[Plugin] Drop Vertices
Simon
DropVertices isn't Drape
Bonjour TIG
OK, I was confused on the concepts Drape/Drope.
I have discovered that the kind of subdivision is important. Until now I was trying to drape with some classical triangulated shapes and that's why the result wasn't working.
As I have seen with your example above it was possible, I have discovered that shapes must be subdivided by real tin subdivision.(as far)
(I see we can't obtain this way something like we can do with sandboxtool/Stamptool but with a 3D path.)
Anyway This DropVertices brings so much !!!!+++ Thank you one more time and bravo!! TIG
simon.
Here is another method to do what you are looking for Simon.
[flash=800,600:1yx2pldf]http://www.youtube.com/v/hzN5n2UB7Ao[/flash:1yx2pldf]
Dear Adam,
your videos are invaluable to understand easily how things work and as reminders.
I have watched your previous a number of times.I'm studying your propositions (soapskin&buble _ instant road (which makes the deal
) and I'm thinking to others. It's for tomorrow now.Cheers,
simon. -
Maybe use of Ferrari can also gives some cool results
oh .thank u verry much
but ruby SplitUp I can find where, who can help me, please
i saw on Youtube
http://www.youtu.be/watch?v=kAUx4AHVbOU&feature=related -
i saw on Youtube
http://www.youtu.be/watch?v=kAUx4AHVbOU&feature=relatedLike 'On Screen Rolling Reel' - 'SplitUp' has never been published.
It's in beta testing with a select group [Rich O'B].
The bugs are now ironed out... I'll speak with the other[s] to see what we should do next... -
Don't forget my NURBS plugin that's fairly stable. Just too powerful for mere mortals.
great plugin, used it to fix a f-ed up model
What did I wrong here?
Scant on what you've tried...
arcs/curves do not drop unless they are exploded first...
but see this example...
Here is v2.0 http://sketchucation.com/pluginstore?pln=dropverts It now overcomes the curve issue.
All edges in a dropped curve are now treated as separate edges. -
Thank you, nice update!
Does it possible to imagine a "drop" on X or Y direction ?
(sure I can rotate all before but...) -
Hi TIG,
I found that To Middle and To average do not work.
Console indicates that line 93z=z.to_s.to_l if zis faulty; cannot convert to length.
I changed it toz=z.to_f if z. (float) They now work.
Is this right ? -
(sure I can rotate all before but...)In this port are functions for the 3 axis.
I tried to stick to the actual extension standards.
Re-named it since it does more than just drop.
Added LanguageHandler, french. And a contextual menu for the most frequent ones I use.
Extension Errors Report
SketchUp: 26.2.242
OS: Tahoe
Ruby: 3.2.2Extension: [unknown]
Error: SyntaxError (/Users/maxos/Library/Application Support/SketchUp 2026/SketchUp/Plugins/ropverts.rb:1: syntax error, unexpected ':', expecting end-of-input
Why have you posted 6 almost identical posts about something - one will do.
And your post doesn't contain enough info for the error either.
You can copy the whole thing and post that - it'd include the error details, and even the line number ?
In you copy/paste it looks like you didn't get the file name right - it's dropverts.rb - you missed off the 'd' - or have you somehow mangled the file's name in reality within the Plugins folder ?
ALSO note that this script is 16 years old and no one has posted here for 10 years. So SketchUp versions and their Ruby installations can vary to generate errors for older scripts when loaded in newer SketchUp versions !
Having said that, I just loaded it into v2026 [PC] and it works fine - just as expected... So please be more helpful with your reporting, so we can help you... -
Extra removed.
