    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    597 Posts 120 Posters 2.2m Views 120 Watching
    • soloS
      Okay, all fixed, it is indeed a Thea bug and I do have a fix thanks to Tomasz (the Thea plugin author)
      • fredo6F
        What was the fix ?
        • soloS
          @fredo6 said:
          What was the fix ?
          I was given a new .rbs file, it's a temporary fix, Tomasz will get that sorted soon, he is very busy with Thea v 2.0 at moment.
          • ntxdaveN
            ntxdave
            Good to hear the situation is being addressed. I had reached out for a trial for 2018 so I could try you model and see what happened on my machine. They did send me a link but I will back off and let you guys get it resolved. 😄
            Press F1...thank me later
            • fredo6F
              Solo,
              Thanks. I don't know what the fix can be, as it worked fine on my side.
              I had to tweak the sunlight setting to remove the black background (not perfect as shadows are projected in the empty space), but I do get a normal movement for the different parts.
              Film 1.mov
                Mike598601
                @fredo6 said:
                Is Vray 3.6 installed in SU2018?
                I will investigate on my side
                Hi Fredo,
                Did you check on this? I have just done a completely fresh install of everything onto a new PC, so SU 2018 Pro, Animator 1.8b, LibFredo6 8.0b and V-Ray 3.6 and it still doesn't appear as an option to Render.
                Kind regards
                Mike
                • fredo6F
                  I installed VRay 3.6 and found the same results as you.
                  Actually, the API has changed and at least one method has disappeared.
                  I contacted Chaos Group to inquire about this.
                  In the meantime, I am afraid that Animator won't support VRay 3.6, as I cannot do anything on my side (note that the VRay API is not documented, and thus the integration in Sketchup was more in a beta stage).
                  Sorry for that. I hope it won't take too long.
                  • fredo6F
                    I just published LibFredo6 8.0c, which includes a fix for compatibility with VRay 3.6.
                    However, I noticed that VRay 3.6 may freeze after rendering a number of frames. Please report if you have this case.
                    • L
                      liam887
                      Wow cant wait to take this for a spin!
                      VISIT MY ONLINE GALLERY
                        Mike598601
                        Possible issue with v1.8g - tried to change layer visibility and animator just crashed on saving. Couldn't get out of animator back to sketchup.
                        • fredo6F
                          Do you mean bugsplat?
                          • fredo6F
                            New Release: Animator - v1.8h - 15 Mar 18
                            Requirement: LibFredo6 v8.1e
                            Minor release
                            • bug fixing of a problem in v1.8g related to cameras and visual effects
                            • Extension of validity
                            See main post for RBZ files
                            • N
                              nuddles
                              when I render an animation by vray,it always stop at 2′17″or 2′18″,and continue rendering next frame,however,the last image was not rendered completely. I used Sketchup 2017 pro and VFS 3.40.04
                              • fredo6F
                                New Release: Animator - v2.0a - 07 May 18
                                Requirement: LibFredo6 v8.3a
                                Major release
                                1. Revamping of the user interface, with a dark theme, based on constructive, artistic advice from derei.
                                1. Major functional evolutions in the Timeline
                                • Contextual menu, with many options available about the navigation in the timeline and the manipulation of selected elements
                                • Move and resize of several elements by dragging. You can also specify a shift for moving the start time and end time of elements, as well as align elements. When moving or resizing elements, there now inferences in the timeline to better align elements
                                • Insertion (as well as removal) of empty space in the timeline (via contextual menu), and also at the beginning and at the end (via white arrows).
                                • Advanced Selection panel, filtering by category and position versus the current time
                                • Change of the time scale by Alt+mousewheel. You can reset to automatic time scaling by Alt + Click in the time track.
                                • Name of elements displayed in the rectangles in the timeline (optional). There is an option in the Default Parameters to display names when the timeline is Horizontal or Vertical or both, or not to display name.
                                1. New Positioner dialog box(with single icon in toolbar) allowing to load, save, delete, rename and replace positioners
                                1. Constant acceleration, based on 2 speeds, one for start one for end, for movements: Translation, Screw, Rotate, Spin and AlongPath
                                1. SaveNext button in the Movement Editor, allowing to save the current sequence and then go directly to the edition of a new one with the same selected object
                                1. The visitor mode has been disabled, as it does not work.
                                See plugin home page of Animator for Download of RBZ from the PluginStore.
                                See Main Post of the Animator thread for more information.
                                • SchuppeS
                                  Schuppe
                                  Hi Fredo
                                  WOW, more than i dreamed of !!! I will go into this the next days.
                                  Thanks a lot for your work, great!!! merci beaucoup, tu es le meilleur !!
                                  I know its silly but it feels like christmas, lol
                                  Schuppe
                                    Ahmed0007
                                    • OxerO
                                      Oxer
                                      Hi Fredo, I created the Spanish language file for Animator v2.0a, here the file:
                                      • jgbJ
                                        jgb
                                        Is there any chance you could come up with a 32bit Animator version? I have SU 2015 32 bit and I cannot upgrade my system to 64 bit O/S (Win 10). The h/w IS 64bit, my Win 10 was mistakenly upgraded to 32bit.
                                        Even if a few features are disabled, it would be better than nothing.
                                        jgb
                                        • N
                                          nisel
                                          In the new version, i see some inverse kinematic buttons. Fredo could you add some inverse kinematic tutorials. For example a robotic arm?
                                          • fredo6F
                                            @jgb said:
                                            Unfortunately, I now release Animator for SU2016 and above, because of the support of hi-res screens and also because Animator should become a paid plugin when it has the required amount of features.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 29
                                            • 30
                                            • 12 / 30
