    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.8k Views 122 Watching
    • massimoM
      massimo Moderator
      If you mean painting both front and back faces at once then
      • K
        KrisM
        Okay, fixed. The options bar wasn't showing up because it was behind a floating toolbar.
        KrisM
        • fredo6F
          NEW RELEASE: FredoTools v2.6a - 25 Feb 15
          FredoTools 2.6a is a release for
          • FredoTools::AutoReverseFaces, which automatically align the orientation of faces in pseudo-solids
          • FredoTools::Convexify, which performs the Convex decomposition of 3D shapes
          Note: it requires to install LibFredo6 v6.7a
          • H
            hajasulthan
            hi how to fix the problem with thrupaint. its says more than 4 edges.
              It would be helpful if you could give some useful information about your model. Perhaps you could post an example that shows the problem. Or at least some screen shots.
              • massimoM
                massimo Moderator
                Most probably you've tried to apply a texture on surfaces which have more than 4 edges using the "Quadmesh UV" method. Try again by choosing a different method.
                • fredo6F
                  NEW RELEASE: FredoTools v2.7a - 26 Apr 15
                  FredoTools 2.7a is a release for FredoTools::SolidVolume, which computes the volume of solids in the selection. This is an initial rudimentary version.
                    Thanks Fredo
                    • fredo6F
                      NEW RELEASE: FredoTools v2.7c - 27 Apr 15
                      FredoTools 2.7c is a release for FredoTools::SolidVolume v1.1b, which computes the volume and faces area of solids in the selection. In this second version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner.
                      • srxS
                        srx
                        Now it works perfect! 👍
                        www.saurus.rs
                        • srxS
                          srx
                          😕 It seems not so perfect. There is a problem when dealing with small faces I guess. Here is the example. Group is a solid, lines are ortho. Geometry is OK. The only thing is there is a small misalignment between the faces. But it could be made on purpose...To fix it I just moved one of the faces to meet another and erased the line, which made volume ok.
                          Example of wrong volume 2.skp
                          www.saurus.rs
                          • fredo6F
                            Thanks for signaling.
                            This is actually not related to small faces.
                            I will republsih soon with the fix
                            • fredo6F
                              NEW RELEASE: FredoTools v2.7d - 28 Apr 15
                              FredoTools 2.7d is a release for FredoTools::SolidVolume v1.1c, which computes the volume and faces area of solids in the selection. In this third version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner. I also fixed bugs in the calculation of volumes.
                              • JClementsJ
                                JClements
                                Should this appear in your update log?
                                Fredo Update Log
                                • fredo6F
                                  This should be OK now.
                                  • JClementsJ
                                    JClements
                                    Looks to be operating properly now. Thank you.
                                    • fredo6F
                                      NEW RELEASE: FredoTools v2.7e - 29 Apr 15
                                      FredoTools 2.7e is a release for FredoTools::SolidVolume v1.1d, which computes the volume and faces area of solids in the selection. This fourth version includes a fix for the correct display of the main dialog box.
                                      • P
                                        ptma2008
                                        thank you
                                          arquimecho
                                          great plugin, complete and really functional
                                          • fredo6F
                                            NEW RELEASE: FredoTools v2.8a - 09 Jul 15
                                            FredoTools 2.8a is a minor release for:
                                            • SolidVolume, which now accepts solids with holes
                                            • ReportLabelArea, which now computes the correct area removing the space taken by the glued componentss in cut opening mode.
                                            • 11
                                            • 12
                                            • 13
                                            • 23
                                            • 24
                                            • 11 / 24
