    [Plugin] Drop Vertices
    54 Posts 18 Posters 153.9k Views 18 Watching
      Maybe use of Ferrari can also gives some cool results πŸ˜‰
        ktslambieng
        oh .thank u verry much
        but ruby SplitUp I can find where, who can help me, please
        i saw on Youtube
        http://www.youtu.be/watch?v=kAUx4AHVbOU&feature=related
          i saw on Youtube
          Like 'On Screen Rolling Reel' - 'SplitUp' has never been published.
          It's in beta testing with a select group [Rich O'B].
          The bugs are now ironed out... I'll speak with the other[s] to see what we should do next...
            Don't forget my NURBS plugin that's fairly stable. Just too powerful for mere mortals.
            • peter_shawP Offline
              peter_shaw
              great plugin, used it to fix a f-ed up model
              • cottyC Offline
                cotty
                What did I wrong here?
                klick image
                my SketchUp gallery
                  Scant on what you've tried...
                  arcs/curves do not drop unless they are exploded first...
                  but see this example...
                    Here is v2.0 http://sketchucation.com/pluginstore?pln=dropverts It now overcomes the curve issue.
                    All edges in a dropped curve are now treated as separate edges.
                    • cottyC Offline
                      cotty
                      Thank you, nice update!
                      my SketchUp gallery
                        Does it possible to imagine a "drop" on X or Y direction ?
                        (sure I can rotate all before but...)
                        • mariochaM Offline
                          mariocha
                          Hi TIG,
                          I found that To Middle and To average do not work.
                          Console indicates that line 93 z=z.to_s.to_l if z is faulty; cannot convert to length.
                          I changed it to z=z.to_f if z . (float) They now work.
                          Is this right ?
                          %(#008000)[Mario C.
                          • mariochaM Offline
                            mariocha
                            In this port are functions for the 3 axis.
                            I tried to stick to the actual extension standards.
                            Re-named it since it does more than just drop.
                            Added LanguageHandler, french. And a contextual menu for the most frequent ones I use.
                            Mc-AlignEnds.rbz
                            %(#008000)[Mario C.
                              maxosmedia
                              Extension Errors Report
                              SketchUp: 26.2.242
                              OS: Tahoe
                              Ruby: 3.2.2
                              Extension: [unknown]
                              Error: SyntaxError (/Users/maxos/Library/Application Support/SketchUp 2026/SketchUp/Plugins/ropverts.rb:1: syntax error, unexpected ':', expecting end-of-input
                                @maxosmedia
                                Why have you posted 6 almost identical posts about something - one will do.
                                And your post doesn't contain enough info for the error either.
                                You can copy the whole thing and post that - it'd include the error details, and even the line number ?
                                In you copy/paste it looks like you didn't get the file name right - it's dropverts.rb - you missed off the 'd' - or have you somehow mangled the file's name in reality within the Plugins folder ?
                                ALSO note that this script is 16 years old and no one has posted here for 10 years. So SketchUp versions and their Ruby installations can vary to generate errors for older scripts when loaded in newer SketchUp versions !
                                Having said that, I just loaded it into v2026 [PC] and it works fine - just as expected... So please be more helpful with your reporting, so we can help you...
                                  @tig
                                  Extra removed.
                                  • 3 / 3
