    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
      @Thomthom
      Screen grab with PicPick. It has option to grab only the workspace. Or ShareX can do it and send it on image hosting site in one click.
      That's how I typically do it. Unless I'm missing a setting somewhere too?
      @Dave
      Presto AO is the GPU engine that Thea Render uses. It is very fast and integrates with SketchUp seamlessly. You can render directly in the SketchUp viewport which is a massive advantage.
      • garydornG
        garydorn
        @thomthom said:
        @garydorn said:
        Is SubD something that could be used to smooth out and simplify the surface better than what I've modelled so far. - some of my surfaces are still too dimply.
        Car modelling has been my main interest for QFT and SUbD. You can see a test model in the beginning of this thread: http://sketchucation.com/forums/viewtopic.php?f=397%26amp;t=63826#p584865
        That car you got there would be really fun to model. I've been thinking that I want to model a rounder car like that. (Was thinking Cobra is similar.)
        The AC Aceca is the coupe version of the AC ace, which was the basis of the ac/shelby cobra 260/289 ( ac ace with flared wheel arch ) which became the large flared 427 cobra.
        I working on a AC 260/289 body version - the curves are quite challenging to get visually right.
        ac ace
        cobra body in progress
        • massimoM
          massimo Moderator
          @thomthom said:
          I used that, but when clicking save it omitted the edges...
          You have to pick "SketchUp image" in the "save as" drop-down menu.
          I have an older version of the plugin installed atm so I don't know if something has changed.
          @ntxdave said:
          @rich o brien said:
          I find Presto AO to be best for quickies...
          Nice looking Rich. What is Presto AO?
          Presto is a hybrid CPU+GPU engine.
          Have a look here
            @box said:
            It makes such lovely surfaces for rendering.
            • JQLJ
              JQL
              @thomthom said:
              Hey, how do you guys save out the renders with the wireframe? After doing a Thea render in the viewport with edges and saving it the edges where omitted. (I'm digging up all my ol' render licenses...)
              You have to save "Sketchup Image(*.png)" on the image file options... If you want to render at a different resolution from your screen you have to separate your renders and do a non interactive render. Then, saving sketchup image will export the sketchup image as a png at the render resolution instead of screen resolution so you can easily blend in an image editor.
              www.casca.pt
              Visit us on facebook!
              • JQLJ
                JQL
                Sorry Massimo, missed your post...
                www.casca.pt
                • BoxB
                  • ntxdaveN
                    ntxdave
                    @Box that is some really nice rendering of those parts. I assume they were done with Thea. Is that true?
                    You guys make me feel really jealous. I wish I could come up with stuff that looked like that. I am wondering how some of my car wash equipment would look if rendered like that.
                    Something else for me to go try to learn............although I am learning, I am still struggling a little with the quad stuff. I think I am going to give up on trying to write my intro for beginners because I am still trying to learn how to use the tools correctly.
                    Press F1...thank me later
                      Here's a quick and dirty example by just opening your file and replacing some of the materials with the standard Thea materials. Other other work done.
                      • ntxdaveN
                        ntxdave
                        Boy - I really like that. A couple of things:
                        Should I download the trial version of Thea for SketchUp or the version that I can use "kid of forever" but not for commercial purposes? Is the trial 30 days?
                        I put that silly part in the glass jar just to see the transparency. I was not able to figure out how to put a liquid in the jar (which is what I really wanted to do).
                        What adjustments did you make to the drawing itself.
                        I appreciate you guys putting up with me trying to learn how to do this stuff however, as was mentioned earlier in this thread, maybe some of the "how to" and mentoring discussions should be in a separate thread so as not to dilute the original topic of the thread. I am sure there are others in my category who want to learn. I do not want to be a pain in the rear. I am really enjoying this though.
                        @Rich is there a way to have that kind of quality/rendering in Edg3d?
                        • BoxB
                          @ntxdave said:
                          @Box I assume they were done with Thea. Is that true?
                          No, it's the Hobby version of Twilight.
                          • L
                            leminilab
                            I love modelling now!
                            A couple of things really transformed my approach: Vertex Tools, Quadface Tools and Subd of course!
                            But not only. I recently saw this tutorial by Claas Kuhnen and it really made me understand a lot:
                            https://www.youtube.com/watch?v=nKzxUSjZNds
                            I hope it can help someone else as it did for me!
                            I wish SubD could have a toggle on/off for an entire model or having control over the level of detail on selected objects (<-this is the worst sentence I've ever written I think... Tall me if you really didn't understand...πŸ˜„.
                            Again, thanks a lot for these wonderful add-ons!
                            Nicolas
                            eames wire-proxy.skp
                            • "Live every day as if it were your last and then some day you'll be right."
                            • "ThomThom rules!!!"
                              Yes! This is high up on the list for next release. Multiple selected objects - and I was going to explore allowing groups containing SUbD instances as well to propagate the toggle.
                                Love this Eames model by the way! In my previous job I battled this chair so many times when the architects wanted to add it to their models - grabbing the super-high-poly from the manufacturer's website including all the screws and their threadding. sigh
                                This SUbD version would have saved me so much grief when populating a large model.
                                I'm adding a screenshot of the wireframe here cause it'd wonderfully simplistic.
                                Thanks for sharing that video as well. I got a collection of external links/videos for reference material that I'll be adding to the website.
                                  [edg3d:1jrvm4kp]6dOQrvWoC7Uy1vP[/edg3d:1jrvm4kp]
                                  • L
                                    leminilab
                                    This would be awesome!
                                    In a group, if you have models with different level of details (some at 1 level of subdiv, others at 2 or 3), would the each model's lOD be retained?
                                    But then maybe it would be nice to have an option to apply the same level of detail to all the models within a group...
                                    Well, let me say it again: I already thank you a lot for all your hard work on this: it's really appreciated! πŸ˜„
                                    • BoxB
                                      For those few of you that aren't bored with my doodles. Here's a very fast nose to play with.
                                      Nose.skp
                                      • ntxdaveN
                                        ntxdave
                                        I downloaded the model and, to me, it represents the real key for those of us trying to learn quad modeling. You need to be able to visualize what you are drawing in basic quad configuration. I think your other drawing of a person where you show the steps from just boxes to the eventual shape of the person are the real keys. You can learn to use the tools but if you cannot "see" where you are going, you are going to struggle immensely.
                                        Thanks for sharing this.
                                          Keep'em coming! Loving these models! πŸ˜„
                                          • garydornG
                                            garydorn
                                            I'd agree with you on this, begin able to see where the lines ought to go is a significant ability that will enable the simplest number of quads to produce the desired result.
                                            In my efforts so far, I seem to be modelling the full complexity of the shape, adjusting the vertexes, then retracing over with less lines, and deleting the now redundant lines/quads.
                                            I also wandering whether zorro might be a way of generating some the grid lines?
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 83
                                            • 84
                                            • 18 / 84
