    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    597 Posts 120 Posters 2.2m Views 120 Watching
    • B
      Ben Ritter
      Searched all over but couldn't find an RBZ file for download.
        Install it via SketchUcation Tools...
        Sketchucation Tools | SketchUcation
        (sketchucation.com)
        Or install it via RBZ...
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
        • B
          Ben Ritter
          Thanks Rich
          • C
            Charlie__V
            fredo,
            Thank you, ....great plug-in!
            Q: how to maintain object parallel to path when "helical"?
            In first .gif I have SU path on single/flat plane, and all behaves as expected.
            (I introduced 3 rotations: rear wheel lift just before take off and ยฑ 60ยฐ rotations through curve(s)
            In second .gif I have "elevated" the path to a "helical" type shape and the plane maintains +X axis "heading throughout path.
            Is there a setting to force the plane to follow the path parallel?
            (Ideally, replicate the action in first .gif in the "helical" type path of the second .gif)
            Thanks again,
            Charlie
            Flat flight path
            !["helical" flight path](/uploads/imported_attachments/6Quw_Film1.gif ""helical" flight path")
              Why not add the elevation as movement?
              • C
                Charlie__V
                [attachment=1:ejbr5t2m]<!-- ia1 -->2017-05-27_15-59-08.gif<!-- ia1 -->[/attachment:ejbr5t2m]
                Rich,
                Umm....because I guess I was too thick headed to even think of that. ๐Ÿ˜„
                (now wishing I asked hours ago) ๐Ÿ˜ณ
                Thanks, that works great!
                Charlie
                !["Translation" elevation movement](/uploads/imported_attachments/ZViR_Film1.gif ""Translation" elevation movement")
                  No problem. That's a great little animation!
                  Mind if I share it on twitter?
                  • C
                    Charlie__V
                    (Thanks)Sure, ok to tweet it, though now that I am past my hurdle (thanks again)I was going to add a package dropped via parachute. (scaling)........but don't wait for that.........another learning curve ahead for me. ๐Ÿ˜Ž
                    Charlie
                    • MALAISEM
                      MALAISE
                      New improvements, it opens a whole world. Great Fredo.
                      Pierre
                      La Connaissance n'a de valeur que partagรฉe
                      • C
                        Charlie__V
                        Fredo,
                        You should put a warning label on this plug-in.........its addictive. ๐Ÿ˜„
                        Last one for today...........cargo drop via parachute.
                        Cargo drop
                        • fredo6F
                          Charlie,
                          Great job. I guess you used the Easing for simulating the take off. And nice utilization of the scaling for the parachute.
                          One small thing: you could center the plane on the runway by moving the point of contact to be in the middle of the two wheels.
                          Now you just have to build the landscape and include some views from the cockpit!
                          • C
                            Charlie__V
                            @fredo6 said:
                            Charlie,
                            Thanks Fredo, I am truly honored!& yes I used easing. (see settings attachment)
                            But this is some form of magic that you do, so all credit to you!
                            Hard to tell but path was in the center....I may have inadvertently moved it though.
                            I know.....but have to stop for today.
                            Easing....polynom
                            • chriC
                              chri
                              Magnificent job CHARLIE ๐Ÿ‘
                              Thanks for sharing
                              Thanks to Fredo
                              • ntxdaveN
                                ntxdave
                                Fredo,
                                Pretty neat Charlie!!
                                Press F1...thank me later
                                • C
                                  Charlie__V
                                  Thanks all, it was/is fun. ๐Ÿ˜„
                                    db11
                                    When I click on airplane gif I get this each time:
                                    I've had a similar problem on one other site (The Verge - which fails to even load the home page), so it's likely browser related. Both these have happened since the latest Safari update, so not sure if it broke something.
                                    Anyone know what the issue might be? I'm running Safari on elCapitan (both with latest updates)
                                      If you open this in a browser tab what happens?
                                      403 Forbidden
                                      (sketchucation.com)
                                        db11
                                        Same error. It takes ~ 30 seconds for the tab to load, then it throws the error.
                                        I thought it might be my browser extensions, but the problem persists even with extensions off.
                                        • C
                                          Charlie__V
                                          I revised the length of the .gif as I experienced something similar on my Ipad.
                                          So this is a test to see if it is due to a time issue. (see attached)
                                          I will take down problem file if this resolves it.
                                          Charlie
                                          EDIT:
                                          This version works fine on my IPad.
                                          *Admin. Please let me know if you want problem file taken down or? (In case you want it to source problem)
                                          Flight path/cargo drop Rev1
                                          • F
                                            faust07
                                            COOOL!
                                            • 29
                                            • 30
                                            • 8 / 30
