    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.9m Views 79 Watching
    • ontaottoO Offline
      ontaotto
      @thomthom said:
      Those are octagons, right?
      Dang! Yeah you're right, in this particular case were used octagons, but in the main shapes when you want to get rounded ones, the hexagon should work good.
      Twitter: @ontaotto
        Do you generally feel hexagons works better than octagons or any other ngons?
        • ontaottoO Offline
          ontaotto
          When you are working with simple tubes, the hexagon seems to me as the best, this is another sample:
          https://lh3.googleusercontent.com/-A8MwVNRwKSw/WEctywRmQiI/AAAAAAAAB6E/et8wue-v8gM7CjqvN3PNUkO_hopCM6qCQCL0B/w530-d-h321-p/Carrara%2BSubD.png
          It's a simple hexagon based shape and when you repeat it you can create a texture, as many shown here, the best thing is that you can UV map those very well:
          https://lh3.googleusercontent.com/-F3c0pcs0YEk/WEcuKtwBsrI/AAAAAAAAB60/JvcrEzR2oG8hJGXZNSo-cNcSgHXbACPBwCL0B/w530-d-h427-p/3D%2BModel%2BCarrara.png
          Twitter: @ontaotto
            Lovely example!
            Btw, what software is that? Do you know if it uses OpenSubdiv?
            • panixiaP Offline
              panixia
              not 100% sure about the exagon being the best starting shape, depending on what i have to do, in most cases, i start from 4,8,12,16 segments.. anything you can split by 4.. there are some cases in wich i use 6, that's fine, but i would not say that's always"the golden rule".. it tends to generate asymmetrical topology distribution/flow/cap, sometimes it's what i need, sometime it's not..
              looking at your grid example, in that case exagon is the best way to go, bacause you need to tile your rows "alternate" but in the case of a "stack bond style" tiling, that same base topology could be quite problematic..
              so definetly, it depends on the shape/topology you are tryng to achieve.
                • JQLJ Offline
                  JQL
                  Have you seen this Thomthom?
                  http://www.blenderguru.com/tutorials/introduction-microdisplacements/
                  www.casca.pt
                  Visit us on facebook!
                  • N Offline
                    nlipovac
                    Hi Rich, when will be seeing SU_to_wRapr_to_Substance tutorials?
                    Great modeling.
                    • ontaottoO Offline
                      ontaotto
                      @thomthom said:
                      Lovely example!
                      Thanks, it is Carrara the which is very compatible with SketchUp, and I don't know about Open SubD??
                      Twitter: @ontaotto
                      • ontaottoO Offline
                        ontaotto
                        Yes sure, what I am saying is to build tubes, and as you have seen in the T Pipe tubes the best sample I have done was by using octagons, the main shape recommended to subdivide is the square, mainly known as Quad, it may vary according the model of course.
                        Twitter: @ontaotto
                          It's the de-factor subdivision standard that's being adopted. Originally developed by pixar: http://graphics.pixar.com/opensubdiv/docs/intro.html
                          Next version of SUbD will use OpenSubdiv as the subdivision engine - so it'll subdivide consistently with other applications that implement OpenSubdiv.
                          • ontaottoO Offline
                            ontaotto
                            Well honestly I have no idea if Carrara does have that, however I have done several tests in this program and the process to subdivide is quite similar to other 3D programs such Maya, Blender and others, I am very excited about the SU plugin you have developed, I did install it a few months ago, I was trying to upload more samples but my trial has been expired, (so sad) Will post some other samples soon.
                            Regards!
                            Otto
                            Twitter: @ontaotto
                            • BoxB Offline
                              A little pub doodle. If i get a chance in the next few days I'll reconstruct it fully as a gif.
                              http://i.imgur.com/1303dBI.gif
                                kenancakir
                                Hi Box, it says image not found, from Turkiye..
                                • BoxB Offline
                                  That is strange, it is my normal Imgur account which you have seen on FB.
                                  The gif was too big to upload directly here.
                                  I'll add a screenshot for you.
                                  • BoxB Offline
                                    Here we go, sorry, I would normally post the non facebooked one here but I forgot to keep a clean copy.
                                    http://i.imgur.com/gEkvuNf.gif
                                    • bazB Offline
                                      baz
                                      That's amazing. You go crazy!
                                      • cottyC Offline
                                        cotty
                                        +1
                                        πŸ‘
                                        my SketchUp gallery
                                        • ontaottoO Offline
                                          ontaotto
                                          That's pretty nice!
                                          Twitter: @ontaotto
                                          • HornOxxH Offline
                                            HornOxx
                                            @box said:
                                            A little pub doodle
                                            πŸ‘ πŸ‘
                                            this is so great again - Where do you get these crazy ideas from ??
                                            BTW - thanks for your many BOX-gifs here which always are so interesting and so helpful !!!
                                            never trust a skinny cook
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 83
                                            • 84
                                            • 37 / 84
