    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
      https://media.giphy.com/media/3o7btSCbEOMK8eW8q4/giphy.gif
      Vrrroooommmm!!!!
      • ntxdaveN
        ntxdave
        Fredo, this is pretty exciting. I will be giving this a try as soon as possible (might take a few days). πŸ‘ πŸ‘ πŸ‘
        Press F1...thank me later
        • T
          Treadshot A1
          Animator 1.6a is awesome! Most happy about Animator actually saving animation and model data on click now (previously, saving was... not reliable for animation data). Only had time to try out the follow path feature, by driving a tank of course.
          Great job Fredo as always, thanks!
          • fredo6F
            I guess you use an old version of Sketchup (< 2014). I discovered that there was a bug in the model.save method (doing nothing basically). So I fix that too in 1.6.
            Nice model and video animation!
            • B
              Ben Ritter
              Searched all over but couldn't find an RBZ file for download.
                Install it via SketchUcation Tools...
                Sketchucation Tools | SketchUcation
                (sketchucation.com)
                Or install it via RBZ...
                SketchUp Plugins | PluginStore | SketchUcation
                SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                (sketchucation.com)
                • B
                  Ben Ritter
                  Thanks Rich
                  • C
                    Charlie__V
                    fredo,
                    Thank you, ....great plug-in!
                    Q: how to maintain object parallel to path when "helical"?
                    In first .gif I have SU path on single/flat plane, and all behaves as expected.
                    (I introduced 3 rotations: rear wheel lift just before take off and Β± 60Β° rotations through curve(s)
                    In second .gif I have "elevated" the path to a "helical" type shape and the plane maintains +X axis "heading throughout path.
                    Is there a setting to force the plane to follow the path parallel?
                    (Ideally, replicate the action in first .gif in the "helical" type path of the second .gif)
                    Thanks again,
                    Charlie
                    Flat flight path
                    !["helical" flight path](/uploads/imported_attachments/6Quw_Film1.gif ""helical" flight path")
                      Why not add the elevation as movement?
                      • C
                        Charlie__V
                        [attachment=1:ejbr5t2m]<!-- ia1 -->2017-05-27_15-59-08.gif<!-- ia1 -->[/attachment:ejbr5t2m]
                        Rich,
                        Umm....because I guess I was too thick headed to even think of that. πŸ˜„
                        (now wishing I asked hours ago) 😳
                        Thanks, that works great!
                        Charlie
                        !["Translation" elevation movement](/uploads/imported_attachments/ZViR_Film1.gif ""Translation" elevation movement")
                          No problem. That's a great little animation!
                          Mind if I share it on twitter?
                          • C
                            Charlie__V
                            (Thanks)Sure, ok to tweet it, though now that I am past my hurdle (thanks again)I was going to add a package dropped via parachute. (scaling)........but don't wait for that.........another learning curve ahead for me. 😎
                            Charlie
                            • MALAISEM
                              MALAISE
                              New improvements, it opens a whole world. Great Fredo.
                              Pierre
                              La Connaissance n'a de valeur que partagΓ©e
                              • C
                                Charlie__V
                                Fredo,
                                You should put a warning label on this plug-in.........its addictive. πŸ˜„
                                Last one for today...........cargo drop via parachute.
                                Cargo drop
                                • fredo6F
                                  Charlie,
                                  Great job. I guess you used the Easing for simulating the take off. And nice utilization of the scaling for the parachute.
                                  One small thing: you could center the plane on the runway by moving the point of contact to be in the middle of the two wheels.
                                  Now you just have to build the landscape and include some views from the cockpit!
                                  • C
                                    Charlie__V
                                    @fredo6 said:
                                    Charlie,
                                    Thanks Fredo, I am truly honored!& yes I used easing. (see settings attachment)
                                    But this is some form of magic that you do, so all credit to you!
                                    Hard to tell but path was in the center....I may have inadvertently moved it though.
                                    I know.....but have to stop for today.
                                    Easing....polynom
                                    • chriC
                                      chri
                                      Magnificent job CHARLIE πŸ‘
                                      Thanks for sharing
                                      Thanks to Fredo
                                      • ntxdaveN
                                        ntxdave
                                        Fredo,
                                        Pretty neat Charlie!!
                                        • C
                                          Charlie__V
                                          Thanks all, it was/is fun. πŸ˜„
                                            db11
                                            When I click on airplane gif I get this each time:
                                            I've had a similar problem on one other site (The Verge - which fails to even load the home page), so it's likely browser related. Both these have happened since the latest Safari update, so not sure if it broke something.
                                            Anyone know what the issue might be? I'm running Safari on elCapitan (both with latest updates)
                                            • 29
                                            • 30
                                            • 8 / 30
