    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    595 Posts 119 Posters 2.2m Views 119 Watching
    • ntxdaveN Offline
      ntxdave
      I did not do a good job but at least you can see that both of these render engines will work correctly with Animator (if you know how to user the renderers).
      Thea
      Twilight
      Press F1...thank me later
      • soloS Offline
        Interesting, I had someone on the Thea forums test it out and they also got an abnormal result, now I'm more confused.
        • ntxdaveN Offline
          ntxdave
          Maybe it has something to do with versions:
          • Your skp file: SU Version 8.0.1
          • I used SU: Version 2017 Pro
          • I used Thea: Version TheaForSketchUpBundle_v1.5.07.480.1447
          • I used Animator: Version 1.8a
          • I used Fredo LibFredo6: Version 8.0a
          Do not know if that will shed any light on things but maybe I have something in versions might make a difference. If there is anything else I can do to help (other than a nice clean render), just let me know.
          • soloS Offline
            I have the most recent version as well as new LibFredo v8
            I am using SU 2018 pro and Windows 10, I just saved model as V8 for those that do not have new SU versions.
            • ntxdaveN Offline
              ntxdave
              I am installing a new version of SimLab Composer right now. When it is done, I will update Animator to the latest version and try in 2018 to see if I see any differences.
              • soloS Offline
                I give up, not working for me, this was just a basic test, the whole model has tens of animated sequences including furniture and multiple camera views, it should have been simple as it works so well with SU animation, for some reason Thea has failed me. Can Simlab do this kind of animation? how good is the render quality?
                • ntxdaveN Offline
                  ntxdave
                  I downloaded the trial version and it does no give me the option to install it for SketchUp 2018. Was going to give it a try for you...........
                  Is there something I need to do differently to get a trial version to work with 2018?
                  • soloS Offline
                    Maybe they do not have a version compatible with SU 2018 yet, or an installer, try SU 2017
                      Sim lab can do it. Not as real as Thea but still pretty acceptable.
                      Blender would do this also. But we know where that discussion goes!
                      I didn’t try your file yet on my 2018 and Thea. Will do so later.
                      • ntxdaveN Offline
                        ntxdave
                        When I downloaded the trial, it would not give me the option to install for 2018.
                        With some of the latest stuff for SimLab composer, you can do what he is trying to do here with Animator. Especially with the VR version plus it has a lot of interactive capabilities.
                        Animator also works well with Twilight Render Pro.
                        • soloS Offline
                          Okay, all fixed, it is indeed a Thea bug and I do have a fix thanks to Tomasz (the Thea plugin author)
                          • fredo6F Offline
                            What was the fix ?
                            • soloS Offline
                              @fredo6 said:
                              What was the fix ?
                              I was given a new .rbs file, it's a temporary fix, Tomasz will get that sorted soon, he is very busy with Thea v 2.0 at moment.
                              • ntxdaveN Offline
                                ntxdave
                                Good to hear the situation is being addressed. I had reached out for a trial for 2018 so I could try you model and see what happened on my machine. They did send me a link but I will back off and let you guys get it resolved. 😄
                                • fredo6F Offline
                                  Solo,
                                  Thanks. I don't know what the fix can be, as it worked fine on my side.
                                  I had to tweak the sunlight setting to remove the black background (not perfect as shadows are projected in the empty space), but I do get a normal movement for the different parts.
                                  Film 1.mov
                                    Mike598601
                                    @fredo6 said:
                                    Is Vray 3.6 installed in SU2018?
                                    I will investigate on my side
                                    Hi Fredo,
                                    Did you check on this? I have just done a completely fresh install of everything onto a new PC, so SU 2018 Pro, Animator 1.8b, LibFredo6 8.0b and V-Ray 3.6 and it still doesn't appear as an option to Render.
                                    Kind regards
                                    Mike
                                    • fredo6F Offline
                                      I installed VRay 3.6 and found the same results as you.
                                      Actually, the API has changed and at least one method has disappeared.
                                      I contacted Chaos Group to inquire about this.
                                      In the meantime, I am afraid that Animator won't support VRay 3.6, as I cannot do anything on my side (note that the VRay API is not documented, and thus the integration in Sketchup was more in a beta stage).
                                      Sorry for that. I hope it won't take too long.
                                      • fredo6F Offline
                                        I just published LibFredo6 8.0c, which includes a fix for compatibility with VRay 3.6.
                                        However, I noticed that VRay 3.6 may freeze after rendering a number of frames. Please report if you have this case.
                                          liam887
                                          Wow cant wait to take this for a spin!
                                          VISIT MY ONLINE GALLERY
                                            Mike598601
                                            Possible issue with v1.8g - tried to change layer visibility and animator just crashed on saving. Couldn't get out of animator back to sketchup.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 29
                                            • 30
                                            • 12 / 30
