    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 336.6k Views 89 Watching
    • BoxB Offline
      As tig already said, Which Button? Do you get the settings dialog? or does it not even work from the point of clicking the menu?
        @solo said:
        @valerostudio said:
        Same here in Win7 64 bit - I hit the button and nothing.
        same here and I do have a plane to spray on.
        What button exactly ?
        Also any Ruby Console errors ?
        Have you definitely removed all of the legacy stuff before installing it ?
        Some of you were installing the older version into the Tools folder, and all manner of foolishness !
        The updated version clearly working for many of us in v2015, so we need to find what you troublemakers are doing differently πŸ˜•
        • soloS Offline
          Error; #<NoMethodError; undefined method `dec' for 0.0;Length>
          c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;10;in `initialize'
          c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `new'
          c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `compoSpray_main'
          C;/Users/Pete/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/compoSprayToolbar.rb;19;in `block in <top (required)>'
          SketchUp;1;in `call'
            @Solo
            Now I see... β˜€
            Didier's code [ill advisedly] messes with 'Float'.
            I suspect it adds 'dec' as a method.
            In v2015 'Length' is somewhat divorced from 'Float', so his method 'dec' is probably orphaned with some Units set ups !
            I look at a fix and update when I can...
              I think that this updated version will now work in v2015 with all units settings...
              http://sketchucation.com/pluginstore?pln=compoSpray Please try it, and report back...
              • chonC Offline
                chon
                Many thanks TIG ! πŸ‘
                Works fine for me with AdditionalPluginFolders !!
                • soloS Offline
                  πŸ‘
                  Thanks Tig, working now.
                  • V Offline
                    valerostudio
                    Yes, working. Made sure to delete any old versions and working now in 2015 x64 Win7. HUGE THANKS!!!!
                    • V Offline
                      valerostudio
                      When you get the warning box that it will take X minutes to complete and you click NO the box doesn't go away and the plugin will not close.
                        Didier's code is Byzantine in its complexity !
                        I suspect it's because he used 'break' in the earlier version that itself broke in Ruby2.
                        I replaced it with 'return', but that does nothing !
                        Maybe the earlier 'break' effectively stopped the tool ?
                        I'll look through and see if I can adjust things...
                          Here's an updated version in the PluginStore http://sketchucation.com/pluginstore?pln=compoSpray
                          Now if you are about to add thousands of components and the warning dialog asks if you want to proceed and you answer NO, then the tool quits and the dialog closes.
                          Answer YES and it continues...
                          • CadFatherC Offline
                            CadFather
                            now it is perfect. thank you TIG πŸ‘
                            • V Offline
                              valerostudio
                              Actually I just got a Bugsplat when it tried to close. 😒
                                Please outline your steps.
                                e.g. what was open, or what was the last thing you did when you closed and splatted ?
                                • chonC Offline
                                  chon
                                  TIG,
                                  with your last version, i've got the same problem as Shape Bender, it works fine when i put the CompoSpray plugin in the C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins folder, but it doesn't work when i put it my Fredo6's AdditionalPluginFolder. 😳
                                  I've got that : When you get the warning box that it will take X minutes to complete and you click NO the box doesn't go away and the plugin will not close.
                                  Any suggestion ? πŸ˜•
                                    @chon said:
                                    TIG,
                                    I deliberately removed the limitations of using when loading from a non-default Plugins folder - I have it working from a custom-folder on my PC, so it works - and so something is adrift with your set up...
                                    Do you have the very latest version from the PluginStore ?
                                    I also did a fix to stop when you say so...
                                    That leads me to suspect you haven't installed the latest version in your custom-folder ?
                                    How are you installing it ?
                                    The SketchUcation submenu > Archive Installer... will install an RBZ in a custom-folder...
                                    • chonC Offline
                                      chon
                                      Thanks for response TIG !
                                      I wrote my feedback too quickly : In the "official" SU2015 plugins folder, i still get the "X minutes to complete" message but i can say NO and in the AdditionalPluginFolder, i can't say NO.
                                      Unfortunately, that not solves the "X minutes to complete" problem itself. Even then the plugin is in the official plugins folder, i've got 2 simple components and i try to spray them on a single short line and still have this message and no process.
                                      For the installation, i've got your last compoSpray_v1.4.2xxx version and as all other plugins, i extract file and folder from the RBZ archive and paste them manually in my AdditionalPluginFolder.
                                      • I Offline
                                        imranbangash
                                        Can anyone help me? i get this error message in sketchup 2013
                                        Error Loading File compoSprayToolbar.rb
                                        undefined method `compSpray_env' for main:Object
                                          Do you have the full error message ?
                                          How have you installed this RBZ ?
                                          If you have the latest v8[>=M2] or newer then Preferences > Extensions > Install button will install the RBZ contents properly.
                                          Manually installing from an RBZ suffixed .zip and manually moving files/folders into Plugins is a recipe for disaster.
                                          The 'loader' .rb and its subfolder[s] of all of its helper files etc needs to be kept intact...
                                          Can we see you Plugins folder contents and the tool's subfolder's too ?
                                            rhinoferoce
                                            Hello, I have the exact same error here, with SU2013 Pro.
                                            Used to work but broke up after update through Sketchucation Plugin Store plugin.
                                            I tried to uninstall and reinstall the last version through the extension installer in preferences, but it still doesn't work.
                                            "Error Loading File compoSprayToolbar.rb
                                            undefined method `compSpray_env' for main:Object" is the only message I get when launching sketchup. Then no toolbar...
                                            If anyone have an idea...
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 12 / 14
