    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 336.6k Views 89 Watching
    • soloS Offline
      @valerostudio said:
      Broken again in 2015!!!
      Confirmed
        Didier has agreed to allow me to update some of his Plugins that are in in the PluginStore.
        I have already done of few of the easier ones... πŸ˜•
        I'll try and have a look at this one sometime this year !
          I have now updated 'Compo Spray' for Didier - it is now v2014/2015 compatible, and also works from any custom Plugins folder.
          Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=compoSpray
          If you have messed on installing it in Tools etc please remove it manually and get/install the latest version...
          • OxerO Offline
            Oxer
            Thanks TIG, tested in SU2014 & SU2015 on Mac OSX 10.9.5 and the plugin works fine. πŸ‘
              Pherim
              Thanks for the update!
              • CadFatherC Offline
                CadFather
                Didier, they're coming in faster than i can download them!
                Thanks! πŸ‘ πŸ˜„
                • V Offline
                  valerostudio
                  Same here in Win7 64 bit - I hit the button and nothing.
                    Your message is at odds with the ones following the update πŸ˜•
                    Works fine for me in Win7 64bit !
                    You do have the latest version installed from the PluginStore?
                    You have restarted SketchUp ?
                    AND you have removed any earlier versions of the tool before this ?
                    Are there any error messages in the Ruby Console ?
                    When you say you 'hit the button', do you mean the toolbar's button or the dialog's button ?
                    More feedback please...
                    • BoxB Offline
                      Make sure you have a surface to spray on.
                      • soloS Offline
                        same here and I do have a plane to spray on.
                        • BoxB Offline
                          As tig already said, Which Button? Do you get the settings dialog? or does it not even work from the point of clicking the menu?
                            What button exactly ?
                            Also any Ruby Console errors ?
                            Have you definitely removed all of the legacy stuff before installing it ?
                            Some of you were installing the older version into the Tools folder, and all manner of foolishness !
                            The updated version clearly working for many of us in v2015, so we need to find what you troublemakers are doing differently πŸ˜•
                            • soloS Offline
                              Error; #<NoMethodError; undefined method `dec' for 0.0;Length>
                              c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;10;in `initialize'
                              c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `new'
                              c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `compoSpray_main'
                              C;/Users/Pete/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/compoSprayToolbar.rb;19;in `block in <top (required)>'
                              SketchUp;1;in `call'
                                @Solo
                                Now I see... β˜€
                                Didier's code [ill advisedly] messes with 'Float'.
                                I suspect it adds 'dec' as a method.
                                In v2015 'Length' is somewhat divorced from 'Float', so his method 'dec' is probably orphaned with some Units set ups !
                                I look at a fix and update when I can...
                                  I think that this updated version will now work in v2015 with all units settings...
                                  http://sketchucation.com/pluginstore?pln=compoSpray Please try it, and report back...
                                  • chonC Offline
                                    chon
                                    Many thanks TIG ! πŸ‘
                                    Works fine for me with AdditionalPluginFolders !!
                                    • soloS Offline
                                      πŸ‘
                                      Thanks Tig, working now.
                                      • V Offline
                                        valerostudio
                                        Yes, working. Made sure to delete any old versions and working now in 2015 x64 Win7. HUGE THANKS!!!!
                                        • V Offline
                                          valerostudio
                                          When you get the warning box that it will take X minutes to complete and you click NO the box doesn't go away and the plugin will not close.
                                            Didier's code is Byzantine in its complexity !
                                            I suspect it's because he used 'break' in the earlier version that itself broke in Ruby2.
                                            I replaced it with 'return', but that does nothing !
                                            Maybe the earlier 'break' effectively stopped the tool ?
                                            I'll look through and see if I can adjust things...
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 12 / 14
