    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 379.6k Views 89 Watching
    • P
      Pherim
      Thanks for the update!
      • CadFatherC
        CadFather
        Didier, they're coming in faster than i can download them!
        Thanks! πŸ‘ πŸ˜„
        • V
          valerostudio
          Same here in Win7 64 bit - I hit the button and nothing.
            Your message is at odds with the ones following the update πŸ˜•
            Works fine for me in Win7 64bit !
            You do have the latest version installed from the PluginStore?
            You have restarted SketchUp ?
            AND you have removed any earlier versions of the tool before this ?
            Are there any error messages in the Ruby Console ?
            When you say you 'hit the button', do you mean the toolbar's button or the dialog's button ?
            More feedback please...
            • BoxB
              Make sure you have a surface to spray on.
              • soloS
                same here and I do have a plane to spray on.
                • BoxB
                  As tig already said, Which Button? Do you get the settings dialog? or does it not even work from the point of clicking the menu?
                    What button exactly ?
                    Also any Ruby Console errors ?
                    Have you definitely removed all of the legacy stuff before installing it ?
                    Some of you were installing the older version into the Tools folder, and all manner of foolishness !
                    The updated version clearly working for many of us in v2015, so we need to find what you troublemakers are doing differently πŸ˜•
                    • soloS
                      Error; #<NoMethodError; undefined method `dec' for 0.0;Length>
                      c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;10;in `initialize'
                      c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `new'
                      c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `compoSpray_main'
                      C;/Users/Pete/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/compoSprayToolbar.rb;19;in `block in <top (required)>'
                      SketchUp;1;in `call'
                        @Solo
                        Now I see... β˜€
                        Didier's code [ill advisedly] messes with 'Float'.
                        I suspect it adds 'dec' as a method.
                        In v2015 'Length' is somewhat divorced from 'Float', so his method 'dec' is probably orphaned with some Units set ups !
                        I look at a fix and update when I can...
                          I think that this updated version will now work in v2015 with all units settings...
                          http://sketchucation.com/pluginstore?pln=compoSpray Please try it, and report back...
                          • chonC
                            chon
                            Many thanks TIG ! πŸ‘
                            Works fine for me with AdditionalPluginFolders !!
                            SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
                            • soloS
                              πŸ‘
                              Thanks Tig, working now.
                              • V
                                valerostudio
                                Yes, working. Made sure to delete any old versions and working now in 2015 x64 Win7. HUGE THANKS!!!!
                                • V
                                  valerostudio
                                  When you get the warning box that it will take X minutes to complete and you click NO the box doesn't go away and the plugin will not close.
                                    Didier's code is Byzantine in its complexity !
                                    I suspect it's because he used 'break' in the earlier version that itself broke in Ruby2.
                                    I replaced it with 'return', but that does nothing !
                                    Maybe the earlier 'break' effectively stopped the tool ?
                                    I'll look through and see if I can adjust things...
                                      Here's an updated version in the PluginStore http://sketchucation.com/pluginstore?pln=compoSpray
                                      Now if you are about to add thousands of components and the warning dialog asks if you want to proceed and you answer NO, then the tool quits and the dialog closes.
                                      Answer YES and it continues...
                                      • CadFatherC
                                        CadFather
                                        now it is perfect. thank you TIG πŸ‘
                                        • V
                                          valerostudio
                                          Actually I just got a Bugsplat when it tried to close. 😒
                                            Please outline your steps.
                                            e.g. what was open, or what was the last thing you did when you closed and splatted ?
