[Plugin] FredoTools - v4.5c - 24 Jun 24
NEW RELEASE: FredoTools v2.5b - 18 Jan 15
FredoTools 2.5b is a small update fixing a few bugs in release v2.5a which was for ElementStats.
Note: version 2.5 (a and b) requires to install LibFredo6 v6.6
NEW RELEASE: FredoTools v2.5c - 19 Jan 15
FredoTools 2.5c fixes a major bug for SU8 (and SU6, SU7) preventing ElementStats from working properly.
Note: version 2.5 (a, b and c) requires to install LibFredo6 v6.6
Hello Fredo Thank you for the great work
All Other Translations following soon.
Roland F. SwissTranslatet by Hand very carefully
Please Do not put my name into the plugins There is only space for the Author (Your name)
Save any Space for drawing.FredoTools 2.5a
Feeling kind of dumb here but I can't see how to select both the front and back faces of an object while using ThruPaint. Most useful tool by the way.
KrisM -
If you mean painting both front and back faces at once then
Okay, fixed. The options bar wasn't showing up because it was behind a floating toolbar.
KrisM -
NEW RELEASE: FredoTools v2.6a - 25 Feb 15
FredoTools 2.6a is a release for
- FredoTools::AutoReverseFaces, which automatically align the orientation of faces in pseudo-solids
- FredoTools::Convexify, which performs the Convex decomposition of 3D shapes
Note: it requires to install LibFredo6 v6.7a
hi how to fix the problem with thrupaint. its says more than 4 edges.
It would be helpful if you could give some useful information about your model. Perhaps you could post an example that shows the problem. Or at least some screen shots.
Most probably you've tried to apply a texture on surfaces which have more than 4 edges using the "Quadmesh UV" method. Try again by choosing a different method.
NEW RELEASE: FredoTools v2.7a - 26 Apr 15
FredoTools 2.7a is a release for FredoTools::SolidVolume, which computes the volume of solids in the selection. This is an initial rudimentary version.
Thanks Fredo
NEW RELEASE: FredoTools v2.7c - 27 Apr 15
FredoTools 2.7c is a release for FredoTools::SolidVolume v1.1b, which computes the volume and faces area of solids in the selection. In this second version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner.
Now it works perfect!
It seems not so perfect. There is a problem when dealing with small faces I guess. Here is the example. Group is a solid, lines are ortho. Geometry is OK. The only thing is there is a small misalignment between the faces. But it could be made on purpose...To fix it I just moved one of the faces to meet another and erased the line, which made volume ok.
Thanks for signaling.
This is actually not related to small faces.I will republsih soon with the fix
NEW RELEASE: FredoTools v2.7d - 28 Apr 15
FredoTools 2.7d is a release for FredoTools::SolidVolume v1.1c, which computes the volume and faces area of solids in the selection. In this third version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner. I also fixed bugs in the calculation of volumes.
Should this appear in your update log?
This should be OK now.
Looks to be operating properly now. Thank you.
