    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 608.7k Views 92 Watching
      that's VT 2. try VT 1.
      Extrude and then type value for length. boom...snaps back to origin
        Ah... forgot about that. Been using the dev version of VT2 for so long...
        • BoxB Offline
          I must admit that has be annoying me for ages and I thought I was either being stupid or there was a glitch in my setup.
            Sorry about that. I really need to get VT2 ready. Still working on the feature-set though.
            • HieruH Offline
              Hieru
              Rich hit the nail on the head...that's exactly what I was talking about.
              Glad I'm not the only one Box πŸ‘
              As long as it's in the pipeline and it's not down to me being dumb then I'm happy to wait for the next version....no rush Thomas πŸ˜‰ .
              www.davidhier.co.uk
                cuttingedge
                Hi thomthom,
                Ive been wanting to ask you this question.
                I think the soft selection of Vertex tools is awesome. The only thing is, Can we set the soft selection to select only neighbor vertices (within the specified radius) that are connected. I hope you get what I mean by connected.
                The problem I face is if I try to select vertices in the front, the back are also selected and couldnt deselect it because its with the 'soft select radius', but those are not connected to the rest of the selection in front.
                Image shows what I mean
                vertex tools soft selection
                  I know in VT2 Thom is tackling that issue. I requested an 'Only Connected' type fall-off to allow this type of manipulation.
                  • pbacotP Offline
                    Or "follow surface" so only points are soft-selected in a contiguous fashion from the selection
                      Yes - this is slated for V2 of VT.
                      • plot-parisP Offline
                        plot-paris
                        Hey Thomthom,
                        how's Version 2.0 coming along?
                        I have some questions concerning the new version's functionality:
                        1. Different Soft Selection Falloff-Curves
                        for the Soft Selection currently we are able to select between linear falloff and cosine falloff (soft on both ends). But sometimes different behaviors would be helpful, like soft on one end, hard on the other (exponential).
                        Even better (but increasingly complicated in terms of GUI) would be custom curves πŸ˜‰
                        2. Extrude Quad-Faces
                        when using the CTRL key to extrude surfaces, would it be possible to automatically turn the resulting surfaces into quad faces? That would help a lot when using SUbD πŸ˜„
                        3. Global vs Local Orientation of Gizmo
                        also it could be useful to have an option to orient the Manipulation Gizmo either globally (current behavior) or locally. Should all the selected vertices happen to lie on one plane, the gizmo could be oriented perpendicular to it.
                        Should the selection not be as simple... well, you'll figure something out πŸ˜‰
                        • cottyC Offline
                          cotty
                          You can change the orientation of te gizmo already with the right click context menu
                          my SketchUp gallery
                            Not all too much activity the last few months. During the summer I do less coding - trying to make use of the little "summer" we get in Norway.
                            The plan is to ship SUbD 2.0 with OpenSubdiv support. (it's not far from complete.) Then pick up Vertex Tools.
                            I've been thinking of something like adding a UI that let you control the falloff using bezier curves. Something similar to what 3dsmax do.
                            I'm not sure I follow on this one - extruded edges are all planar faces, right?
                            I like that idea - orient to the best fit plane. πŸ‘ πŸ‘
                              cuttingedge
                              HI Thomthom,
                              May I wish the ability to make planar along say x , y or z based on the active gizmo.
                              I always had problem mirroring when the vertices are not in their perfect x,y or z.
                                Use gizmo-scale to zero?
                                  cuttingedge
                                  I hope I could made my point clearer. At some point whenever modeling more complicated models, somehow
                                  the models gets messed up so i need to cut the half and mirror from the center to make it whole again.
                                  But to successfully mirror it, vertices need to be coplanar and need to be at least in perfect alignment with an axis, say x or y.
                                  Whenever I run "make planar". Vertices get aligned for sure but not in a defined axis (x or y)
                                  Maybe there is something I am not doing correctly.
                                  make planar
                                    Select the verts you want planar and use the Gizmo scale handle to make them planar in the axis of choice.
                                    Just be sure to hit 0 and enter after dragging the handle to scale them planar.
                                      In VT2 the scale will stop at 0 - making it easier.
                                        Ah...VT2.
                                        #waitingpatientlyforthat
                                          Pherim
                                          @escapeartist said:
                                          Great looking plugin!
                                          May I make a suggestion that may provide additional usefulness to the plugin? I have no idea how easy it would be to implement, I don't know darn thing about Ruby. How about different profiles or wave forms used to calculate the shape of the deflection? I notice that the deflection when push/pulled is very smooth, but would it be possible to get different results by selecting a "profie shape", changing the rate and direction (positive or negative displacement) of deflection change across distance selected? Pictures:
                                          [attachment=0:2jjdgjng]<!-- ia0 -->profiles.jpg<!-- ia0 -->[/attachment:2jjdgjng]
                                          Possible? Not worth it?
                                          (Original Post)
                                          As this post is now six years old and it looks like there are still only two choices for this (linear and cosine), will this possibly be added at some point? It would be great to be able to manipulate the curve myself, but the pinched shape from the image would already be a wonderful addition. I am thinking about buying the plugin and this would certainly have an impact on my decision. πŸ˜‰
                                            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=29636%26amp;p=600137#p599939 πŸ˜„
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 33
                                            • 34
                                            • 21 / 34
