    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
    • B
      bsfranza
      πŸ˜ƒ nice to hear - now i wish you for the next year the time to implement and release - may the sales be with you!
      • Bob JamesB
        Bob James
        @thomthom said:
        Indeed - future release of Vertex Tools will have such a feature. πŸ˜„
        Are you using human or geological frame of time? 😎 πŸ˜†
        • C
          cuttingedge
          Thomas, can we chamfer a vertex? or vertices at the same time with some given parameters as in max?
            At the moment no - but I'm working on version 2.
            However, it's been a while since I used Max - do you have some visuals of what this feature looks like? GIF?
              rv1974
              thomthom, please add edge extrude (with option for negative values).
                rv1974
                http://www.polyboost.com/features_modelling.htm
                Here you've got endless source for inspiration. They were bought out by AD and became 'graphite tools' inside 3ds Max. The amount of work is huge so I guess you should cooperate with Fredo and found start-up for porting Polyboost set to SU πŸ˜„
                • C
                  cuttingedge
                  @thomthom said:
                  This is a screen shot of two of the other things to do with vertex-
                  Chamfer (or offset if no value to chamfer) and Extrude.
                  vertex edit
                  Not for any particular model in mind at the moment but I just like the ability to control vertices with some common parameters to play with. By playing around sometimes inspiration comes!
                  I dont know if this is something in your immediate plans.
                  Do you plan to include inset?. I dont know if it falls under the category of vertex though.
                  • HieruH
                    Hieru
                    Am I right in thinking that you should be able to enter a relative value when extruding?
                    Just trying to figure out if I'm misremembering this function or if another plugin is causing a conflict.
                    www.davidhier.co.uk
                      What do you mean by relative value? And what are you observing?
                        I'd imagine what David is mentioning is that VCB input after CTRL+Drag returns the selected extrusion to it's origin.
                            that's VT 2. try VT 1.
                            Extrude and then type value for length. boom...snaps back to origin
                              Ah... forgot about that. Been using the dev version of VT2 for so long...
                              • BoxB
                                I must admit that has be annoying me for ages and I thought I was either being stupid or there was a glitch in my setup.
                                  Sorry about that. I really need to get VT2 ready. Still working on the feature-set though.
                                  • HieruH
                                    Hieru
                                    Rich hit the nail on the head...that's exactly what I was talking about.
                                    Glad I'm not the only one Box πŸ‘
                                    As long as it's in the pipeline and it's not down to me being dumb then I'm happy to wait for the next version....no rush Thomas πŸ˜‰ .
                                    www.davidhier.co.uk
                                    • C
                                      cuttingedge
                                      Hi thomthom,
                                      Ive been wanting to ask you this question.
                                      I think the soft selection of Vertex tools is awesome. The only thing is, Can we set the soft selection to select only neighbor vertices (within the specified radius) that are connected. I hope you get what I mean by connected.
                                      The problem I face is if I try to select vertices in the front, the back are also selected and couldnt deselect it because its with the 'soft select radius', but those are not connected to the rest of the selection in front.
                                      Image shows what I mean
                                      vertex tools soft selection
                                        I know in VT2 Thom is tackling that issue. I requested an 'Only Connected' type fall-off to allow this type of manipulation.
                                        • pbacotP
                                          Or "follow surface" so only points are soft-selected in a contiguous fashion from the selection
                                            Yes - this is slated for V2 of VT.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 33
                                            • 34
                                            • 21 / 34
