    [Plugin] Drop Vertices
    54 Posts 18 Posters 153.0k Views 18 Watching
    • EarthMoverE Offline
      EarthMover
      Here is another method to do what you are looking for Simon.
      [flash=800,600:1yx2pldf]http://www.youtube.com/v/hzN5n2UB7Ao[/flash:1yx2pldf]
      Content Creator at Skapeup
      • simon le bonS Offline
        simon le bon
        Dear Adam,
        your videos are invaluable to understand easily how things work and as reminders.
        I have watched your previous a number of times.
        I'm studying your propositions (soapskin&buble _ instant road (which makes the deal πŸ‘ πŸ‘ ) and I'm thinking to others. It's for tomorrow now.
        Cheers,
           simon.
          Maybe use of Ferrari can also gives some cool results πŸ˜‰
            ktslambieng
            oh .thank u verry much
            but ruby SplitUp I can find where, who can help me, please
            i saw on Youtube
            http://www.youtu.be/watch?v=kAUx4AHVbOU&feature=related
              i saw on Youtube
              Like 'On Screen Rolling Reel' - 'SplitUp' has never been published.
              It's in beta testing with a select group [Rich O'B].
              The bugs are now ironed out... I'll speak with the other[s] to see what we should do next...
                Don't forget my NURBS plugin that's fairly stable. Just too powerful for mere mortals.
                • peter_shawP Offline
                  peter_shaw
                  great plugin, used it to fix a f-ed up model
                  • cottyC Offline
                    cotty
                    What did I wrong here?
                    klick image
                    my SketchUp gallery
                      Scant on what you've tried...
                      arcs/curves do not drop unless they are exploded first...
                      but see this example...
                        Here is v2.0 http://sketchucation.com/pluginstore?pln=dropverts It now overcomes the curve issue.
                        All edges in a dropped curve are now treated as separate edges.
                        • cottyC Offline
                          cotty
                          Thank you, nice update!
                          my SketchUp gallery
                            Does it possible to imagine a "drop" on X or Y direction ?
                            (sure I can rotate all before but...)
                            • mariochaM Offline
                              mariocha
                              Hi TIG,
                              I found that To Middle and To average do not work.
                              Console indicates that line 93 z=z.to_s.to_l if z is faulty; cannot convert to length.
                              I changed it to z=z.to_f if z . (float) They now work.
                              Is this right ?
                              %(#008000)[Mario C.
                              • mariochaM Offline
                                mariocha
                                In this port are functions for the 3 axis.
                                I tried to stick to the actual extension standards.
                                Re-named it since it does more than just drop.
                                Added LanguageHandler, french. And a contextual menu for the most frequent ones I use.
                                Mc-AlignEnds.rbz
                                %(#008000)[Mario C.
                                  maxosmedia
                                  Extension Errors Report
                                  SketchUp: 26.2.242
                                  OS: Tahoe
                                  Ruby: 3.2.2
                                  Extension: [unknown]
                                  Error: SyntaxError (/Users/maxos/Library/Application Support/SketchUp 2026/SketchUp/Plugins/ropverts.rb:1: syntax error, unexpected ':', expecting end-of-input
                                    @maxosmedia
                                    Why have you posted 6 almost identical posts about something - one will do.
                                    And your post doesn't contain enough info for the error either.
                                    You can copy the whole thing and post that - it'd include the error details, and even the line number ?
                                    In you copy/paste it looks like you didn't get the file name right - it's dropverts.rb - you missed off the 'd' - or have you somehow mangled the file's name in reality within the Plugins folder ?
                                    ALSO note that this script is 16 years old and no one has posted here for 10 years. So SketchUp versions and their Ruby installations can vary to generate errors for older scripts when loaded in newer SketchUp versions !
                                    Having said that, I just loaded it into v2026 [PC] and it works fine - just as expected... So please be more helpful with your reporting, so we can help you...
                                      @tig
                                      Extra removed.
                                      • 3 / 3
