    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    595 Posts 119 Posters 2.2m Views 119 Watching
    • fredo6F Offline
      @adrihal said:
      The quality of the video with the screen size is poor. It can not be used for further work. Why the renderer in Sketchup allows you to set the picture size to 2500 or more.
      The animator can greatly improve the presentation of the model. But for this we need a large picture resolution without additional programs.
      I arranged to increase the limit for video resolution above the screen resolution. I did not test what are the limits in FFMPEG, but in Sketchup it is in theory 16000x16000.
      I have attached a short one in 6000x2000 (as a MOV file, since we cannot attach a MP4 in this forum)
      Film 4 - final path.mov
        adrihal
        Thank you! Do I need to update the plugin,
         So that all the changes were in my program?
          adrihal
          After updating the plug-in - the result did not change ...
          Maybe I'm doing something wrong?
          Video_2017-04-16_220841.rar
          • fredo6F Offline
            Well...I need to publish it first. Should come in the next release in a few days hopefully.
            • V Offline
              valerostudio
              Just playing with this for the first time, testing with Thea. Amazing! Fredo, you've made SketchUp the modeling application that we've always wanted it to be. Huge thanks.
              • fredo6F Offline
                New Release: Animator - v1.5d - 13 May 17
                Requirement: LibFredo6 v7.5a
                This is the same as previous version (v1.5c) with extension of validity beyond 14 May 17.
                I am working on a major new release, with Scaling and Along path movements, but it takes more time than expected.
                See main post for RBZ files
                  bedavisdesign
                  Hi Fredo,
                  I absolutely love your Animator plugin. I was actually in the middle of editing some animations when I received the notice that "this version is out of date, please update" (paraphrasing). I went to the sketchucation plugin and downloaded animator v1.5d successfully. I am currently running LibFredo6 v7.5b. However it still is giving me the popup that says this version of animator is out of date. I am running sketchup version 15.3.331 64-bit. Thoughts?
                  UPDATE: I quit and restarted sketchup and the animator plugin seems to be working. Apologies.
                  Best,
                  BD
                  • fredo6F Offline
                    Yes, you need to restart Sketchup after you install Animator (or most plugins) so that the new code is actually loaded.
                      sarkarshomit
                      Waiting and i know it will be the best as always.....thanks for the plugin Fredo......u have been great.
                      Scaling is something i have been waiting from long time......this expected update will be a great update...
                        Fabulous! Fast & furious! 😎
                        • fredo6F Offline
                          New Release: Animator - v1.6a - 25 May 17
                          Requirement: LibFredo6 v7.6a
                          Major release
                          • bug fixing and cosmetic changes
                          • introduction of Scaling Movement
                          • Introduction of MovementAlong Path
                          • Wireframe mode in Movement Editor
                          • Speed Control mode (i.e. impose the speed) for Translation, Screw, Rotation, Spin and Along Path
                          • Cloning of sequences (copy a sequence, and then change the object selection)
                          • video resolution can be larger that the screen
                          • Improvement in the management of Thea rendering (more efficient when you have timeouts) (see video)
                            https://media.giphy.com/media/3o7btSCbEOMK8eW8q4/giphy.gif
                            Vrrroooommmm!!!!
                            • ntxdaveN Offline
                              ntxdave
                              Fredo, this is pretty exciting. I will be giving this a try as soon as possible (might take a few days). 👍 👍 👍
                              Press F1...thank me later
                                Treadshot A1
                                Animator 1.6a is awesome! Most happy about Animator actually saving animation and model data on click now (previously, saving was... not reliable for animation data). Only had time to try out the follow path feature, by driving a tank of course.
                                Great job Fredo as always, thanks!
                                • fredo6F Offline
                                  I guess you use an old version of Sketchup (< 2014). I discovered that there was a bug in the model.save method (doing nothing basically). So I fix that too in 1.6.
                                  Nice model and video animation!
                                    Ben Ritter
                                    Searched all over but couldn't find an RBZ file for download.
                                      Install it via SketchUcation Tools...
                                      Sketchucation Tools | SketchUcation
                                      (sketchucation.com)
                                      Or install it via RBZ...
                                      SketchUp Plugins | PluginStore | SketchUcation
                                      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                      (sketchucation.com)
                                        Ben Ritter
                                        Thanks Rich
                                          Charlie__V
                                          fredo,
                                          Thank you, ....great plug-in!
                                          Q: how to maintain object parallel to path when "helical"?
                                          In first .gif I have SU path on single/flat plane, and all behaves as expected.
                                          (I introduced 3 rotations: rear wheel lift just before take off and ± 60° rotations through curve(s)
                                          In second .gif I have "elevated" the path to a "helical" type shape and the plane maintains +X axis "heading throughout path.
                                          Is there a setting to force the plane to follow the path parallel?
                                          (Ideally, replicate the action in first .gif in the "helical" type path of the second .gif)
                                          Thanks again,
                                          Charlie
                                          Flat flight path
                                          !["helical" flight path](/uploads/imported_attachments/6Quw_Film1.gif ""helical" flight path")
                                            Why not add the elevation as movement?
                                            • 29
                                            • 30
                                            • 8 / 30
