    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 311.4k Views 89 Watching
      Didier has agreed to allow me to update some of his Plugins that are in in the PluginStore.
      I have already done of few of the easier ones... πŸ˜•
      I'll try and have a look at this one sometime this year !
        I have now updated 'Compo Spray' for Didier - it is now v2014/2015 compatible, and also works from any custom Plugins folder.
        Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=compoSpray
        If you have messed on installing it in Tools etc please remove it manually and get/install the latest version...
        • OxerO Offline
          Oxer
          Thanks TIG, tested in SU2014 & SU2015 on Mac OSX 10.9.5 and the plugin works fine. πŸ‘
            Pherim
            Thanks for the update!
            • CadFatherC Offline
              CadFather
              Didier, they're coming in faster than i can download them!
              Thanks! πŸ‘ πŸ˜„
              • V Offline
                valerostudio
                Same here in Win7 64 bit - I hit the button and nothing.
                  Your message is at odds with the ones following the update πŸ˜•
                  Works fine for me in Win7 64bit !
                  You do have the latest version installed from the PluginStore?
                  You have restarted SketchUp ?
                  AND you have removed any earlier versions of the tool before this ?
                  Are there any error messages in the Ruby Console ?
                  When you say you 'hit the button', do you mean the toolbar's button or the dialog's button ?
                  More feedback please...
                  • BoxB Offline
                    Make sure you have a surface to spray on.
                    • soloS Offline
                      same here and I do have a plane to spray on.
                      • BoxB Offline
                        As tig already said, Which Button? Do you get the settings dialog? or does it not even work from the point of clicking the menu?
                          What button exactly ?
                          Also any Ruby Console errors ?
                          Have you definitely removed all of the legacy stuff before installing it ?
                          Some of you were installing the older version into the Tools folder, and all manner of foolishness !
                          The updated version clearly working for many of us in v2015, so we need to find what you troublemakers are doing differently πŸ˜•
                          • soloS Offline
                            Error; #<NoMethodError; undefined method `dec' for 0.0;Length>
                            c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;10;in `initialize'
                            c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `new'
                            c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `compoSpray_main'
                            C;/Users/Pete/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/compoSprayToolbar.rb;19;in `block in <top (required)>'
                            SketchUp;1;in `call'
                              @Solo
                              Now I see... β˜€
                              Didier's code [ill advisedly] messes with 'Float'.
                              I suspect it adds 'dec' as a method.
                              In v2015 'Length' is somewhat divorced from 'Float', so his method 'dec' is probably orphaned with some Units set ups !
                              I look at a fix and update when I can...
                                I think that this updated version will now work in v2015 with all units settings...
                                http://sketchucation.com/pluginstore?pln=compoSpray Please try it, and report back...
                                • chonC Offline
                                  chon
                                  Many thanks TIG ! πŸ‘
                                  Works fine for me with AdditionalPluginFolders !!
                                  • soloS Offline
                                    πŸ‘
                                    Thanks Tig, working now.
                                    • V Offline
                                      valerostudio
                                      Yes, working. Made sure to delete any old versions and working now in 2015 x64 Win7. HUGE THANKS!!!!
                                      • V Offline
                                        valerostudio
                                        When you get the warning box that it will take X minutes to complete and you click NO the box doesn't go away and the plugin will not close.
                                          Didier's code is Byzantine in its complexity !
                                          I suspect it's because he used 'break' in the earlier version that itself broke in Ruby2.
                                          I replaced it with 'return', but that does nothing !
                                          Maybe the earlier 'break' effectively stopped the tool ?
                                          I'll look through and see if I can adjust things...
                                            Here's an updated version in the PluginStore http://sketchucation.com/pluginstore?pln=compoSpray
                                            Now if you are about to add thousands of components and the warning dialog asks if you want to proceed and you answer NO, then the tool quits and the dialog closes.
                                            Answer YES and it continues...
                                            • 13
                                            • 14
                                            • 6 / 14
