    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 748.8k Views 121 Watching
    • JClementsJ Offline
      JClements
      Another home run.
      Great for serious modelers and newbies alike. Super great for SU training instructors and plugin demonstrations.
      • OxerO Offline
        Oxer
        Thanks for this new update!! 👍
        Spanish Language Fredo Tools v2.5a
        FredoTools_ES.lang.zip
        • fredo6F Offline
          NEW RELEASE: FredoTools v2.5b - 18 Jan 15
          FredoTools 2.5b is a small update fixing a few bugs in release v2.5a which was for ElementStats.
          Note: version 2.5 (a and b) requires to install LibFredo6 v6.6
          • fredo6F Offline
            NEW RELEASE: FredoTools v2.5c - 19 Jan 15
            FredoTools 2.5c fixes a major bug for SU8 (and SU6, SU7) preventing ElementStats from working properly.
            Note: version 2.5 (a, b and c) requires to install LibFredo6 v6.6
              schnydix
              Hello Fredo Thank you for the great work
              All Other Translations following soon.
              Roland F. Swiss
              Translatet by Hand very carefully
              Please Do not put my name into the plugins There is only space for the Author (Your name)
              Save any Space for drawing.
              FredoTools 2.5a
              LibFredo6_DE.zip
              SUClock_DE.zip
              RoundCorner_DE.zip
              HoverSelect_DE.zip
              FredoTools_DE.zip
              JointPushPull_DE.zip
              ToolsOnSurface_DE.zip
                KrisM
                Feeling kind of dumb here but I can't see how to select both the front and back faces of an object while using ThruPaint. Most useful tool by the way.
                KrisM
                • massimoM Offline
                  massimo Moderator
                  If you mean painting both front and back faces at once then
                    KrisM
                    Okay, fixed. The options bar wasn't showing up because it was behind a floating toolbar.
                    KrisM
                    • fredo6F Offline
                      NEW RELEASE: FredoTools v2.6a - 25 Feb 15
                      FredoTools 2.6a is a release for
                      • FredoTools::AutoReverseFaces, which automatically align the orientation of faces in pseudo-solids
                      • FredoTools::Convexify, which performs the Convex decomposition of 3D shapes
                      Note: it requires to install LibFredo6 v6.7a
                      • H Offline
                        hajasulthan
                        hi how to fix the problem with thrupaint. its says more than 4 edges.
                          It would be helpful if you could give some useful information about your model. Perhaps you could post an example that shows the problem. Or at least some screen shots.
                          • massimoM Offline
                            massimo Moderator
                            Most probably you've tried to apply a texture on surfaces which have more than 4 edges using the "Quadmesh UV" method. Try again by choosing a different method.
                            • fredo6F Offline
                              NEW RELEASE: FredoTools v2.7a - 26 Apr 15
                              FredoTools 2.7a is a release for FredoTools::SolidVolume, which computes the volume of solids in the selection. This is an initial rudimentary version.
                                Thanks Fredo
                                • fredo6F Offline
                                  NEW RELEASE: FredoTools v2.7c - 27 Apr 15
                                  FredoTools 2.7c is a release for FredoTools::SolidVolume v1.1b, which computes the volume and faces area of solids in the selection. In this second version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner.
                                  • srxS Offline
                                    srx
                                    Now it works perfect! 👍
                                    www.saurus.rs
                                    • srxS Offline
                                      srx
                                      😕 It seems not so perfect. There is a problem when dealing with small faces I guess. Here is the example. Group is a solid, lines are ortho. Geometry is OK. The only thing is there is a small misalignment between the faces. But it could be made on purpose...To fix it I just moved one of the faces to meet another and erased the line, which made volume ok.
                                      Example of wrong volume 2.skp
                                      www.saurus.rs
                                      • fredo6F Offline
                                        Thanks for signaling.
                                        This is actually not related to small faces.
                                        I will republsih soon with the fix
                                        • fredo6F Offline
                                          NEW RELEASE: FredoTools v2.7d - 28 Apr 15
                                          FredoTools 2.7d is a release for FredoTools::SolidVolume v1.1c, which computes the volume and faces area of solids in the selection. In this third version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner. I also fixed bugs in the calculation of volumes.
                                            JClements
                                            Should this appear in your update log?
                                            Fredo Update Log
                                            • 11
                                            • 12
                                            • 13
                                            • 23
                                            • 24
                                            • 11 / 24
