    [Plugin] Groups to Components
    50 Posts 20 Posters 51.8k Views 20 Watching
      That is a good question. I got X-Frog trees myself - have it on my todo list somewhere to find a way to optimize them.
        Maybe my component dropper plugin will work for this...?
          autarchos
          thanks for the tip, thomthom. i see solo proposed the idea in your component dropper thread. i am experimenting with it on a few trees. it actually makes the workflow quite a bit faster and easier, but does not keep geometry in the exact original orientation.
          thus, i'm creating components of each leaf (painfully slow), using component dropper to make them all the same (instantaneous, even for thousands of leaves), and then using chris fullmer's scale and rotate multiple to give them a little bit of randomness. i'll show you a tree with some stats when finished - it's slow, but i think will yield a more natural chaotic result than the original trees - xfrog tends to be too fractal and perfect in my opinion.
          a note however, your 'groups to components' works almost instantly, whereas the same function with matts plugin took several minutes. perhaps at some point this script could be updated to work on non-group entities as matts does, but with more efficiency.
          • P
            publied
            very interesting Thom,
            now i'm trying it!
            hire me@ http://www.publied.it !
            • halroachH
              halroach
              Sometimes when I'm using this plugin it only converts one selected group to one component leaving all the rest as groups. Not sure what's causing that. ideas?
              FlexTools - Super Quick Windows, Doors, Slats...
              • halroachH
                halroach
                @halroach said:
                I copied and pasted all the groups to another sketchup model (outside of the one component they were in, and they were all converted. could it be this plugin doesn't work within a component?
                • tt_suT
                  tt_su
                  Do you have a sample scenario/model where I can reproduce this?
                  • irwanwrI
                    irwanwr
                    I thought there's already Group to Components function in Selection Toys, isn't it?
                      It's somewhat different. Selection Toys got a function to convert group copies to component instance while ensuring each instance isn't made unique.
                      This small extension had a special purpose for preserving naming in a special way by request of some user.
                      • B
                        bsfranza
                        hi there,
                        could it be that its not yet updated for su 2014???
                        its not showing in any menue 😞
                          @bsfranza said:
                          hi there,
                          No. It works fine n SketchUp 2014. How did you install it? If installed correctly, it will appear in the Plugins menu.
                          • K
                            koliboti
                            Hi, do you guys have plugin that makes components to groups, that work wit SU2015?
                              I assume you mean to make component-instances into groups ?
                              This one liner processed a selection. Making any component-instances into groups, using the same name/layer/material/attributes as the original...
                              m=Sketchup.active_model;a=m.active_entities;s=m.selection;m.start_operation('!');s.grep(Sketchup;;ComponentInstance).each{|i|g=a.add_group();e=g.entities;n=e.add_instance(i.definition, i.transformation);n.explode;g.name=i.definition.name;g.layer=i.layer;g.material=i.material;i.attribute_dictionaries.each{|d|d.each_pair{|k,v|g.add_attribute(d.name,k,v)}}if i.attribute_dictionaries;i.erase!;};m.commit_operation
                              • K
                                koliboti
                                Thank you very-very much TIG! it works perfect also with imported 3ds objects. 🎉
                                • C
                                  camilo_caicedo
                                  Hi thomthom.
                                  Your conversion tool changes all groups in the selection to components, one component for each group where the group's name is transferred to the component's definition's name.
                                  Please, do you know about some plugin which changes all groups in the selection to a single component (the groups should be a copy of a single group), so you obtain one component for each group, where the component definition name of each component is the same?
                                  People often forget to make a component instead of a group, so if you repeat a group, and then you rotate or move that group to diferent places many times, it would be hard to make a component and then repeat it, rotate or move it many times again. A tool to convert those groups to one component would allow you to go on with your job.
                                  Thank's
                                    If the group haven't been modified (or even opened) then Selection Toys can convert such groups to components. But if the user has performed any kind of action that makes SU kick in the make-unique then it won't be able to detect that.
                                    You can force replace with Component Replacer, but you need to pick out which ones to replace with what.
                                      rv1974
                                      Thomthom, may I request this tool to keep the object(s) selected after conversion?
                                      • Y
                                        YCL furniture
                                        Hello, Thom
                                        maybe have any plugin to convert components to groups? without losing the component name
                                          @ycl furniture said:
                                          Hello, Thom
                                          Why convert components to groups?
                                          • Y
                                            YCL furniture
                                            Hello, Thom
                                            Because I design furniture with components. After designing the furniture, I use the ABF solutions plugin to make report list of furniture panels cutting and edges bandings. This plugin only works with groups.
                                            Maybe you know of another plugin that make report list of furniture panels and edges banding?
                                            I made a video where I showed what features I need (https://www.youtube.com/watch?v=85djT5KbnZw)
                                            • 2 / 3
