    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.1m Views 79 Watching
      You know, I started modelling that car so many years ago - in 3dsmax. It's starting to become a haunting ghost. At some point I need to defeat this thing. My bluewhite whale.
        @box said:
        Errm, that would be a white whale.
        Cursed, I even quickly googled it and picked the first answer.
        • Z
          ZahariStoyanov
          @box said:
          Errm, that would be a white whale. But then you norgies eat whale. So maybe it's a lightly grilled whale.
          ...I'm off now to pickle a koala for my breakfast.
          Got me dead 🀣
            • HornOxxH
              HornOxx
              Rich, this is just awesome πŸ‘ ❗ πŸ‘
              This is a great vehicle - This tank design look more nice than threatening. Great details - does one chain link(?) consist out of 2 single parts?
              never trust a skinny cook
                So... when will we see the animated version...? πŸ˜„
                • pbacotP
                  "Sick" as the kiddies say. Is that a turret? Do the tubes upfront stretch if it turns?
                  • N
                    nlipovac
                    This tank looks made for new toy design, shoots soap balloons. πŸ˜„
                    • ontaottoO
                      ontaotto
                      @cotty said:
                      Another simple one...
                      [attachment=0:1su2j5k6]<!-- ia0 -->2pipes.jpg<!-- ia0 -->[/attachment:1su2j5k6]
                      I have done in the past some similar shapes, to me the best shape to get those T Pipes are the hexagons:
                      https://lh3.googleusercontent.com/GN3AwVZp-TozAfcTf7BfTuFBhVtuXP1iyVVXokQjA6mPIeGhvmq_JXg_-pP20kvaIgDuklLBk1dp_w=w1920-h1080-no
                      https://lh3.googleusercontent.com/-O6lTySKOAlM/WEbm6k4VBaI/AAAAAAAAB4U/KB2TxAF6pOImUO0SzMBeDcAeFx0R5-eTACL0B/w530-d-h479-p/T%2BTube%2B3D%2BMesh%2BCorrected.png
                      https://lh3.googleusercontent.com/-ihtGxqGDFHg/WEbm_aqnCkI/AAAAAAAAB4w/CVNAlgiWrkYf4oNX-dSEqV88dxKI28G8QCL0B/w530-d-h528-p/T%2BTube%2B3D%2BModel.png
                      This sample was done in another program, but works exactly the same in SU by using SubD.
                      Cheers!
                      Twitter: @ontaotto
                        Those are octagons, right?
                        • ontaottoO
                          ontaotto
                          Dang! Yeah you're right, in this particular case were used octagons, but in the main shapes when you want to get rounded ones, the hexagon should work good.
                          Twitter: @ontaotto
                            Do you generally feel hexagons works better than octagons or any other ngons?
                            • ontaottoO
                              ontaotto
                              When you are working with simple tubes, the hexagon seems to me as the best, this is another sample:
                              https://lh3.googleusercontent.com/-A8MwVNRwKSw/WEctywRmQiI/AAAAAAAAB6E/et8wue-v8gM7CjqvN3PNUkO_hopCM6qCQCL0B/w530-d-h321-p/Carrara%2BSubD.png
                              It's a simple hexagon based shape and when you repeat it you can create a texture, as many shown here, the best thing is that you can UV map those very well:
                              https://lh3.googleusercontent.com/-F3c0pcs0YEk/WEcuKtwBsrI/AAAAAAAAB60/JvcrEzR2oG8hJGXZNSo-cNcSgHXbACPBwCL0B/w530-d-h427-p/3D%2BModel%2BCarrara.png
                              Twitter: @ontaotto
                                Lovely example!
                                Btw, what software is that? Do you know if it uses OpenSubdiv?
                                • panixiaP
                                  panixia
                                  not 100% sure about the exagon being the best starting shape, depending on what i have to do, in most cases, i start from 4,8,12,16 segments.. anything you can split by 4.. there are some cases in wich i use 6, that's fine, but i would not say that's always"the golden rule".. it tends to generate asymmetrical topology distribution/flow/cap, sometimes it's what i need, sometime it's not..
                                  looking at your grid example, in that case exagon is the best way to go, bacause you need to tile your rows "alternate" but in the case of a "stack bond style" tiling, that same base topology could be quite problematic..
                                  so definetly, it depends on the shape/topology you are tryng to achieve.
                                    • JQLJ
                                      JQL
                                      Have you seen this Thomthom?
                                      http://www.blenderguru.com/tutorials/introduction-microdisplacements/
                                      www.casca.pt
                                      Visit us on facebook!
                                      • N
                                        nlipovac
                                        Hi Rich, when will be seeing SU_to_wRapr_to_Substance tutorials?
                                        Great modeling.
                                        • ontaottoO
                                          ontaotto
                                          @thomthom said:
                                          Lovely example!
                                          Thanks, it is Carrara the which is very compatible with SketchUp, and I don't know about Open SubD??
                                          Twitter: @ontaotto
                                          • ontaottoO
                                            ontaotto
                                            Yes sure, what I am saying is to build tubes, and as you have seen in the T Pipe tubes the best sample I have done was by using octagons, the main shape recommended to subdivide is the square, mainly known as Quad, it may vary according the model of course.
                                            Twitter: @ontaotto
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 83
                                            • 84
                                            • 36 / 84
