    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.8k Views 122 Watching
    • fredo6F
      NEW RELEASE: FredoTools v2.5b - 18 Jan 15
      FredoTools 2.5b is a small update fixing a few bugs in release v2.5a which was for ElementStats.
      Note: version 2.5 (a and b) requires to install LibFredo6 v6.6
      • fredo6F
        NEW RELEASE: FredoTools v2.5c - 19 Jan 15
        FredoTools 2.5c fixes a major bug for SU8 (and SU6, SU7) preventing ElementStats from working properly.
        Note: version 2.5 (a, b and c) requires to install LibFredo6 v6.6
          schnydix
          Hello Fredo Thank you for the great work
          All Other Translations following soon.
          Roland F. Swiss
          Translatet by Hand very carefully
          Please Do not put my name into the plugins There is only space for the Author (Your name)
          Save any Space for drawing.
          FredoTools 2.5a
          LibFredo6_DE.zip
          SUClock_DE.zip
          RoundCorner_DE.zip
          HoverSelect_DE.zip
          FredoTools_DE.zip
          JointPushPull_DE.zip
          ToolsOnSurface_DE.zip
          • K
            KrisM
            Feeling kind of dumb here but I can't see how to select both the front and back faces of an object while using ThruPaint. Most useful tool by the way.
            KrisM
            • massimoM
              massimo Moderator
              If you mean painting both front and back faces at once then
              • K
                KrisM
                Okay, fixed. The options bar wasn't showing up because it was behind a floating toolbar.
                KrisM
                • fredo6F
                  NEW RELEASE: FredoTools v2.6a - 25 Feb 15
                  FredoTools 2.6a is a release for
                  • FredoTools::AutoReverseFaces, which automatically align the orientation of faces in pseudo-solids
                  • FredoTools::Convexify, which performs the Convex decomposition of 3D shapes
                  Note: it requires to install LibFredo6 v6.7a
                  • H
                    hajasulthan
                    hi how to fix the problem with thrupaint. its says more than 4 edges.
                      It would be helpful if you could give some useful information about your model. Perhaps you could post an example that shows the problem. Or at least some screen shots.
                      • massimoM
                        massimo Moderator
                        Most probably you've tried to apply a texture on surfaces which have more than 4 edges using the "Quadmesh UV" method. Try again by choosing a different method.
                        • fredo6F
                          NEW RELEASE: FredoTools v2.7a - 26 Apr 15
                          FredoTools 2.7a is a release for FredoTools::SolidVolume, which computes the volume of solids in the selection. This is an initial rudimentary version.
                            Thanks Fredo
                            • fredo6F
                              NEW RELEASE: FredoTools v2.7c - 27 Apr 15
                              FredoTools 2.7c is a release for FredoTools::SolidVolume v1.1b, which computes the volume and faces area of solids in the selection. In this second version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner.
                              • srxS
                                srx
                                Now it works perfect! πŸ‘
                                www.saurus.rs
                                • srxS
                                  srx
                                  πŸ˜• It seems not so perfect. There is a problem when dealing with small faces I guess. Here is the example. Group is a solid, lines are ortho. Geometry is OK. The only thing is there is a small misalignment between the faces. But it could be made on purpose...To fix it I just moved one of the faces to meet another and erased the line, which made volume ok.
                                  Example of wrong volume 2.skp
                                  www.saurus.rs
                                  • fredo6F
                                    Thanks for signaling.
                                    This is actually not related to small faces.
                                    I will republsih soon with the fix
                                    • fredo6F
                                      NEW RELEASE: FredoTools v2.7d - 28 Apr 15
                                      FredoTools 2.7d is a release for FredoTools::SolidVolume v1.1c, which computes the volume and faces area of solids in the selection. In this third version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner. I also fixed bugs in the calculation of volumes.
                                      • JClementsJ
                                        JClements
                                        Should this appear in your update log?
                                        Fredo Update Log
                                        • fredo6F
                                          This should be OK now.
                                          • JClementsJ
                                            JClements
                                            Looks to be operating properly now. Thank you.
                                            • 11
                                            • 12
                                            • 13
                                            • 23
                                            • 24
                                            • 11 / 24
