    1.3k Posts 299 Posters 2.5m Views 297 Watching
      surfmike
      JGB,
      Thanks for helping out, I fully understand your instructions. πŸ˜„
      However, when I color the line by axis it shows beziers with parallell red end lines (7,2mm on above, 0,045mm in the below line) in each half.
      Maybe 0,045mm is too short to be recognized correctly, but in the final skinning group there's parallell lines alright even though 0,045mm became 1,06mm (see attached pic).
      But the issue is that inbetween those perfectly parallell lines the skin gets a "V" shape... (???)
      //Mikael
      P.S The unconnected edges was a unpleasant result of copy/paste 300s beziers from SU2016 to 2015. D.S
      • gillesG Offline
        gilles
        @surfmike said:
        JGB,
        //Mikael
        [attachment=0:vpj5k8ov]<!-- ia0 -->red_line.png<!-- ia0 -->[/attachment:vpj5k8ov]
        You don't need to copy/paste from SU2016 to 2015, just Save as and choose the SU version.
        Also when you work at this scale make a component, copy/paste this component, scale the copy X100 or X1000 and work with the copy, 0,045mm is far from the tolerance of SU to create faces.
        • jgbJ Offline
          jgb
          Yes, that is a problem. I noticed it but forgot to say so in my reply. SU really does not like very short lines.
          To get around this scale up the whole object 10 times and do the required functions on that, then scale back to 10% to return to original scale.
          SU can display short lines, but has some difficulty working with them.
          As Gilles said, save the SU-16 version as SU-15 and re-post it so I can look at it again.
          jgb
            surfmike
            Here's a "Save as..." version for SU2015.
            Thx!
            Front 1.5 fix SUC (SU2015) v1.1.skp
            • jgbJ Offline
              jgb
              OK, Got it.
              I've been playing with it for well over an hour. I needed to implement a few tricks I've learned with Curviloft over the years when it just won't skin what I see as a clean perimeter. I managed to skin all the curves and yes, I do see the "V" ridge and it is why I said above. I did a partial re-skinning of the main join of the 2 components, and that does eliminate the "V", but it is a laborious job and I simply do not have the time to finish it, so here is what I did......
              1 - I separated the 2 halves so they do not interfere visually as I did the fix. Move just one comp on the red axis, so later it is easy to rejoin them.
              2 - I tried skinning the main complex curve, but the perimeter was not true. So trick #1 is to explode the curves and delete the edges at the corners, but leaving 1 edge as a rejoin reference endpoint. I then rejoined the end points for an intact curve that Curviloft will accept. 4 corners - 8 lines deleted and redrawn.
              3 - Curviloft skinned the side and top easily, but hung twice on the front curve.
              4 - Trick #2 - when Curviloft craps out on a "perfect" perimeter, it is most often due to a very complex curve (and this IS a very complex curve) or where the curve is also part of an adjacent curve, I move/copy the perimeter away from the total object. I make sure the corners are clean, 2 lines only connected at endpoints. Curviloft skinned this. It took almost 10 minutes; I thought it hung again. When I brought the skins back together, sure enough, the "V" was there.
              5 - I then softened and smoothed the join line and the "V" was less noticeable, but that was a visual fix only. A 3D printed part would have a ridge.
              6 - I deleted the 2 faces and lines at the join from bottom to only about 1/2 way up as this was taking a long time to do. I had to do it with perspective off because the lines were so close to each other.
              7 - I then drew a line ON RED AXIS from each horizontal line to the length of the gap. I then made an endpoint to endpoint line up the curve, softend and smoothed all lines, and effectively recreated the part of the surface deleted in #6 but it was now flat in respect to its mirrored half.
              The "V" is essentially gone, as the join is flat.
              ![The "V" ridge is fixed 1/2 way up](/uploads/imported_attachments/hqZS_AutoSave_Front1.5fixSUCSU2015v1.jpg "The "V" ridge is fixed 1/2 way up")
              What you see is SU interpreting the surface as it reflects the 2 halves.
              That file is too big (18.5mb) to be attached for your reference. Even just the curved part is too big.
              A cupola pointers......
              The curves are way too fine, resulting in an unwieldy Curviloft surface. This skin has over 135000 entities alone. That is big. I know you want to 3D print a very smooth surface but take into account the resolution of the printer, and draw accordingly. The main problem you will face (NPI) is that Curviloft will almost double or even quadruple the line count from a perimeter because the endpoints of the opposing parts of a perimeter do not exactly align with each other.
              If you need to join 2 curved surfaces at a common edge, try to make the faces at the edge meet the other side as close to straight as possible, or you will need to massage that join line to make it smooth. That is a tedious task, one I have to do all too often.
              I hope this helps!
              jgb
                galrot
                I have sketchup 2016 and I tried to install this plugin and the latest libfredo-plugin through the Sketchucation extension. As far as I can see both got installed, but I am unable to find the toolbar or any way to access the Curviloft plugin to actually use it. Could anyone help me?
                  In v2016 you may need to activate the Lib and the Extension itself, using Preferences > Extensions.
                  The Extension should then appear in a submenu item [Tools > Fredo6 Collection > Curviloft.
                  There is also a Toolbar of the same name [which will also need activation]...
                  • H Offline
                    helpandtrouble
                    Hey.
                    I have a issue.
                    I have used the Curviloft plugin for a while now to create what it calls loft junctions between surfaces based on spline curves. This have worked perfectly until about a week ago or so.
                    Since then it have refused to complete the "loft surface". Instead it just color the edges purple like it did previously when I had forgotten to select a surrounding edge, and it refuses to do anything beyond that. I've tried to completely delete the plugin and re-install, but it did not fix it. I'm still unable to get it to work.
                    I think the problem started around the same time that I installed the fredotools plugin, but I'm not sure. Regardless I tried to delete that too but that did not help either.
                    • fredo6F Offline
                      @helpandtrouble
                      Could you open the Ruby console before launching Curviloft and see if there is any error message displayed while you do the selection in Curviloft.
                      • H Offline
                        helpandtrouble
                        The Ruby Console window remained blank while I tried to use the curviloft plugin. I have not used this ruby function before so I was unsure whether I was supposed to write anything or not? Here is a screen-shot of it, which also shows how far I am able to use the curviloft command.
                          It would appear that you are using the wrong tool. Try the third tool on the toolbar instead.
                          • H Offline
                            helpandtrouble
                            [attachment=0:fwubhjnj]<!-- ia0 -->Screenshot - 2_26_2017 , 7_07_23 AM.png<!-- ia0 -->[/attachment:fwubhjnj]
                            Hm, It can't seems like you are right, but I could swear that I used the same tools previously. Maybe I just had a brain fart. Rather embarrassing. πŸ’š
                              Azeemuddin
                              Hi everyone.
                              Can anyone help me for this problem with sketchup curviloft.
                              This is problem I am having
                                How did you install Curviloft and Round Corner? Did you also install LibFredo6?
                                  toy52372
                                  ζ„Ÿθ¬ε€§ε€§
                                  [mod=:nzf08c63]Thank you greatly[/mod:nzf08c63]
                                    Doopy
                                    @azeemuddin said:
                                    Hi everyone.
                                    Not sure where my first post went...
                                    Having a similar problem on a mac (OS 10.5.8) running SU7. Here is are pictures of the error dialogue, the Plugins folder, and the first several entries in the libFredo6 folder.Picture 2.pngPicture 3.pngPicture 4.png
                                    • CadFatherC Offline
                                      CadFather
                                      Hi Fredo, Is there anyway to override the default settings in the toolbar? (even hardcoded!)
                                      like this?
                                        @Doopy
                                        Have you installed the latest versions of the RBZ files for the various Fredo Plugins and his LibFredo ?
                                        Restart SketchUp after installation to ensure everything is getting meshed together properly...
                                        BUT...
                                        I suspect that it's because although your profile lists SUp v8, your post says that are using SUp v7 which is the issue.
                                        Even v8 is no longer supported by Trimble - there are many changes in the way Ruby code now works !
                                        Why haven't you upgraded to a newer version ?
                                        More than one Sketchup version can be installed coexist on the same computer, and you can always save_as from v2017 into any earlier version compatible format...
                                        • V Offline
                                          Vulfgangavi
                                          like this?
                                          [attachment=0:1jid7v16]<!-- ia0 -->edition.jpg<!-- ia0 -->[/attachment:1jid7v16]
                                          And while we are on the note of modifications, any chance for a tutorial on how to use this plug-in on our Linux based systems? I see that some of the libraries that it requires are already part of Linux but all instructions are reserved to Windows and Mac so far. I need to start creating new renders for http://promocodius.com/tr/magazalar/trendyol-indirim-kuponu soon to avoid fines for copyright reasons but if I will not be able to find a way of installing this plug-in on the office laptop, I will be restricted to the stupid old Inkscape and its plug-ins. Since you are all here, you should already know that the two bears no comparison...
                                          • fredo6F Offline
                                            NEW RELEASE: Curviloft v1.5b - 12 Aug 17
                                            Curviloft 1.5b is required for the support of usernames with non-ascii characters in Sketchup 2017.
                                            IMPORTANT: It requires LibFredo6 v7.7 or above.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 65
                                            • 66
                                            • 17 / 66
