    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
    • pbacotP
      I mean I when I move it, after picking the direction, I want to be able to pick a point (most likely at the center of the selection) then move it relative to (inference) another point on the model, sort of a target point. Often it's not for exact lineup but for some frame of reference for the move. (Sometimes I do move single points with it. Maybe there's no point using it for that?)
      • panixiaP
        panixia
        @pbacot said:
        I often default to the simple point move tool to do that. Am I missing something?
        maybe you are missing that if you activate the move tool with soft selection turned on, it does exactly what you are asking for πŸ‘
        or pheraps i did'nt 100% understand your point..
        • sicksickisckS
          sicksickisck
          my works with vertex tool [and tgi3d and fredo monster tools 🀣 πŸ‘Š ]
          https://www.artstation.com/artwork/staff-001-modules-concept-artof-ancient-space
          some progress..
          https://www.artstation.com/artwork/infiltrator_art2
          vertex tool is very very useful tool,, so far, for me πŸŽ‰
            some progress..
            That looks amazing! Loving the Infiltrator!
            • panixiaP
              panixia
              impressive.
              • B
                bsfranza
                hi there,
                just wantet to state a feature request for vertex tools πŸ˜ƒ
                how about the option to merge vertices to a designated spot/selected vertice? that would really help!
                thanks
                • panixiaP
                  panixia
                  i'm pretty much sure Thom WILL add it in the next version. along with some other really cool features.. πŸ˜›
                    Indeed - future release of Vertex Tools will have such a feature. πŸ˜„
                    • B
                      bsfranza
                      πŸ˜ƒ nice to hear - now i wish you for the next year the time to implement and release - may the sales be with you!
                      • Bob JamesB
                        Bob James
                        Are you using human or geological frame of time? 😎 πŸ˜†
                        • C
                          cuttingedge
                          Thomas, can we chamfer a vertex? or vertices at the same time with some given parameters as in max?
                            At the moment no - but I'm working on version 2.
                            However, it's been a while since I used Max - do you have some visuals of what this feature looks like? GIF?
                              rv1974
                              thomthom, please add edge extrude (with option for negative values).
                                rv1974
                                http://www.polyboost.com/features_modelling.htm
                                Here you've got endless source for inspiration. They were bought out by AD and became 'graphite tools' inside 3ds Max. The amount of work is huge so I guess you should cooperate with Fredo and found start-up for porting Polyboost set to SU πŸ˜„
                                • C
                                  cuttingedge
                                  @thomthom said:
                                  This is a screen shot of two of the other things to do with vertex-
                                  Chamfer (or offset if no value to chamfer) and Extrude.
                                  vertex edit
                                  Not for any particular model in mind at the moment but I just like the ability to control vertices with some common parameters to play with. By playing around sometimes inspiration comes!
                                  I dont know if this is something in your immediate plans.
                                  Do you plan to include inset?. I dont know if it falls under the category of vertex though.
                                  • HieruH
                                    Hieru
                                    Am I right in thinking that you should be able to enter a relative value when extruding?
                                    Just trying to figure out if I'm misremembering this function or if another plugin is causing a conflict.
                                    www.davidhier.co.uk
                                      What do you mean by relative value? And what are you observing?
                                        I'd imagine what David is mentioning is that VCB input after CTRL+Drag returns the selected extrusion to it's origin.
                                            that's VT 2. try VT 1.
                                            Extrude and then type value for length. boom...snaps back to origin
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 33
                                            • 34
                                            • 21 / 34
