    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
      • HornOxxH Offline
        HornOxx
        Rich, this is just awesome πŸ‘ ❗ πŸ‘
        This is a great vehicle - This tank design look more nice than threatening. Great details - does one chain link(?) consist out of 2 single parts?
        never trust a skinny cook
          So... when will we see the animated version...? πŸ˜„
          • pbacotP Offline
            "Sick" as the kiddies say. Is that a turret? Do the tubes upfront stretch if it turns?
            • N Offline
              nlipovac
              This tank looks made for new toy design, shoots soap balloons. πŸ˜„
              • ontaottoO Offline
                ontaotto
                @cotty said:
                Another simple one...
                [attachment=0:1su2j5k6]<!-- ia0 -->2pipes.jpg<!-- ia0 -->[/attachment:1su2j5k6]
                I have done in the past some similar shapes, to me the best shape to get those T Pipes are the hexagons:
                https://lh3.googleusercontent.com/GN3AwVZp-TozAfcTf7BfTuFBhVtuXP1iyVVXokQjA6mPIeGhvmq_JXg_-pP20kvaIgDuklLBk1dp_w=w1920-h1080-no
                https://lh3.googleusercontent.com/-O6lTySKOAlM/WEbm6k4VBaI/AAAAAAAAB4U/KB2TxAF6pOImUO0SzMBeDcAeFx0R5-eTACL0B/w530-d-h479-p/T%2BTube%2B3D%2BMesh%2BCorrected.png
                https://lh3.googleusercontent.com/-ihtGxqGDFHg/WEbm_aqnCkI/AAAAAAAAB4w/CVNAlgiWrkYf4oNX-dSEqV88dxKI28G8QCL0B/w530-d-h528-p/T%2BTube%2B3D%2BModel.png
                This sample was done in another program, but works exactly the same in SU by using SubD.
                Cheers!
                Twitter: @ontaotto
                  Those are octagons, right?
                  • ontaottoO Offline
                    ontaotto
                    Dang! Yeah you're right, in this particular case were used octagons, but in the main shapes when you want to get rounded ones, the hexagon should work good.
                    Twitter: @ontaotto
                      Do you generally feel hexagons works better than octagons or any other ngons?
                      • ontaottoO Offline
                        ontaotto
                        When you are working with simple tubes, the hexagon seems to me as the best, this is another sample:
                        https://lh3.googleusercontent.com/-A8MwVNRwKSw/WEctywRmQiI/AAAAAAAAB6E/et8wue-v8gM7CjqvN3PNUkO_hopCM6qCQCL0B/w530-d-h321-p/Carrara%2BSubD.png
                        It's a simple hexagon based shape and when you repeat it you can create a texture, as many shown here, the best thing is that you can UV map those very well:
                        https://lh3.googleusercontent.com/-F3c0pcs0YEk/WEcuKtwBsrI/AAAAAAAAB60/JvcrEzR2oG8hJGXZNSo-cNcSgHXbACPBwCL0B/w530-d-h427-p/3D%2BModel%2BCarrara.png
                        Twitter: @ontaotto
                          Lovely example!
                          Btw, what software is that? Do you know if it uses OpenSubdiv?
                          • panixiaP Offline
                            panixia
                            not 100% sure about the exagon being the best starting shape, depending on what i have to do, in most cases, i start from 4,8,12,16 segments.. anything you can split by 4.. there are some cases in wich i use 6, that's fine, but i would not say that's always"the golden rule".. it tends to generate asymmetrical topology distribution/flow/cap, sometimes it's what i need, sometime it's not..
                            looking at your grid example, in that case exagon is the best way to go, bacause you need to tile your rows "alternate" but in the case of a "stack bond style" tiling, that same base topology could be quite problematic..
                            so definetly, it depends on the shape/topology you are tryng to achieve.
                              • JQLJ Offline
                                JQL
                                Have you seen this Thomthom?
                                Introduction to Microdisplacements β€” Blender Guru
                                This is one of the most exciting developmentsΒ to come to Blender inΒ recent years. It's two separate features that work together: Adaptive Subdivision - Automatically subdivides objects based on the amount of screen space they take up Micropolygon displacement - Uses t
                                Blender Guru (www.blenderguru.com)
                                www.casca.pt
                                Visit us on facebook!
                                • N Offline
                                  nlipovac
                                  Hi Rich, when will be seeing SU_to_wRapr_to_Substance tutorials?
                                  Great modeling.
                                  • ontaottoO Offline
                                    ontaotto
                                    @thomthom said:
                                    Lovely example!
                                    Thanks, it is Carrara the which is very compatible with SketchUp, and I don't know about Open SubD??
                                    Twitter: @ontaotto
                                    • ontaottoO Offline
                                      ontaotto
                                      Yes sure, what I am saying is to build tubes, and as you have seen in the T Pipe tubes the best sample I have done was by using octagons, the main shape recommended to subdivide is the square, mainly known as Quad, it may vary according the model of course.
                                      Twitter: @ontaotto
                                        It's the de-factor subdivision standard that's being adopted. Originally developed by pixar: http://graphics.pixar.com/opensubdiv/docs/intro.html
                                        Next version of SUbD will use OpenSubdiv as the subdivision engine - so it'll subdivide consistently with other applications that implement OpenSubdiv.
                                        • ontaottoO Offline
                                          ontaotto
                                          Well honestly I have no idea if Carrara does have that, however I have done several tests in this program and the process to subdivide is quite similar to other 3D programs such Maya, Blender and others, I am very excited about the SU plugin you have developed, I did install it a few months ago, I was trying to upload more samples but my trial has been expired, (so sad) Will post some other samples soon.
                                          Regards!
                                          Otto
                                          Twitter: @ontaotto
                                          • BoxB Offline
                                            A little pub doodle. If i get a chance in the next few days I'll reconstruct it fully as a gif.
                                            http://i.imgur.com/1303dBI.gif
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 82
                                            • 83
                                            • 68 / 83
