    [Plugin] Groups to Components
    50 Posts 20 Posters 49.8k Views 20 Watching
    • tt_suT Offline
      tt_su
      Do you have a sample scenario/model where I can reproduce this?
      • irwanwrI Offline
        irwanwr
        I thought there's already Group to Components function in Selection Toys, isn't it?
          It's somewhat different. Selection Toys got a function to convert group copies to component instance while ensuring each instance isn't made unique.
          This small extension had a special purpose for preserving naming in a special way by request of some user.
            bsfranza
            hi there,
            could it be that its not yet updated for su 2014???
            its not showing in any menue 😞
              @bsfranza said:
              hi there,
              No. It works fine n SketchUp 2014. How did you install it? If installed correctly, it will appear in the Plugins menu.
                koliboti
                Hi, do you guys have plugin that makes components to groups, that work wit SU2015?
                • TIGT Online
                  I assume you mean to make component-instances into groups ?
                  This one liner processed a selection. Making any component-instances into groups, using the same name/layer/material/attributes as the original...
                  m=Sketchup.active_model;a=m.active_entities;s=m.selection;m.start_operation('!');s.grep(Sketchup;;ComponentInstance).each{|i|g=a.add_group();e=g.entities;n=e.add_instance(i.definition, i.transformation);n.explode;g.name=i.definition.name;g.layer=i.layer;g.material=i.material;i.attribute_dictionaries.each{|d|d.each_pair{|k,v|g.add_attribute(d.name,k,v)}}if i.attribute_dictionaries;i.erase!;};m.commit_operation
                    koliboti
                    Thank you very-very much TIG! it works perfect also with imported 3ds objects. πŸŽ‰
                      camilo_caicedo
                      Hi thomthom.
                      Your conversion tool changes all groups in the selection to components, one component for each group where the group's name is transferred to the component's definition's name.
                      Please, do you know about some plugin which changes all groups in the selection to a single component (the groups should be a copy of a single group), so you obtain one component for each group, where the component definition name of each component is the same?
                      People often forget to make a component instead of a group, so if you repeat a group, and then you rotate or move that group to diferent places many times, it would be hard to make a component and then repeat it, rotate or move it many times again. A tool to convert those groups to one component would allow you to go on with your job.
                      Thank's
                        If the group haven't been modified (or even opened) then Selection Toys can convert such groups to components. But if the user has performed any kind of action that makes SU kick in the make-unique then it won't be able to detect that.
                        You can force replace with Component Replacer, but you need to pick out which ones to replace with what.
                          rv1974
                          Thomthom, may I request this tool to keep the object(s) selected after conversion?
                          • Y Offline
                            YCL furniture
                            Hello, Thom
                            maybe have any plugin to convert components to groups? without losing the component name
                              @ycl furniture said:
                              Hello, Thom
                              Why convert components to groups?
                              • Y Offline
                                YCL furniture
                                Hello, Thom
                                Because I design furniture with components. After designing the furniture, I use the ABF solutions plugin to make report list of furniture panels cutting and edges bandings. This plugin only works with groups.
                                Maybe you know of another plugin that make report list of furniture panels and edges banding?
                                I made a video where I showed what features I need (https://www.youtube.com/watch?v=85djT5KbnZw)
                                  You are using SketchUp 2016 Make for your business?
                                  There are numerous cutlist extensions that work with components.
                                  • Y Offline
                                    YCL furniture
                                    There are many extensions that calculate report list of furniture panels cuttings. But none of them count the edges banding
                                    • F Offline
                                      fortyonethirty
                                      Thanks! πŸ‘
                                        Dennis_n
                                        I was looking to convert groups into components and found this plugin. It is supposed to show up in a plugin tab. However, there is no Plugin tab anymore.
                                        How to access the function on SU 2023?
                                        (my use case is exporting parts of the SU model for Lumion phasing animation. For this every part has to be saved separately. There is a plugin that does export every component. however, the groups will not export. So I was looking for ways to convert the groups to components, so I can export it all into Lumion)
                                        Thank you.
                                          I assume you mean Plugins menu. That was replaced with Extensions some time ago.
                                          I just installed this extension in SketchUp 2023. It shows up in the Extensions menu as it should and works just fine.
                                          • TIGT Online
                                            Dave R beat me to the post !
                                            The menu tab 'Plugins' was renamed 'Extensions' looong ago...
                                            Did you look there ?
                                            • 2 / 3
