    Power Toolbar (2.5) - fix for 2019
    78 Posts 39 Posters 132.5k Views 39 Watching
      Anton_S
      Hey man! That's a nice powerbar. By looking at the main file size, some 216KB, I can tell that so much work has been put into combining all these tools together. All the icons look amazing as well. Generally, I'm very impressed with your work and actually find your powerbar quite handy. Thank you 👍
      • pbacotP
        Thanks for the great work! Very cool. I'll try it on Mac.
        • O
          optimaforever
          1001 x thanks!
          Since I updated to 2015, I was VERY frustrated the PTB wasn't working anymore...
          Simple tools like extrudealongpath, pipealongpath, extrudelines, mirror, dropintersection, protrude were really essential in my workflow and crawling through the menus to find them was really a pain...
          My brain is already overcrowded with shortcut keys of photoshop, 3dsmax, aftereffects, sketchup, etc. that I feel very relieved when sometimes there are simply but brilliantly designed icons to click on 😄
          • P
            Pherim
            Very nice, thank you!
            Just a minor issue: On my Laptop I have the screen resolution 1366x768 (a little low for Sketchup, I know, but right now I don't have access to my desktop pc with the FullHD screen) and in the customization menu the two lowest lines are not visible. Any chance of a scrollbar or a more horizontal alignment of the icons (I think 15/15/14 would make sense)?
            • CadFatherC
              CadFather
              Bob, fairly sure you haven't really uninstalled it somehow. try it manually, there are only 2 files: _jhs01_powerbar.rb and the jhs folder. delete them and reinstall
              Anton, it was titanic (in the greek sense of the word). for the main part i didn't go out of the house for 8 solid days, or talk to anyone for that matter 😄 . in fact there's a big chunk of my own coding on this one, (by grace of all the pastas i was being nurtured with). 😄
              Pherim, check the fix on first post, should be good with 1366x768.
              Thanks all, good to hear you like it.
              • Bob JamesB
                Bob James
                Did that. Three times. Loaded it three ways: Importing rbz, opening the rbz with WinZip and extracting the files, and Plugin Store. Also, only used the standard plugin folder so no duplication in two locations.
                Must just be having a bad hair day
                • P
                  Pherim
                  It looks different for me... the first icon in the middle column is Comps to Grid Array and even when maximized, the lowest row of icons is only visible when I enable automatic taskbar hiding. Not a big issue, certainly, but a little annoying.
                  • CadFatherC
                    CadFather
                    Bob, are you sure you have no file or folder named jhs anywhere? never happened before.
                    Pherim, strange sounding - the new fix sets the window at 650 vertical, so that should not occur.
                    it should look like above image: first icon on second column being 'center to red'.
                      it's nice max!
                      now get back to the guitar...
                      • CadFatherC
                        CadFather
                        ...don't tempt me, mate! 😆
                        • P
                          Pherim
                          Oh, alright, I didn't realize I had to re-install it... It was not marked as updated. After re-installing, it works, thank you!
                          • doppelD
                            doppel
                            Thank you for this fantastic job! I will try it right now!
                            • CadFatherC
                              CadFather
                              told of a bug in the menus - fix coming soon.
                              • ntxdaveN
                                ntxdave
                                Does installing the toolbar also install all of the related plugins?
                                Press F1...thank me later
                                • B
                                  bsfranza
                                  awesome collection and coding 😃 great - hope you keep having fun with maintaining and expanding this
                                  • KrisidiousK
                                    Krisidious
                                    I missed it... Glorious.
                                    By: Kristoff Rand
                                    • onzkiO
                                      onzki
                                      Hi, Thanks for sharing this amazing plugins, I installed it via Sketchucation Store (Autoinstall)but how come mine seems lacking? Do I need to uninstall old plugins first? Please see attached screenshot. Thanks!
                                      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                                      • P
                                        pipinek
                                        Greetings,
                                        Is the current version 2.3 compatible with SU 2016?
                                        Many thanks
                                          Sam3D
                                          Por favor nao consigo instalar, aparece erro! Já fiz todo o processo, meu windows 8!
                                          Me ajude!!!!!
                                          Error Loading File C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb
                                          Error: No such file or directory - C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_pb.strings
                                          C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:19:in readlines' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:19:in module:Max_Coppoletta'
                                          C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:6:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
                                          C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:16:in register_extension'
                                          C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:16:in <module:JHS_powerbar>' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:8:in module:Max_Coppoletta'
                                          C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:7:in `<top (required)>'
                                          • deaneauD
                                            deaneau
                                            pictures tell more than 1000 words 😉
                                            • 1 / 4
