    Power Toolbar (2.5) - fix for 2019
    78 Posts 39 Posters 134.3k Views 39 Watching
    • O
      optimaforever
      1001 x thanks!
      Since I updated to 2015, I was VERY frustrated the PTB wasn't working anymore...
      Simple tools like extrudealongpath, pipealongpath, extrudelines, mirror, dropintersection, protrude were really essential in my workflow and crawling through the menus to find them was really a pain...
      My brain is already overcrowded with shortcut keys of photoshop, 3dsmax, aftereffects, sketchup, etc. that I feel very relieved when sometimes there are simply but brilliantly designed icons to click on 😄
      • P
        Pherim
        Very nice, thank you!
        Just a minor issue: On my Laptop I have the screen resolution 1366x768 (a little low for Sketchup, I know, but right now I don't have access to my desktop pc with the FullHD screen) and in the customization menu the two lowest lines are not visible. Any chance of a scrollbar or a more horizontal alignment of the icons (I think 15/15/14 would make sense)?
        • CadFatherC
          CadFather
          Bob, fairly sure you haven't really uninstalled it somehow. try it manually, there are only 2 files: _jhs01_powerbar.rb and the jhs folder. delete them and reinstall
          Anton, it was titanic (in the greek sense of the word). for the main part i didn't go out of the house for 8 solid days, or talk to anyone for that matter 😄 . in fact there's a big chunk of my own coding on this one, (by grace of all the pastas i was being nurtured with). 😄
          Pherim, check the fix on first post, should be good with 1366x768.
          Thanks all, good to hear you like it.
          • Bob JamesB
            Bob James
            Did that. Three times. Loaded it three ways: Importing rbz, opening the rbz with WinZip and extracting the files, and Plugin Store. Also, only used the standard plugin folder so no duplication in two locations.
            Must just be having a bad hair day
            • P
              Pherim
              It looks different for me... the first icon in the middle column is Comps to Grid Array and even when maximized, the lowest row of icons is only visible when I enable automatic taskbar hiding. Not a big issue, certainly, but a little annoying.
              • CadFatherC
                CadFather
                Bob, are you sure you have no file or folder named jhs anywhere? never happened before.
                Pherim, strange sounding - the new fix sets the window at 650 vertical, so that should not occur.
                it should look like above image: first icon on second column being 'center to red'.
                  it's nice max!
                  now get back to the guitar...
                  • CadFatherC
                    CadFather
                    ...don't tempt me, mate! 😆
                    • P
                      Pherim
                      Oh, alright, I didn't realize I had to re-install it... It was not marked as updated. After re-installing, it works, thank you!
                      • doppelD
                        doppel
                        Thank you for this fantastic job! I will try it right now!
                        • CadFatherC
                          CadFather
                          told of a bug in the menus - fix coming soon.
                          • ntxdaveN
                            ntxdave
                            Does installing the toolbar also install all of the related plugins?
                            Press F1...thank me later
                            • B
                              bsfranza
                              awesome collection and coding 😃 great - hope you keep having fun with maintaining and expanding this
                              • KrisidiousK
                                Krisidious
                                I missed it... Glorious.
                                By: Kristoff Rand
                                • onzkiO
                                  onzki
                                  Hi, Thanks for sharing this amazing plugins, I installed it via Sketchucation Store (Autoinstall)but how come mine seems lacking? Do I need to uninstall old plugins first? Please see attached screenshot. Thanks!
                                  [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                                  • P
                                    pipinek
                                    Greetings,
                                    Is the current version 2.3 compatible with SU 2016?
                                    Many thanks
                                      Sam3D
                                      Por favor nao consigo instalar, aparece erro! Já fiz todo o processo, meu windows 8!
                                      Me ajude!!!!!
                                      Error Loading File C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb
                                      Error: No such file or directory - C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_pb.strings
                                      C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:19:in readlines' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:19:in module:Max_Coppoletta'
                                      C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:6:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
                                      C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:16:in register_extension'
                                      C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:16:in <module:JHS_powerbar>' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:8:in module:Max_Coppoletta'
                                      C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:7:in `<top (required)>'
                                      • deaneauD
                                        deaneau
                                        pictures tell more than 1000 words 😉
                                        • HornOxxH
                                          HornOxx
                                          Thank you so much for this great tool collection - I've missed so much !!
                                          (it works great!)
                                          never trust a skinny cook
                                          • onzkiO
                                            onzki
                                            Funny It's been a year and I have to reply to my own post LOL.. Anyway, for those with similar question like mine here, I finally found where the missing icons are, Euerka! They're under the main menu "HELP->CADFATHER PACK->POWERBARICONS." It took me a year to discover by accident since I don't often scroll down the help menu path.
                                            These are truly amazing plugins, thanks a lot! 👍
                                            Screenshot
