    1.3k Posts 300 Posters 3.1m Views 298 Watching
    • jgbJ Offline
      jgb
      OK, Got it.
      I've been playing with it for well over an hour. I needed to implement a few tricks I've learned with Curviloft over the years when it just won't skin what I see as a clean perimeter. I managed to skin all the curves and yes, I do see the "V" ridge and it is why I said above. I did a partial re-skinning of the main join of the 2 components, and that does eliminate the "V", but it is a laborious job and I simply do not have the time to finish it, so here is what I did......
      1 - I separated the 2 halves so they do not interfere visually as I did the fix. Move just one comp on the red axis, so later it is easy to rejoin them.
      2 - I tried skinning the main complex curve, but the perimeter was not true. So trick #1 is to explode the curves and delete the edges at the corners, but leaving 1 edge as a rejoin reference endpoint. I then rejoined the end points for an intact curve that Curviloft will accept. 4 corners - 8 lines deleted and redrawn.
      3 - Curviloft skinned the side and top easily, but hung twice on the front curve.
      4 - Trick #2 - when Curviloft craps out on a "perfect" perimeter, it is most often due to a very complex curve (and this IS a very complex curve) or where the curve is also part of an adjacent curve, I move/copy the perimeter away from the total object. I make sure the corners are clean, 2 lines only connected at endpoints. Curviloft skinned this. It took almost 10 minutes; I thought it hung again. When I brought the skins back together, sure enough, the "V" was there.
      5 - I then softened and smoothed the join line and the "V" was less noticeable, but that was a visual fix only. A 3D printed part would have a ridge.
      6 - I deleted the 2 faces and lines at the join from bottom to only about 1/2 way up as this was taking a long time to do. I had to do it with perspective off because the lines were so close to each other.
      7 - I then drew a line ON RED AXIS from each horizontal line to the length of the gap. I then made an endpoint to endpoint line up the curve, softend and smoothed all lines, and effectively recreated the part of the surface deleted in #6 but it was now flat in respect to its mirrored half.
      The "V" is essentially gone, as the join is flat.
      ![The "V" ridge is fixed 1/2 way up](/uploads/imported_attachments/hqZS_AutoSave_Front1.5fixSUCSU2015v1.jpg "The "V" ridge is fixed 1/2 way up")
      What you see is SU interpreting the surface as it reflects the 2 halves.
      That file is too big (18.5mb) to be attached for your reference. Even just the curved part is too big.
      A cupola pointers......
      The curves are way too fine, resulting in an unwieldy Curviloft surface. This skin has over 135000 entities alone. That is big. I know you want to 3D print a very smooth surface but take into account the resolution of the printer, and draw accordingly. The main problem you will face (NPI) is that Curviloft will almost double or even quadruple the line count from a perimeter because the endpoints of the opposing parts of a perimeter do not exactly align with each other.
      If you need to join 2 curved surfaces at a common edge, try to make the faces at the edge meet the other side as close to straight as possible, or you will need to massage that join line to make it smooth. That is a tedious task, one I have to do all too often.
      I hope this helps!
      jgb
        galrot
        I have sketchup 2016 and I tried to install this plugin and the latest libfredo-plugin through the Sketchucation extension. As far as I can see both got installed, but I am unable to find the toolbar or any way to access the Curviloft plugin to actually use it. Could anyone help me?
          In v2016 you may need to activate the Lib and the Extension itself, using Preferences > Extensions.
          The Extension should then appear in a submenu item [Tools > Fredo6 Collection > Curviloft.
          There is also a Toolbar of the same name [which will also need activation]...
          • H Offline
            helpandtrouble
            Hey.
            I have a issue.
            I have used the Curviloft plugin for a while now to create what it calls loft junctions between surfaces based on spline curves. This have worked perfectly until about a week ago or so.
            Since then it have refused to complete the "loft surface". Instead it just color the edges purple like it did previously when I had forgotten to select a surrounding edge, and it refuses to do anything beyond that. I've tried to completely delete the plugin and re-install, but it did not fix it. I'm still unable to get it to work.
            I think the problem started around the same time that I installed the fredotools plugin, but I'm not sure. Regardless I tried to delete that too but that did not help either.
            • fredo6F Offline
              @helpandtrouble
              Could you open the Ruby console before launching Curviloft and see if there is any error message displayed while you do the selection in Curviloft.
              • H Offline
                helpandtrouble
                The Ruby Console window remained blank while I tried to use the curviloft plugin. I have not used this ruby function before so I was unsure whether I was supposed to write anything or not? Here is a screen-shot of it, which also shows how far I am able to use the curviloft command.
                  It would appear that you are using the wrong tool. Try the third tool on the toolbar instead.
                  • H Offline
                    helpandtrouble
                    [attachment=0:fwubhjnj]<!-- ia0 -->Screenshot - 2_26_2017 , 7_07_23 AM.png<!-- ia0 -->[/attachment:fwubhjnj]
                    Hm, It can't seems like you are right, but I could swear that I used the same tools previously. Maybe I just had a brain fart. Rather embarrassing. πŸ’š
                      Azeemuddin
                      Hi everyone.
                      Can anyone help me for this problem with sketchup curviloft.
                      This is problem I am having
                        How did you install Curviloft and Round Corner? Did you also install LibFredo6?
                          toy52372
                          ζ„Ÿθ¬ε€§ε€§
                          [mod=:nzf08c63]Thank you greatly[/mod:nzf08c63]
                            Doopy
                            @azeemuddin said:
                            Hi everyone.
                            Not sure where my first post went...
                            Having a similar problem on a mac (OS 10.5.8) running SU7. Here is are pictures of the error dialogue, the Plugins folder, and the first several entries in the libFredo6 folder.Picture 2.pngPicture 3.pngPicture 4.png
                            • CadFatherC Offline
                              CadFather
                              Hi Fredo, Is there anyway to override the default settings in the toolbar? (even hardcoded!)
                              like this?
                                @Doopy
                                Have you installed the latest versions of the RBZ files for the various Fredo Plugins and his LibFredo ?
                                Restart SketchUp after installation to ensure everything is getting meshed together properly...
                                BUT...
                                I suspect that it's because although your profile lists SUp v8, your post says that are using SUp v7 which is the issue.
                                Even v8 is no longer supported by Trimble - there are many changes in the way Ruby code now works !
                                Why haven't you upgraded to a newer version ?
                                More than one Sketchup version can be installed coexist on the same computer, and you can always save_as from v2017 into any earlier version compatible format...
                                • V Offline
                                  Vulfgangavi
                                  like this?
                                  [attachment=0:1jid7v16]<!-- ia0 -->edition.jpg<!-- ia0 -->[/attachment:1jid7v16]
                                  And while we are on the note of modifications, any chance for a tutorial on how to use this plug-in on our Linux based systems? I see that some of the libraries that it requires are already part of Linux but all instructions are reserved to Windows and Mac so far. I need to start creating new renders for http://promocodius.com/tr/magazalar/trendyol-indirim-kuponu soon to avoid fines for copyright reasons but if I will not be able to find a way of installing this plug-in on the office laptop, I will be restricted to the stupid old Inkscape and its plug-ins. Since you are all here, you should already know that the two bears no comparison...
                                  • fredo6F Offline
                                    NEW RELEASE: Curviloft v1.5b - 12 Aug 17
                                    Curviloft 1.5b is required for the support of usernames with non-ascii characters in Sketchup 2017.
                                    IMPORTANT: It requires LibFredo6 v7.7 or above.
                                    • jgbJ Offline
                                      jgb
                                      @azeemuddin said:
                                      Hi everyone.
                                      I had the same problem.
                                      The solution is to reinstall the latest version of Curviloft or any other Fredo6 tools, but ONLY AFTER the latest LibFredo is installed.
                                      jgb
                                        SWills
                                        Not working for me 😞(( comes up highlighting my shapes with numbers and then never shows the preview once I press enter. Could anyone help me out?
                                          Upload your model so we can see what you've got.
                                          • fredo6F Offline
                                            NEW RELEASE: Curviloft v1.6a - 13 Aug 17
                                            Curviloft 1.6a is a maintenance release with the following additions:
                                            • Support of usernames with non-ascii characters
                                            • Certified for Sketchup 2017.
                                            • Compatible with high-resolution screens (simulation below)
                                            See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
                                            Main post of this thread
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 65
                                            • 66
                                            • 55 / 66
