    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.8k Views 122 Watching
    • micioneM
      micione
      Ok Fredo,
      mail sent .
      • F
        fantoosh420
        I have also tried with SU2015 X64 on win7 X64 sp1. i used freedo tools 2.2a (with libfreedo 6.2a, i think). it was (and is) working just fine on my home PC. have to check with this new release of 2.4a.
        Sketchup 14.0.4900
        Core i5 760 @ 3.00 Ghz. 8 GB RAM windows 7 SP1 X64
        • micioneM
          micione
          Problem solved.
          (today re-downloaded and installed).
          Works wonders.
          thanks
          • OxerO
            Oxer
            New Spanish Language file v2.4a
            Spanish Language File
            • fredo6F
              Oxer,
              Thanks very much. This will go in next update
                mcjoiner
                Unsure if the following issue is me (likely), or related to FredoTools or LibFredo.
                When using actively using thrupaint the tool works great. As soon as I double-click out, the changes are not visible. If I re-activate the tool, the previous changes are visible again.
                I'm currently using sketchup pro 8.
                Suggestions?
                • fredo6F
                  It is probably related to the style for displaying Edges.
                  To see the colors you need to set up the style by material in your model
                  • fredo6F
                    NEW RELEASE: FredoTools v2.5a - 10 Jan 15
                    FredoTools 2.5a is a release for ElementStats v1.0, which is a small tool to display statistiscs about entities in the model in an interactive way.
                    [flash=640,480:sirs851j]http://www.youtube.com/v/46IcCUqVf0c&hl[/flash:sirs851j]
                    Note: it requires to install LibFredo6 v6.6a
                    • cottyC
                      cotty
                      Thank you for another great addition to your toolbox!
                      my SketchUp gallery
                      • JClementsJ
                        JClements
                        Another home run.
                        Great for serious modelers and newbies alike. Super great for SU training instructors and plugin demonstrations.
                        • OxerO
                          Oxer
                          Thanks for this new update!! πŸ‘
                          Spanish Language Fredo Tools v2.5a
                          FredoTools_ES.lang.zip
                          • fredo6F
                            NEW RELEASE: FredoTools v2.5b - 18 Jan 15
                            FredoTools 2.5b is a small update fixing a few bugs in release v2.5a which was for ElementStats.
                            Note: version 2.5 (a and b) requires to install LibFredo6 v6.6
                            • fredo6F
                              NEW RELEASE: FredoTools v2.5c - 19 Jan 15
                              FredoTools 2.5c fixes a major bug for SU8 (and SU6, SU7) preventing ElementStats from working properly.
                              Note: version 2.5 (a, b and c) requires to install LibFredo6 v6.6
                                schnydix
                                Hello Fredo Thank you for the great work
                                All Other Translations following soon.
                                Roland F. Swiss
                                Translatet by Hand very carefully
                                Please Do not put my name into the plugins There is only space for the Author (Your name)
                                Save any Space for drawing.
                                FredoTools 2.5a
                                LibFredo6_DE.zip
                                SUClock_DE.zip
                                RoundCorner_DE.zip
                                HoverSelect_DE.zip
                                FredoTools_DE.zip
                                JointPushPull_DE.zip
                                ToolsOnSurface_DE.zip
                                • K
                                  KrisM
                                  Feeling kind of dumb here but I can't see how to select both the front and back faces of an object while using ThruPaint. Most useful tool by the way.
                                  KrisM
                                  • massimoM
                                    massimo Moderator
                                    If you mean painting both front and back faces at once then
                                    • K
                                      KrisM
                                      Okay, fixed. The options bar wasn't showing up because it was behind a floating toolbar.
                                      KrisM
                                      • fredo6F
                                        NEW RELEASE: FredoTools v2.6a - 25 Feb 15
                                        FredoTools 2.6a is a release for
                                        • FredoTools::AutoReverseFaces, which automatically align the orientation of faces in pseudo-solids
                                        • FredoTools::Convexify, which performs the Convex decomposition of 3D shapes
                                        Note: it requires to install LibFredo6 v6.7a
                                        • H
                                          hajasulthan
                                          hi how to fix the problem with thrupaint. its says more than 4 edges.
                                            It would be helpful if you could give some useful information about your model. Perhaps you could post an example that shows the problem. Or at least some screen shots.
                                            • 11
                                            • 12
                                            • 23
                                            • 24
                                            • 10 / 24
