    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 673.1k Views 121 Watching
    • F Offline
      fantoosh420
      I have also tried with SU2015 X64 on win7 X64 sp1. i used freedo tools 2.2a (with libfreedo 6.2a, i think). it was (and is) working just fine on my home PC. have to check with this new release of 2.4a.
      Sketchup 14.0.4900
      Core i5 760 @ 3.00 Ghz. 8 GB RAM windows 7 SP1 X64
      • micioneM Offline
        micione
        Problem solved.
        (today re-downloaded and installed).
        Works wonders.
        thanks
        • OxerO Offline
          Oxer
          New Spanish Language file v2.4a
          Spanish Language File
          • fredo6F Offline
            Oxer,
            Thanks very much. This will go in next update
              mcjoiner
              Unsure if the following issue is me (likely), or related to FredoTools or LibFredo.
              When using actively using thrupaint the tool works great. As soon as I double-click out, the changes are not visible. If I re-activate the tool, the previous changes are visible again.
              I'm currently using sketchup pro 8.
              Suggestions?
              • fredo6F Offline
                It is probably related to the style for displaying Edges.
                To see the colors you need to set up the style by material in your model
                • fredo6F Offline
                  NEW RELEASE: FredoTools v2.5a - 10 Jan 15
                  FredoTools 2.5a is a release for ElementStats v1.0, which is a small tool to display statistiscs about entities in the model in an interactive way.
                  [flash=640,480:sirs851j]http://www.youtube.com/v/46IcCUqVf0c&hl[/flash:sirs851j]
                  Note: it requires to install LibFredo6 v6.6a
                  • cottyC Offline
                    cotty
                    Thank you for another great addition to your toolbox!
                    my SketchUp gallery
                    • JClementsJ Offline
                      JClements
                      Another home run.
                      Great for serious modelers and newbies alike. Super great for SU training instructors and plugin demonstrations.
                      • OxerO Offline
                        Oxer
                        Thanks for this new update!! 👍
                        Spanish Language Fredo Tools v2.5a
                        FredoTools_ES.lang.zip
                        • fredo6F Offline
                          NEW RELEASE: FredoTools v2.5b - 18 Jan 15
                          FredoTools 2.5b is a small update fixing a few bugs in release v2.5a which was for ElementStats.
                          Note: version 2.5 (a and b) requires to install LibFredo6 v6.6
                          • fredo6F Offline
                            NEW RELEASE: FredoTools v2.5c - 19 Jan 15
                            FredoTools 2.5c fixes a major bug for SU8 (and SU6, SU7) preventing ElementStats from working properly.
                            Note: version 2.5 (a, b and c) requires to install LibFredo6 v6.6
                              schnydix
                              Hello Fredo Thank you for the great work
                              All Other Translations following soon.
                              Roland F. Swiss
                              Translatet by Hand very carefully
                              Please Do not put my name into the plugins There is only space for the Author (Your name)
                              Save any Space for drawing.
                              FredoTools 2.5a
                              LibFredo6_DE.zip
                              SUClock_DE.zip
                              RoundCorner_DE.zip
                              HoverSelect_DE.zip
                              FredoTools_DE.zip
                              JointPushPull_DE.zip
                              ToolsOnSurface_DE.zip
                                KrisM
                                Feeling kind of dumb here but I can't see how to select both the front and back faces of an object while using ThruPaint. Most useful tool by the way.
                                KrisM
                                • massimoM Offline
                                  massimo Moderator
                                  If you mean painting both front and back faces at once then
                                    KrisM
                                    Okay, fixed. The options bar wasn't showing up because it was behind a floating toolbar.
                                    KrisM
                                    • fredo6F Offline
                                      NEW RELEASE: FredoTools v2.6a - 25 Feb 15
                                      FredoTools 2.6a is a release for
                                      • FredoTools::AutoReverseFaces, which automatically align the orientation of faces in pseudo-solids
                                      • FredoTools::Convexify, which performs the Convex decomposition of 3D shapes
                                      Note: it requires to install LibFredo6 v6.7a
                                      • H Offline
                                        hajasulthan
                                        hi how to fix the problem with thrupaint. its says more than 4 edges.
                                          It would be helpful if you could give some useful information about your model. Perhaps you could post an example that shows the problem. Or at least some screen shots.
                                          • massimoM Offline
                                            massimo Moderator
                                            Most probably you've tried to apply a texture on surfaces which have more than 4 edges using the "Quadmesh UV" method. Try again by choosing a different method.
                                            • 11
                                            • 23
                                            • 24
                                            • 9 / 24
