    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.4m Views 79 Watching
      @hornoxx said:
      @thomthom said:
      ...and now I'm thinking of that cursed Charger I never finish... one day - one day!
      Hey Thomas - I thought it was already finished but I missed it somehow πŸ˜„ πŸ˜„
      No... whenever I start working on it I end up writing an extension or enhancement to aid the modelling... facepalm
      • panixiaP Online
        panixia
        lol 🀣
          kaas
          ...start working please....Curious what you will come up with next! πŸ˜‰
          • BoxB Offline
            Errm, that would be a white whale. But then you norgies eat whale. So maybe it's a lightly grilled whale.
            ...I'm off now to pickle a koala for my breakfast.
              You know, I started modelling that car so many years ago - in 3dsmax. It's starting to become a haunting ghost. At some point I need to defeat this thing. My bluewhite whale.
                Cursed, I even quickly googled it and picked the first answer.
                • Z Offline
                  ZahariStoyanov
                  Got me dead 🀣
                  • Rich O BrienR Online
                    • HornOxxH Offline
                      HornOxx
                      Rich, this is just awesome πŸ‘ ❗ πŸ‘
                      This is a great vehicle - This tank design look more nice than threatening. Great details - does one chain link(?) consist out of 2 single parts?
                      never trust a skinny cook
                        So... when will we see the animated version...? πŸ˜„
                        • pbacotP Offline
                          "Sick" as the kiddies say. Is that a turret? Do the tubes upfront stretch if it turns?
                          • N Offline
                            nlipovac
                            This tank looks made for new toy design, shoots soap balloons. πŸ˜„
                            • ontaottoO Offline
                              ontaotto
                              @cotty said:
                              Another simple one...
                              [attachment=0:1su2j5k6]<!-- ia0 -->2pipes.jpg<!-- ia0 -->[/attachment:1su2j5k6]
                              I have done in the past some similar shapes, to me the best shape to get those T Pipes are the hexagons:
                              https://lh3.googleusercontent.com/GN3AwVZp-TozAfcTf7BfTuFBhVtuXP1iyVVXokQjA6mPIeGhvmq_JXg_-pP20kvaIgDuklLBk1dp_w=w1920-h1080-no
                              https://lh3.googleusercontent.com/-O6lTySKOAlM/WEbm6k4VBaI/AAAAAAAAB4U/KB2TxAF6pOImUO0SzMBeDcAeFx0R5-eTACL0B/w530-d-h479-p/T%2BTube%2B3D%2BMesh%2BCorrected.png
                              https://lh3.googleusercontent.com/-ihtGxqGDFHg/WEbm_aqnCkI/AAAAAAAAB4w/CVNAlgiWrkYf4oNX-dSEqV88dxKI28G8QCL0B/w530-d-h528-p/T%2BTube%2B3D%2BModel.png
                              This sample was done in another program, but works exactly the same in SU by using SubD.
                              Cheers!
                              Twitter: @ontaotto
                                Those are octagons, right?
                                • ontaottoO Offline
                                  ontaotto
                                  Dang! Yeah you're right, in this particular case were used octagons, but in the main shapes when you want to get rounded ones, the hexagon should work good.
                                  Twitter: @ontaotto
                                    Do you generally feel hexagons works better than octagons or any other ngons?
                                    • ontaottoO Offline
                                      ontaotto
                                      When you are working with simple tubes, the hexagon seems to me as the best, this is another sample:
                                      https://lh3.googleusercontent.com/-A8MwVNRwKSw/WEctywRmQiI/AAAAAAAAB6E/et8wue-v8gM7CjqvN3PNUkO_hopCM6qCQCL0B/w530-d-h321-p/Carrara%2BSubD.png
                                      It's a simple hexagon based shape and when you repeat it you can create a texture, as many shown here, the best thing is that you can UV map those very well:
                                      https://lh3.googleusercontent.com/-F3c0pcs0YEk/WEcuKtwBsrI/AAAAAAAAB60/JvcrEzR2oG8hJGXZNSo-cNcSgHXbACPBwCL0B/w530-d-h427-p/3D%2BModel%2BCarrara.png
                                      Twitter: @ontaotto
                                        Lovely example!
                                        Btw, what software is that? Do you know if it uses OpenSubdiv?
                                        • panixiaP Online
                                          panixia
                                          not 100% sure about the exagon being the best starting shape, depending on what i have to do, in most cases, i start from 4,8,12,16 segments.. anything you can split by 4.. there are some cases in wich i use 6, that's fine, but i would not say that's always"the golden rule".. it tends to generate asymmetrical topology distribution/flow/cap, sometimes it's what i need, sometime it's not..
                                          looking at your grid example, in that case exagon is the best way to go, bacause you need to tile your rows "alternate" but in the case of a "stack bond style" tiling, that same base topology could be quite problematic..
                                          so definetly, it depends on the shape/topology you are tryng to achieve.
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 83
                                            • 84
                                            • 36 / 84
