    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.8k Views 122 Watching
      Thanks Fredo
      • fredo6F
        NEW RELEASE: FredoTools v2.7c - 27 Apr 15
        FredoTools 2.7c is a release for FredoTools::SolidVolume v1.1b, which computes the volume and faces area of solids in the selection. In this second version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner.
        • srxS
          srx
          Now it works perfect! 👍
          www.saurus.rs
          • srxS
            srx
            😕 It seems not so perfect. There is a problem when dealing with small faces I guess. Here is the example. Group is a solid, lines are ortho. Geometry is OK. The only thing is there is a small misalignment between the faces. But it could be made on purpose...To fix it I just moved one of the faces to meet another and erased the line, which made volume ok.
            Example of wrong volume 2.skp
            www.saurus.rs
            • fredo6F
              Thanks for signaling.
              This is actually not related to small faces.
              I will republsih soon with the fix
              • fredo6F
                NEW RELEASE: FredoTools v2.7d - 28 Apr 15
                FredoTools 2.7d is a release for FredoTools::SolidVolume v1.1c, which computes the volume and faces area of solids in the selection. In this third version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner. I also fixed bugs in the calculation of volumes.
                • JClementsJ
                  JClements
                  Should this appear in your update log?
                  Fredo Update Log
                  • fredo6F
                    This should be OK now.
                    • JClementsJ
                      JClements
                      Looks to be operating properly now. Thank you.
                      • fredo6F
                        NEW RELEASE: FredoTools v2.7e - 29 Apr 15
                        FredoTools 2.7e is a release for FredoTools::SolidVolume v1.1d, which computes the volume and faces area of solids in the selection. This fourth version includes a fix for the correct display of the main dialog box.
                        • P
                          ptma2008
                          thank you
                            arquimecho
                            great plugin, complete and really functional
                            • fredo6F
                              NEW RELEASE: FredoTools v2.8a - 09 Jul 15
                              FredoTools 2.8a is a minor release for:
                              • SolidVolume, which now accepts solids with holes
                              • ReportLabelArea, which now computes the correct area removing the space taken by the glued componentss in cut opening mode.
                              • fredo6F
                                Warning:
                                Please upgrade to LibFredo6 6.8c if you installed FredoTools v2.8.
                                There is a bug in FredoTools::Convexify, which is fixed in LibFredo6 v6.8c.
                                Sorry for inconvenience
                                Fred
                                • pbacotP
                                  Thanks Fredo!
                                  • E
                                    elvirem
                                    Hello Fredo, je viens de passer sur skp 2015. J etais sur 2008 et tout allait bien et voici ce qui m'arrive malgré pas mal de tentatives.. ça fait 15 jours que c'est comme ça... et moi SKP sans libfredo, c'est comme si on me coupait un bras...tu saurais ce que je pourrais faire pour telecharger ton plugin et qu il fonctionne ? je suis sous mac yosemite ( non de Dieu que Mavericks me manque!!!)
                                    Merci de tes lumières.... si tu en as !
                                    Elvirem
                                    Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                                    Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                    /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:716:in match' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:716:in block (2 levels) in load_from_config'
                                    /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:715:in each' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:715:in block in load_from_config'
                                    /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:713:in foreach' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:713:in load_from_config'
                                    /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in block in load_all_plugins' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in each'
                                    /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in load_all_plugins' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:786:in load_from_config'
                                    /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:in startup' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:338:in module:LibFredo6'
                                    /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in <top (required)>' `
                                    • B
                                      BIANI patrick
                                      Where downloading Move along ???????
                                      • cottyC
                                        cotty
                                        It's part of this collection and you can download it at the first post or with the Plugin store.
                                        Make sure that you have installed LibFredo too.
                                        my SketchUp gallery
                                        • JClementsJ
                                          JClements
                                          VOLUME Calculator.
                                          I am getting a very large difference in calculated volumes between what SU displays in the Entity Info and what the volume calculator comes up with. I suspect it is due to a small sized object with many very small facets.
                                          Can I send you the model to look it over?
                                          Model created in SU2015, 64-bit. Windows 7.
                                          • fredo6F
                                            Yes. Please send the model.
                                            By the way, do you already know which result is the correct one?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 23
                                            • 24
                                            • 12 / 24
