    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 336.6k Views 89 Watching
    • BoxB Offline
      It does work on 2013 and 2014 with some tweaks.
      Make sure you have the properties set to what you need and remember it needs a surface to spray on.
      As for the developer being MIA, Didier has never said he supports this free plugin in perpetuity.
      • chonC Offline
        chon
        Hello,
        no match for me with CS modified and given by Oxer few posts above. I've tried to install the plugin in "C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools" (even then we should'nt use this folder as explained by TIG) and in "C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins" but no success.
        Cherry on the cake, i would like to install this plugin in an additional plugin folder using the Fredo6 tool (doesn't work in this folder neither of course).
        Any one to help me ?
        Thanks a lot !! πŸ˜‰
        • nghminh81N Offline
          nghminh81
          Thanks so much Oxer and MTriple. Your file works perfectly with my sketchup 2014!
          To anyone who using Windows and still can't install it: Please extract files(ComposprayToolbar.rb and 1 folder Compospray) to "C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools".
          DON'T EXTRACT FILES TO "C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins"
          AND IF THEY WERE THERE (Because you tried to install it) Just DELETE.
          • V Offline
            valerostudio
            Agreed. This works in 2014! Thanks!!!
            • faBcnF Offline
              faBcn
              Hi there,
              I do not see any window when clicking on Draw / Compo spray (SU 2013)...
              Any idea ?
              Thanx
              • faBcnF Offline
                faBcn
                How I manage to make it work on SU 2013, here in Spain (with bloody accents everywhere...)
                1- Copy/Paste CompoSpray folder + .rb in Plugins file as usual
                2- Remove all .lingvo but CompoSprayUS.lingvo
                and it works perfectly ! Nada mΓ‘s....
                • chonC Offline
                  chon
                  Not for me in France ! 😞
                  Still not working with my config...
                  • V Offline
                    valerostudio
                    Broken again in 2015!!!
                    • soloS Offline
                      Confirmed
                        Didier has agreed to allow me to update some of his Plugins that are in in the PluginStore.
                        I have already done of few of the easier ones... πŸ˜•
                        I'll try and have a look at this one sometime this year !
                          I have now updated 'Compo Spray' for Didier - it is now v2014/2015 compatible, and also works from any custom Plugins folder.
                          Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=compoSpray
                          If you have messed on installing it in Tools etc please remove it manually and get/install the latest version...
                          • OxerO Offline
                            Oxer
                            Thanks TIG, tested in SU2014 & SU2015 on Mac OSX 10.9.5 and the plugin works fine. πŸ‘
                              Pherim
                              Thanks for the update!
                              • CadFatherC Offline
                                CadFather
                                Didier, they're coming in faster than i can download them!
                                Thanks! πŸ‘ πŸ˜„
                                • V Offline
                                  valerostudio
                                  Same here in Win7 64 bit - I hit the button and nothing.
                                    Your message is at odds with the ones following the update πŸ˜•
                                    Works fine for me in Win7 64bit !
                                    You do have the latest version installed from the PluginStore?
                                    You have restarted SketchUp ?
                                    AND you have removed any earlier versions of the tool before this ?
                                    Are there any error messages in the Ruby Console ?
                                    When you say you 'hit the button', do you mean the toolbar's button or the dialog's button ?
                                    More feedback please...
                                    • BoxB Offline
                                      Make sure you have a surface to spray on.
                                      • soloS Offline
                                        same here and I do have a plane to spray on.
                                        • BoxB Offline
                                          As tig already said, Which Button? Do you get the settings dialog? or does it not even work from the point of clicking the menu?
                                            What button exactly ?
                                            Also any Ruby Console errors ?
                                            Have you definitely removed all of the legacy stuff before installing it ?
                                            Some of you were installing the older version into the Tools folder, and all manner of foolishness !
                                            The updated version clearly working for many of us in v2015, so we need to find what you troublemakers are doing differently πŸ˜•
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
