    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • fredo6F
      @helpandtrouble
      Could you open the Ruby console before launching Curviloft and see if there is any error message displayed while you do the selection in Curviloft.
      • H
        helpandtrouble
        The Ruby Console window remained blank while I tried to use the curviloft plugin. I have not used this ruby function before so I was unsure whether I was supposed to write anything or not? Here is a screen-shot of it, which also shows how far I am able to use the curviloft command.
          It would appear that you are using the wrong tool. Try the third tool on the toolbar instead.
          • H
            helpandtrouble
            [attachment=0:fwubhjnj]<!-- ia0 -->Screenshot - 2_26_2017 , 7_07_23 AM.png<!-- ia0 -->[/attachment:fwubhjnj]
            Hm, It can't seems like you are right, but I could swear that I used the same tools previously. Maybe I just had a brain fart. Rather embarrassing. πŸ’š
              Azeemuddin
              Hi everyone.
              Can anyone help me for this problem with sketchup curviloft.
              This is problem I am having
                How did you install Curviloft and Round Corner? Did you also install LibFredo6?
                • T
                  toy52372
                  ζ„Ÿθ¬ε€§ε€§
                  [mod=:nzf08c63]Thank you greatly[/mod:nzf08c63]
                    Doopy
                    @azeemuddin said:
                    Hi everyone.
                    Not sure where my first post went...
                    Having a similar problem on a mac (OS 10.5.8) running SU7. Here is are pictures of the error dialogue, the Plugins folder, and the first several entries in the libFredo6 folder.Picture 2.pngPicture 3.pngPicture 4.png
                    • CadFatherC
                      CadFather
                      Hi Fredo, Is there anyway to override the default settings in the toolbar? (even hardcoded!)
                      like this?
                        @Doopy
                        Have you installed the latest versions of the RBZ files for the various Fredo Plugins and his LibFredo ?
                        Restart SketchUp after installation to ensure everything is getting meshed together properly...
                        BUT...
                        I suspect that it's because although your profile lists SUp v8, your post says that are using SUp v7 which is the issue.
                        Even v8 is no longer supported by Trimble - there are many changes in the way Ruby code now works !
                        Why haven't you upgraded to a newer version ?
                        More than one Sketchup version can be installed coexist on the same computer, and you can always save_as from v2017 into any earlier version compatible format...
                        • V
                          Vulfgangavi
                          like this?
                          [attachment=0:1jid7v16]<!-- ia0 -->edition.jpg<!-- ia0 -->[/attachment:1jid7v16]
                          And while we are on the note of modifications, any chance for a tutorial on how to use this plug-in on our Linux based systems? I see that some of the libraries that it requires are already part of Linux but all instructions are reserved to Windows and Mac so far. I need to start creating new renders for http://promocodius.com/tr/magazalar/trendyol-indirim-kuponu soon to avoid fines for copyright reasons but if I will not be able to find a way of installing this plug-in on the office laptop, I will be restricted to the stupid old Inkscape and its plug-ins. Since you are all here, you should already know that the two bears no comparison...
                          • fredo6F
                            NEW RELEASE: Curviloft v1.5b - 12 Aug 17
                            Curviloft 1.5b is required for the support of usernames with non-ascii characters in Sketchup 2017.
                            IMPORTANT: It requires LibFredo6 v7.7 or above.
                            • jgbJ
                              jgb
                              @azeemuddin said:
                              Hi everyone.
                              I had the same problem.
                              The solution is to reinstall the latest version of Curviloft or any other Fredo6 tools, but ONLY AFTER the latest LibFredo is installed.
                              jgb
                                SWills
                                Not working for me 😞(( comes up highlighting my shapes with numbers and then never shows the preview once I press enter. Could anyone help me out?
                                  Upload your model so we can see what you've got.
                                  • fredo6F
                                    NEW RELEASE: Curviloft v1.6a - 13 Aug 17
                                    Curviloft 1.6a is a maintenance release with the following additions:
                                    • Support of usernames with non-ascii characters
                                    • Certified for Sketchup 2017.
                                    • Compatible with high-resolution screens (simulation below)
                                    See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
                                    Main post of this thread
                                    • jgbJ
                                      jgb
                                      This is Sunday. Don't you ever take a day off???
                                      jgb
                                      • fredo6F
                                        Precisely, ...I work on the other days...
                                          @SWills
                                          Please upload a SKP displaying this issue.
                                          It need not be a big file, just the part with the problem...
                                            deezprez
                                            I recently started to have a problem with curviloft lofting along a path. When I choose the two shapes and path it doesnt work, the part outlines change color and nothing happens. This just started two days ago but I have been having issues for a while were it waits for a path to be made and never finishes. I could fix this by closing and reopening sketchup. I really dont know what is happening. I will post the file were im triying to loft the specific shape that just wont work.
                                            lofting test.skp
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 65
                                            • 66
                                            • 56 / 66
