    Power Toolbar (2.5) - fix for 2019
    78 Posts 39 Posters 126.7k Views 39 Watching
      Pherim
      Very nice, thank you!
      Just a minor issue: On my Laptop I have the screen resolution 1366x768 (a little low for Sketchup, I know, but right now I don't have access to my desktop pc with the FullHD screen) and in the customization menu the two lowest lines are not visible. Any chance of a scrollbar or a more horizontal alignment of the icons (I think 15/15/14 would make sense)?
      • CadFatherC Offline
        CadFather
        Bob, fairly sure you haven't really uninstalled it somehow. try it manually, there are only 2 files: _jhs01_powerbar.rb and the jhs folder. delete them and reinstall
        Anton, it was titanic (in the greek sense of the word). for the main part i didn't go out of the house for 8 solid days, or talk to anyone for that matter 😄 . in fact there's a big chunk of my own coding on this one, (by grace of all the pastas i was being nurtured with). 😄
        Pherim, check the fix on first post, should be good with 1366x768.
        Thanks all, good to hear you like it.
        • Bob JamesB Offline
          Bob James
          Did that. Three times. Loaded it three ways: Importing rbz, opening the rbz with WinZip and extracting the files, and Plugin Store. Also, only used the standard plugin folder so no duplication in two locations.
          Must just be having a bad hair day
            Pherim
            It looks different for me... the first icon in the middle column is Comps to Grid Array and even when maximized, the lowest row of icons is only visible when I enable automatic taskbar hiding. Not a big issue, certainly, but a little annoying.
              CadFather
              Bob, are you sure you have no file or folder named jhs anywhere? never happened before.
              Pherim, strange sounding - the new fix sets the window at 650 vertical, so that should not occur.
              it should look like above image: first icon on second column being 'center to red'.
                it's nice max!
                now get back to the guitar...
                  CadFather
                  ...don't tempt me, mate! 😆
                    Pherim
                    Oh, alright, I didn't realize I had to re-install it... It was not marked as updated. After re-installing, it works, thank you!
                    • doppelD Offline
                      doppel
                      Thank you for this fantastic job! I will try it right now!
                        CadFather
                        told of a bug in the menus - fix coming soon.
                        • ntxdaveN Offline
                          ntxdave
                          Does installing the toolbar also install all of the related plugins?
                          Press F1...thank me later
                            bsfranza
                            awesome collection and coding 😃 great - hope you keep having fun with maintaining and expanding this
                            • KrisidiousK Offline
                              Krisidious
                              I missed it... Glorious.
                              By: Kristoff Rand
                              • onzkiO Offline
                                onzki
                                Hi, Thanks for sharing this amazing plugins, I installed it via Sketchucation Store (Autoinstall)but how come mine seems lacking? Do I need to uninstall old plugins first? Please see attached screenshot. Thanks!
                                [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                                  pipinek
                                  Greetings,
                                  Is the current version 2.3 compatible with SU 2016?
                                  Many thanks
                                    Sam3D
                                    Por favor nao consigo instalar, aparece erro! Já fiz todo o processo, meu windows 8!
                                    Me ajude!!!!!
                                    Error Loading File C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb
                                    Error: No such file or directory - C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_pb.strings
                                    C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:19:in readlines' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:19:in module:Max_Coppoletta'
                                    C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:6:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
                                    C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:16:in register_extension'
                                    C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:16:in <module:JHS_powerbar>' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:8:in module:Max_Coppoletta'
                                    C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/_jhs01_powerbar.rb:7:in `<top (required)>'
                                    • deaneauD Offline
                                      deaneau
                                      pictures tell more than 1000 words 😉
                                      • HornOxxH Offline
                                        HornOxx
                                        Thank you so much for this great tool collection - I've missed so much !!
                                        (it works great!)
                                        never trust a skinny cook
                                        • onzkiO Offline
                                          onzki
                                          Funny It's been a year and I have to reply to my own post LOL.. Anyway, for those with similar question like mine here, I finally found where the missing icons are, Euerka! They're under the main menu "HELP->CADFATHER PACK->POWERBARICONS." It took me a year to discover by accident since I don't often scroll down the help menu path.
                                          These are truly amazing plugins, thanks a lot! 👍
                                          Screenshot
                                            ktsbanam
                                            Extrude tool fails in sketchup 2017
                                            It does not create surface
                                            please fix it
                                            thank
                                            • 1 / 4
