    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    597 Posts 120 Posters 2.2m Views 120 Watching
    • ntxdaveN
      ntxdave
      Still working on it Pete. Creating an MP4 with Thea did not work correctly and I had a problem trying to create a GIF. In the process again.........
      Press F1...thank me later
      • ntxdaveN
        ntxdave
        I did not do a good job but at least you can see that both of these render engines will work correctly with Animator (if you know how to user the renderers).
        Thea
        Twilight
        • soloS
          Interesting, I had someone on the Thea forums test it out and they also got an abnormal result, now I'm more confused.
          • ntxdaveN
            ntxdave
            Maybe it has something to do with versions:
            • Your skp file: SU Version 8.0.1
            • I used SU: Version 2017 Pro
            • I used Thea: Version TheaForSketchUpBundle_v1.5.07.480.1447
            • I used Animator: Version 1.8a
            • I used Fredo LibFredo6: Version 8.0a
            Do not know if that will shed any light on things but maybe I have something in versions might make a difference. If there is anything else I can do to help (other than a nice clean render), just let me know.
            • soloS
              I have the most recent version as well as new LibFredo v8
              I am using SU 2018 pro and Windows 10, I just saved model as V8 for those that do not have new SU versions.
              • ntxdaveN
                ntxdave
                I am installing a new version of SimLab Composer right now. When it is done, I will update Animator to the latest version and try in 2018 to see if I see any differences.
                • soloS
                  I give up, not working for me, this was just a basic test, the whole model has tens of animated sequences including furniture and multiple camera views, it should have been simple as it works so well with SU animation, for some reason Thea has failed me. Can Simlab do this kind of animation? how good is the render quality?
                  • ntxdaveN
                    ntxdave
                    I downloaded the trial version and it does no give me the option to install it for SketchUp 2018. Was going to give it a try for you...........
                    Is there something I need to do differently to get a trial version to work with 2018?
                    • soloS
                      Maybe they do not have a version compatible with SU 2018 yet, or an installer, try SU 2017
                        Sim lab can do it. Not as real as Thea but still pretty acceptable.
                        Blender would do this also. But we know where that discussion goes!
                        I didn’t try your file yet on my 2018 and Thea. Will do so later.
                        • ntxdaveN
                          ntxdave
                          When I downloaded the trial, it would not give me the option to install for 2018.
                          With some of the latest stuff for SimLab composer, you can do what he is trying to do here with Animator. Especially with the VR version plus it has a lot of interactive capabilities.
                          Animator also works well with Twilight Render Pro.
                          • soloS
                            Okay, all fixed, it is indeed a Thea bug and I do have a fix thanks to Tomasz (the Thea plugin author)
                            • fredo6F
                              What was the fix ?
                              • soloS
                                @fredo6 said:
                                What was the fix ?
                                I was given a new .rbs file, it's a temporary fix, Tomasz will get that sorted soon, he is very busy with Thea v 2.0 at moment.
                                • ntxdaveN
                                  ntxdave
                                  Good to hear the situation is being addressed. I had reached out for a trial for 2018 so I could try you model and see what happened on my machine. They did send me a link but I will back off and let you guys get it resolved. 😄
                                  • fredo6F
                                    Solo,
                                    Thanks. I don't know what the fix can be, as it worked fine on my side.
                                    I had to tweak the sunlight setting to remove the black background (not perfect as shadows are projected in the empty space), but I do get a normal movement for the different parts.
                                    Film 1.mov
                                      Mike598601
                                      @fredo6 said:
                                      Is Vray 3.6 installed in SU2018?
                                      I will investigate on my side
                                      Hi Fredo,
                                      Did you check on this? I have just done a completely fresh install of everything onto a new PC, so SU 2018 Pro, Animator 1.8b, LibFredo6 8.0b and V-Ray 3.6 and it still doesn't appear as an option to Render.
                                      Kind regards
                                      Mike
                                      • fredo6F
                                        I installed VRay 3.6 and found the same results as you.
                                        Actually, the API has changed and at least one method has disappeared.
                                        I contacted Chaos Group to inquire about this.
                                        In the meantime, I am afraid that Animator won't support VRay 3.6, as I cannot do anything on my side (note that the VRay API is not documented, and thus the integration in Sketchup was more in a beta stage).
                                        Sorry for that. I hope it won't take too long.
                                        • fredo6F
                                          I just published LibFredo6 8.0c, which includes a fix for compatibility with VRay 3.6.
                                          However, I noticed that VRay 3.6 may freeze after rendering a number of frames. Please report if you have this case.
                                          • L
                                            liam887
                                            Wow cant wait to take this for a spin!
                                            VISIT MY ONLINE GALLERY
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 29
                                            • 30
                                            • 12 / 30
