    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 608.7k Views 92 Watching
      bsfranza
      hi there,
      just wantet to state a feature request for vertex tools πŸ˜ƒ
      how about the option to merge vertices to a designated spot/selected vertice? that would really help!
      thanks
      • panixiaP Offline
        panixia
        i'm pretty much sure Thom WILL add it in the next version. along with some other really cool features.. πŸ˜›
          Indeed - future release of Vertex Tools will have such a feature. πŸ˜„
            bsfranza
            πŸ˜ƒ nice to hear - now i wish you for the next year the time to implement and release - may the sales be with you!
            • Bob JamesB Offline
              Bob James
              Are you using human or geological frame of time? 😎 πŸ˜†
                cuttingedge
                Thomas, can we chamfer a vertex? or vertices at the same time with some given parameters as in max?
                  At the moment no - but I'm working on version 2.
                  However, it's been a while since I used Max - do you have some visuals of what this feature looks like? GIF?
                    rv1974
                    thomthom, please add edge extrude (with option for negative values).
                      rv1974
                      http://www.polyboost.com/features_modelling.htm
                      Here you've got endless source for inspiration. They were bought out by AD and became 'graphite tools' inside 3ds Max. The amount of work is huge so I guess you should cooperate with Fredo and found start-up for porting Polyboost set to SU πŸ˜„
                        cuttingedge
                        @thomthom said:
                        This is a screen shot of two of the other things to do with vertex-
                        Chamfer (or offset if no value to chamfer) and Extrude.
                        vertex edit
                        Not for any particular model in mind at the moment but I just like the ability to control vertices with some common parameters to play with. By playing around sometimes inspiration comes!
                        I dont know if this is something in your immediate plans.
                        Do you plan to include inset?. I dont know if it falls under the category of vertex though.
                        • HieruH Offline
                          Hieru
                          Am I right in thinking that you should be able to enter a relative value when extruding?
                          Just trying to figure out if I'm misremembering this function or if another plugin is causing a conflict.
                          www.davidhier.co.uk
                            What do you mean by relative value? And what are you observing?
                              I'd imagine what David is mentioning is that VCB input after CTRL+Drag returns the selected extrusion to it's origin.
                                  that's VT 2. try VT 1.
                                  Extrude and then type value for length. boom...snaps back to origin
                                    Ah... forgot about that. Been using the dev version of VT2 for so long...
                                    • BoxB Offline
                                      I must admit that has be annoying me for ages and I thought I was either being stupid or there was a glitch in my setup.
                                        Sorry about that. I really need to get VT2 ready. Still working on the feature-set though.
                                        • HieruH Offline
                                          Hieru
                                          Rich hit the nail on the head...that's exactly what I was talking about.
                                          Glad I'm not the only one Box πŸ‘
                                          As long as it's in the pipeline and it's not down to me being dumb then I'm happy to wait for the next version....no rush Thomas πŸ˜‰ .
                                          www.davidhier.co.uk
                                            cuttingedge
                                            Hi thomthom,
                                            Ive been wanting to ask you this question.
                                            I think the soft selection of Vertex tools is awesome. The only thing is, Can we set the soft selection to select only neighbor vertices (within the specified radius) that are connected. I hope you get what I mean by connected.
                                            The problem I face is if I try to select vertices in the front, the back are also selected and couldnt deselect it because its with the 'soft select radius', but those are not connected to the rest of the selection in front.
                                            Image shows what I mean
                                            vertex tools soft selection
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 33
                                            • 34
                                            • 21 / 34
