    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 798.1k Views 121 Watching
    • fredo6F Offline
      @micione,
      Could you open the Trace Log file (in Windows > LibFredo6 Settings...) and check if FredoTools was loaded (or export as txt and send it to me).
      • micioneM Offline
        micione
        Ok Fredo,
        mail sent .
        • F Offline
          fantoosh420
          I have also tried with SU2015 X64 on win7 X64 sp1. i used freedo tools 2.2a (with libfreedo 6.2a, i think). it was (and is) working just fine on my home PC. have to check with this new release of 2.4a.
          Sketchup 14.0.4900
          Core i5 760 @ 3.00 Ghz. 8 GB RAM windows 7 SP1 X64
          • micioneM Offline
            micione
            Problem solved.
            (today re-downloaded and installed).
            Works wonders.
            thanks
            • OxerO Offline
              Oxer
              New Spanish Language file v2.4a
              Spanish Language File
              • fredo6F Offline
                Oxer,
                Thanks very much. This will go in next update
                  mcjoiner
                  Unsure if the following issue is me (likely), or related to FredoTools or LibFredo.
                  When using actively using thrupaint the tool works great. As soon as I double-click out, the changes are not visible. If I re-activate the tool, the previous changes are visible again.
                  I'm currently using sketchup pro 8.
                  Suggestions?
                  • fredo6F Offline
                    It is probably related to the style for displaying Edges.
                    To see the colors you need to set up the style by material in your model
                    • fredo6F Offline
                      NEW RELEASE: FredoTools v2.5a - 10 Jan 15
                      FredoTools 2.5a is a release for ElementStats v1.0, which is a small tool to display statistiscs about entities in the model in an interactive way.
                      [flash=640,480:sirs851j]http://www.youtube.com/v/46IcCUqVf0c&hl[/flash:sirs851j]
                      Note: it requires to install LibFredo6 v6.6a
                      • cottyC Offline
                        cotty
                        Thank you for another great addition to your toolbox!
                        my SketchUp gallery
                        • JClementsJ Offline
                          JClements
                          Another home run.
                          Great for serious modelers and newbies alike. Super great for SU training instructors and plugin demonstrations.
                          • OxerO Offline
                            Oxer
                            Thanks for this new update!! πŸ‘
                            Spanish Language Fredo Tools v2.5a
                            FredoTools_ES.lang.zip
                            • fredo6F Offline
                              NEW RELEASE: FredoTools v2.5b - 18 Jan 15
                              FredoTools 2.5b is a small update fixing a few bugs in release v2.5a which was for ElementStats.
                              Note: version 2.5 (a and b) requires to install LibFredo6 v6.6
                              • fredo6F Offline
                                NEW RELEASE: FredoTools v2.5c - 19 Jan 15
                                FredoTools 2.5c fixes a major bug for SU8 (and SU6, SU7) preventing ElementStats from working properly.
                                Note: version 2.5 (a, b and c) requires to install LibFredo6 v6.6
                                  schnydix
                                  Hello Fredo Thank you for the great work
                                  All Other Translations following soon.
                                  Roland F. Swiss
                                  Translatet by Hand very carefully
                                  Please Do not put my name into the plugins There is only space for the Author (Your name)
                                  Save any Space for drawing.
                                  FredoTools 2.5a
                                  LibFredo6_DE.zip
                                  SUClock_DE.zip
                                  RoundCorner_DE.zip
                                  HoverSelect_DE.zip
                                  FredoTools_DE.zip
                                  JointPushPull_DE.zip
                                  ToolsOnSurface_DE.zip
                                    KrisM
                                    Feeling kind of dumb here but I can't see how to select both the front and back faces of an object while using ThruPaint. Most useful tool by the way.
                                    KrisM
                                    • massimoM Offline
                                      massimo Moderator
                                      If you mean painting both front and back faces at once then
                                        KrisM
                                        Okay, fixed. The options bar wasn't showing up because it was behind a floating toolbar.
                                        KrisM
                                        • fredo6F Offline
                                          NEW RELEASE: FredoTools v2.6a - 25 Feb 15
                                          FredoTools 2.6a is a release for
                                          • FredoTools::AutoReverseFaces, which automatically align the orientation of faces in pseudo-solids
                                          • FredoTools::Convexify, which performs the Convex decomposition of 3D shapes
                                          Note: it requires to install LibFredo6 v6.7a
                                          • H Offline
                                            hajasulthan
                                            hi how to fix the problem with thrupaint. its says more than 4 edges.
                                            • 11
                                            • 12
                                            • 23
                                            • 24
                                            • 10 / 24
