Posts 119 Posters 1.8m Views 119 Watching
    • soloS Offline
      @ntxdave said:
      I downloaded the trial version and it does no give me the option to install it for SketchUp 2018. Was going to give it a try for you...........
      Is there something I need to do differently to get a trial version to work with 2018?
      Maybe they do not have a version compatible with SU 2018 yet, or an installer, try SU 2017
        Sim lab can do it. Not as real as Thea but still pretty acceptable.
        Blender would do this also. But we know where that discussion goes!
        I didn’t try your file yet on my 2018 and Thea. Will do so later.
        • ntxdaveN Offline
          ntxdave
          When I downloaded the trial, it would not give me the option to install for 2018.
          With some of the latest stuff for SimLab composer, you can do what he is trying to do here with Animator. Especially with the VR version plus it has a lot of interactive capabilities.
          Animator also works well with Twilight Render Pro.
          • soloS Offline
            Okay, all fixed, it is indeed a Thea bug and I do have a fix thanks to Tomasz (the Thea plugin author)
            • fredo6F Offline
              What was the fix ?
              • soloS Offline
                @fredo6 said:
                What was the fix ?
                I was given a new .rbs file, it's a temporary fix, Tomasz will get that sorted soon, he is very busy with Thea v 2.0 at moment.
                • ntxdaveN Offline
                  ntxdave
                  Good to hear the situation is being addressed. I had reached out for a trial for 2018 so I could try you model and see what happened on my machine. They did send me a link but I will back off and let you guys get it resolved. 😄
                  • fredo6F Offline
                    Solo,
                    Thanks. I don't know what the fix can be, as it worked fine on my side.
                    I had to tweak the sunlight setting to remove the black background (not perfect as shadows are projected in the empty space), but I do get a normal movement for the different parts.
                    Film 1.mov
                      Mike598601
                      @fredo6 said:
                      Is Vray 3.6 installed in SU2018?
                      I will investigate on my side
                      Hi Fredo,
                      Did you check on this? I have just done a completely fresh install of everything onto a new PC, so SU 2018 Pro, Animator 1.8b, LibFredo6 8.0b and V-Ray 3.6 and it still doesn't appear as an option to Render.
                      Kind regards
                      Mike
                      • fredo6F Offline
                        I installed VRay 3.6 and found the same results as you.
                        Actually, the API has changed and at least one method has disappeared.
                        I contacted Chaos Group to inquire about this.
                        In the meantime, I am afraid that Animator won't support VRay 3.6, as I cannot do anything on my side (note that the VRay API is not documented, and thus the integration in Sketchup was more in a beta stage).
                        Sorry for that. I hope it won't take too long.
                        • fredo6F Offline
                          I just published LibFredo6 8.0c, which includes a fix for compatibility with VRay 3.6.
                          However, I noticed that VRay 3.6 may freeze after rendering a number of frames. Please report if you have this case.
                            liam887
                            Wow cant wait to take this for a spin!
                            VISIT MY ONLINE GALLERY
                              Mike598601
                              Possible issue with v1.8g - tried to change layer visibility and animator just crashed on saving. Couldn't get out of animator back to sketchup.
                              • fredo6F Offline
                                Do you mean bugsplat?
                                • fredo6F Offline
                                  New Release: Animator - v1.8h - 15 Mar 18
                                  Requirement: LibFredo6 v8.1e
                                  Minor release
                                  • bug fixing of a problem in v1.8g related to cameras and visual effects
                                  • Extension of validity
                                  See main post for RBZ files
                                  • N Offline
                                    nuddles
                                    when I render an animation by vray,it always stop at 2′17″or 2′18″,and continue rendering next frame,however,the last image was not rendered completely. I used Sketchup 2017 pro and VFS 3.40.04
                                    • fredo6F Offline
                                      New Release: Animator - v2.0a - 07 May 18
                                      Requirement: LibFredo6 v8.3a
                                      Major release
                                      1. Revamping of the user interface, with a dark theme, based on constructive, artistic advice from derei.
                                      1. Major functional evolutions in the Timeline
                                      • Contextual menu, with many options available about the navigation in the timeline and the manipulation of selected elements
                                      • Move and resize of several elements by dragging. You can also specify a shift for moving the start time and end time of elements, as well as align elements. When moving or resizing elements, there now inferences in the timeline to better align elements
                                      • Insertion (as well as removal) of empty space in the timeline (via contextual menu), and also at the beginning and at the end (via white arrows).
                                      • Advanced Selection panel, filtering by category and position versus the current time
                                      • Change of the time scale by Alt+mousewheel. You can reset to automatic time scaling by Alt + Click in the time track.
                                      • Name of elements displayed in the rectangles in the timeline (optional). There is an option in the Default Parameters to display names when the timeline is Horizontal or Vertical or both, or not to display name.
                                      1. New Positioner dialog box(with single icon in toolbar) allowing to load, save, delete, rename and replace positioners
                                      1. Constant acceleration, based on 2 speeds, one for start one for end, for movements: Translation, Screw, Rotate, Spin and AlongPath
                                      1. SaveNext button in the Movement Editor, allowing to save the current sequence and then go directly to the edition of a new one with the same selected object
                                      1. The visitor mode has been disabled, as it does not work.
                                      See plugin home page of Animator for Download of RBZ from the PluginStore.
                                      See Main Post of the Animator thread for more information.
                                      • SchuppeS Offline
                                        Schuppe
                                        Hi Fredo
                                        WOW, more than i dreamed of !!! I will go into this the next days.
                                        Thanks a lot for your work, great!!! merci beaucoup, tu es le meilleur !!
                                        I know its silly but it feels like christmas, lol
                                        Schuppe
                                          Ahmed0007
                                          • OxerO Offline
                                            Oxer
                                            Hi Fredo, I created the Spanish language file for Animator v2.0a, here the file:
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 27
                                            • 28
                                            • 13 / 28
