    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 836.5k Views 121 Watching
      @hajasulthan said:
      hi how to fix the problem with thrupaint. its says more than 4 edges.
      It would be helpful if you could give some useful information about your model. Perhaps you could post an example that shows the problem. Or at least some screen shots.
      • massimoM
        massimo Moderator
        Most probably you've tried to apply a texture on surfaces which have more than 4 edges using the "Quadmesh UV" method. Try again by choosing a different method.
        • fredo6F
          NEW RELEASE: FredoTools v2.7a - 26 Apr 15
          FredoTools 2.7a is a release for FredoTools::SolidVolume, which computes the volume of solids in the selection. This is an initial rudimentary version.
            Thanks Fredo
            • fredo6F
              NEW RELEASE: FredoTools v2.7c - 27 Apr 15
              FredoTools 2.7c is a release for FredoTools::SolidVolume v1.1b, which computes the volume and faces area of solids in the selection. In this second version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner.
              • srxS
                srx
                Now it works perfect! 👍
                www.saurus.rs
                • srxS
                  srx
                  😕 It seems not so perfect. There is a problem when dealing with small faces I guess. Here is the example. Group is a solid, lines are ortho. Geometry is OK. The only thing is there is a small misalignment between the faces. But it could be made on purpose...To fix it I just moved one of the faces to meet another and erased the line, which made volume ok.
                  Example of wrong volume 2.skp
                  www.saurus.rs
                  • fredo6F
                    Thanks for signaling.
                    This is actually not related to small faces.
                    I will republsih soon with the fix
                    • fredo6F
                      NEW RELEASE: FredoTools v2.7d - 28 Apr 15
                      FredoTools 2.7d is a release for FredoTools::SolidVolume v1.1c, which computes the volume and faces area of solids in the selection. In this third version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner. I also fixed bugs in the calculation of volumes.
                      • JClementsJ
                        JClements
                        Should this appear in your update log?
                        Fredo Update Log
                        • fredo6F
                          This should be OK now.
                          • JClementsJ
                            JClements
                            Looks to be operating properly now. Thank you.
                            • fredo6F
                              NEW RELEASE: FredoTools v2.7e - 29 Apr 15
                              FredoTools 2.7e is a release for FredoTools::SolidVolume v1.1d, which computes the volume and faces area of solids in the selection. This fourth version includes a fix for the correct display of the main dialog box.
                              • P
                                ptma2008
                                thank you
                                  arquimecho
                                  great plugin, complete and really functional
                                  • fredo6F
                                    NEW RELEASE: FredoTools v2.8a - 09 Jul 15
                                    FredoTools 2.8a is a minor release for:
                                    • SolidVolume, which now accepts solids with holes
                                    • ReportLabelArea, which now computes the correct area removing the space taken by the glued componentss in cut opening mode.
                                    • fredo6F
                                      Warning:
                                      Please upgrade to LibFredo6 6.8c if you installed FredoTools v2.8.
                                      There is a bug in FredoTools::Convexify, which is fixed in LibFredo6 v6.8c.
                                      Sorry for inconvenience
                                      Fred
                                      • pbacotP
                                        Thanks Fredo!
                                        • E
                                          elvirem
                                          Hello Fredo, je viens de passer sur skp 2015. J etais sur 2008 et tout allait bien et voici ce qui m'arrive malgré pas mal de tentatives.. ça fait 15 jours que c'est comme ça... et moi SKP sans libfredo, c'est comme si on me coupait un bras...tu saurais ce que je pourrais faire pour telecharger ton plugin et qu il fonctionne ? je suis sous mac yosemite ( non de Dieu que Mavericks me manque!!!)
                                          Merci de tes lumières.... si tu en as !
                                          Elvirem
                                          Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                                          Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                          /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:716:in match' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:716:in block (2 levels) in load_from_config'
                                          /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:715:in each' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:715:in block in load_from_config'
                                          /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:713:in foreach' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:713:in load_from_config'
                                          /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in block in load_all_plugins' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in each'
                                          /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in load_all_plugins' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:786:in load_from_config'
                                          /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:in startup' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:338:in module:LibFredo6'
                                          /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in <top (required)>' `
                                          • B
                                            BIANI patrick
                                            Where downloading Move along ???????
                                            • 11
                                            • 12
                                            • 13
                                            • 23
                                            • 24
                                            • 11 / 24
