    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.8k Views 122 Watching
    • fredo6F
      NEW RELEASE: FredoTools v2.5a - 10 Jan 15
      FredoTools 2.5a is a release for ElementStats v1.0, which is a small tool to display statistiscs about entities in the model in an interactive way.
      [flash=640,480:sirs851j]http://www.youtube.com/v/46IcCUqVf0c&hl[/flash:sirs851j]
      Note: it requires to install LibFredo6 v6.6a
      • cottyC
        cotty
        Thank you for another great addition to your toolbox!
        my SketchUp gallery
        • JClementsJ
          JClements
          Another home run.
          Great for serious modelers and newbies alike. Super great for SU training instructors and plugin demonstrations.
          • OxerO
            Oxer
            Thanks for this new update!! 👍
            Spanish Language Fredo Tools v2.5a
            FredoTools_ES.lang.zip
            • fredo6F
              NEW RELEASE: FredoTools v2.5b - 18 Jan 15
              FredoTools 2.5b is a small update fixing a few bugs in release v2.5a which was for ElementStats.
              Note: version 2.5 (a and b) requires to install LibFredo6 v6.6
              • fredo6F
                NEW RELEASE: FredoTools v2.5c - 19 Jan 15
                FredoTools 2.5c fixes a major bug for SU8 (and SU6, SU7) preventing ElementStats from working properly.
                Note: version 2.5 (a, b and c) requires to install LibFredo6 v6.6
                  schnydix
                  Hello Fredo Thank you for the great work
                  All Other Translations following soon.
                  Roland F. Swiss
                  Translatet by Hand very carefully
                  Please Do not put my name into the plugins There is only space for the Author (Your name)
                  Save any Space for drawing.
                  FredoTools 2.5a
                  LibFredo6_DE.zip
                  SUClock_DE.zip
                  RoundCorner_DE.zip
                  HoverSelect_DE.zip
                  FredoTools_DE.zip
                  JointPushPull_DE.zip
                  ToolsOnSurface_DE.zip
                  • K
                    KrisM
                    Feeling kind of dumb here but I can't see how to select both the front and back faces of an object while using ThruPaint. Most useful tool by the way.
                    KrisM
                    • massimoM
                      massimo Moderator
                      If you mean painting both front and back faces at once then
                      • K
                        KrisM
                        Okay, fixed. The options bar wasn't showing up because it was behind a floating toolbar.
                        KrisM
                        • fredo6F
                          NEW RELEASE: FredoTools v2.6a - 25 Feb 15
                          FredoTools 2.6a is a release for
                          • FredoTools::AutoReverseFaces, which automatically align the orientation of faces in pseudo-solids
                          • FredoTools::Convexify, which performs the Convex decomposition of 3D shapes
                          Note: it requires to install LibFredo6 v6.7a
                          • H
                            hajasulthan
                            hi how to fix the problem with thrupaint. its says more than 4 edges.
                              It would be helpful if you could give some useful information about your model. Perhaps you could post an example that shows the problem. Or at least some screen shots.
                              • massimoM
                                massimo Moderator
                                Most probably you've tried to apply a texture on surfaces which have more than 4 edges using the "Quadmesh UV" method. Try again by choosing a different method.
                                • fredo6F
                                  NEW RELEASE: FredoTools v2.7a - 26 Apr 15
                                  FredoTools 2.7a is a release for FredoTools::SolidVolume, which computes the volume of solids in the selection. This is an initial rudimentary version.
                                    Thanks Fredo
                                    • fredo6F
                                      NEW RELEASE: FredoTools v2.7c - 27 Apr 15
                                      FredoTools 2.7c is a release for FredoTools::SolidVolume v1.1b, which computes the volume and faces area of solids in the selection. In this second version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner.
                                      • srxS
                                        srx
                                        Now it works perfect! 👍
                                        www.saurus.rs
                                        • srxS
                                          srx
                                          😕 It seems not so perfect. There is a problem when dealing with small faces I guess. Here is the example. Group is a solid, lines are ortho. Geometry is OK. The only thing is there is a small misalignment between the faces. But it could be made on purpose...To fix it I just moved one of the faces to meet another and erased the line, which made volume ok.
                                          Example of wrong volume 2.skp
                                          www.saurus.rs
                                          • fredo6F
                                            Thanks for signaling.
                                            This is actually not related to small faces.
                                            I will republsih soon with the fix
                                            • 11
                                            • 12
                                            • 13
                                            • 23
                                            • 24
                                            • 11 / 24
