    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 340.7k Views 89 Watching
    • chonC Offline
      chon
      Not for me in France ! 😞
      Still not working with my config...
      • V Offline
        valerostudio
        Broken again in 2015!!!
        • soloS Offline
          Confirmed
            Didier has agreed to allow me to update some of his Plugins that are in in the PluginStore.
            I have already done of few of the easier ones... πŸ˜•
            I'll try and have a look at this one sometime this year !
              I have now updated 'Compo Spray' for Didier - it is now v2014/2015 compatible, and also works from any custom Plugins folder.
              Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=compoSpray
              If you have messed on installing it in Tools etc please remove it manually and get/install the latest version...
              • OxerO Offline
                Oxer
                Thanks TIG, tested in SU2014 & SU2015 on Mac OSX 10.9.5 and the plugin works fine. πŸ‘
                  Pherim
                  Thanks for the update!
                  • CadFatherC Offline
                    CadFather
                    Didier, they're coming in faster than i can download them!
                    Thanks! πŸ‘ πŸ˜„
                    • V Offline
                      valerostudio
                      Same here in Win7 64 bit - I hit the button and nothing.
                        Your message is at odds with the ones following the update πŸ˜•
                        Works fine for me in Win7 64bit !
                        You do have the latest version installed from the PluginStore?
                        You have restarted SketchUp ?
                        AND you have removed any earlier versions of the tool before this ?
                        Are there any error messages in the Ruby Console ?
                        When you say you 'hit the button', do you mean the toolbar's button or the dialog's button ?
                        More feedback please...
                        • BoxB Offline
                          Make sure you have a surface to spray on.
                          • soloS Offline
                            same here and I do have a plane to spray on.
                            • BoxB Offline
                              As tig already said, Which Button? Do you get the settings dialog? or does it not even work from the point of clicking the menu?
                                What button exactly ?
                                Also any Ruby Console errors ?
                                Have you definitely removed all of the legacy stuff before installing it ?
                                Some of you were installing the older version into the Tools folder, and all manner of foolishness !
                                The updated version clearly working for many of us in v2015, so we need to find what you troublemakers are doing differently πŸ˜•
                                • soloS Offline
                                  Error; #<NoMethodError; undefined method `dec' for 0.0;Length>
                                  c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;10;in `initialize'
                                  c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `new'
                                  c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `compoSpray_main'
                                  C;/Users/Pete/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/compoSprayToolbar.rb;19;in `block in <top (required)>'
                                  SketchUp;1;in `call'
                                    @Solo
                                    Now I see... β˜€
                                    Didier's code [ill advisedly] messes with 'Float'.
                                    I suspect it adds 'dec' as a method.
                                    In v2015 'Length' is somewhat divorced from 'Float', so his method 'dec' is probably orphaned with some Units set ups !
                                    I look at a fix and update when I can...
                                      I think that this updated version will now work in v2015 with all units settings...
                                      http://sketchucation.com/pluginstore?pln=compoSpray Please try it, and report back...
                                      • chonC Offline
                                        chon
                                        Many thanks TIG ! πŸ‘
                                        Works fine for me with AdditionalPluginFolders !!
                                        • soloS Offline
                                          πŸ‘
                                          Thanks Tig, working now.
                                          • V Offline
                                            valerostudio
                                            Yes, working. Made sure to delete any old versions and working now in 2015 x64 Win7. HUGE THANKS!!!!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 12 / 14
