    [Plugin] Groups to Components
    50 Posts 20 Posters 52.7k Views 20 Watching
      mac1
      I use it very often to convert single groups to components especially in models where some one has used a number of identical groups. Then you can use the component browser function of replace selected to replace all these converted groups with one component. Caution there is a quirk with the program. You also have to include in your selection a line also. http://forums.sketchucation.com/viewtopic.php?f=323&t=28395
        mac1
        @thomthom said:
        Might be partly duplicate functions - but a key feature in this script was the naming: the definition inherited the group's name, not the instance.
        Does SketchUp still consider them copies of each other? If you select one and open Entity Info - does it say "Group (3 in model)" ?
        If so, Selection Toys can convert them into components in one operation.
        Don't remember but you can take say 50 groups and then convert them to a single component or individual components (50) If my memory is correct it did use the same name for the component as the group number but what I don't like is how it moves around in the outliner and in a large model you have to then search to find the ones converted to replace as noted above
          mac1
          Here is a good test case for you if you want to go crazy. http://www.google.com/support/forum/p/sketchup/thread?tid=0a9b7b20ecc8e1bf&hl=en The model uses a number of identical groups and those should be reduced to a single definition
            I did not see any model to download... where about in the thread is it?
              mac1
              https://docs.google.com/leaf?id=0B37CGPyQd3oiMWE1NDJlMWEtYTdmMC00MzYwLWIzMzMtYTAwMGE3NjM2NTRh&hl=en_GB
                DIEGO-RODRIGUEZ
                thom hello.
                thanks for the new plugins.
                a question:
                what is the difference with the "Group copies> Convert Into components" of your plugins SELECTION TOY 2.0.
                  @diego-rodriguez said:
                  thom hello.
                  a question:
                  This one converts each group instance into a component instance. (plus it transfers the name to the definition)
                  Selection Toys will convert all instances of a group into instances of one component definition.
                  • CadFatherC
                    CadFather
                    Matts plugin is still buggy, he has been very busy and not able to update many of his scripts - on the other hand Fredo's scale tools include a group to component command, so Thom you don't really need the extra effort for this plugin - but perhaps a CTRL toggle between the wider context and not could be handy... 💚
                      mac1
                      Ref Matt's tool is Buggy but I can work around by just including a line I draw in my selection and has worked Ok for me that way
                      • JClementsJ
                        JClements
                        Thank you, Thomas!
                        Might I suggest this plugin could stand as it isand another be created to deal with the issues mentioned above where there are identical instances of a group and rename this plugin"Groups to UniqueComponents" or something similar to describe what it does ... a quick and dirty conversion.
                          autarchos
                          i'm looking for a method to simplify an xfrog tree using perhaps this plugin, or matt's, but i'm running into problems with the component axes.
                          the idea is:
                          1. make each leaf (1.5"x1" rectangles) into a component.
                          2. in the component window, i replace the selected unique leaf components with a single leaf component.
                          the glitch comes with the fact that each leaf is tilted to a different angle, but component creation scripts seem to set the axes identical to that of the world axes (see pics below). thus when i replace the selected components with one single component they all end up angled to the exact same direction. so is there a way that i can do this and maintain the orientation of each individual component? ie. can an option be included in this script to set all component axes exactly the same relative to each 'unique' component?
                          good if axes of each leaf is the same, maybe here:
                          bad if axes of each leaf component is different relative to comp.:
                          thanks!
                            That is a good question. I got X-Frog trees myself - have it on my todo list somewhere to find a way to optimize them.
                              Maybe my component dropper plugin will work for this...?
                                autarchos
                                thanks for the tip, thomthom. i see solo proposed the idea in your component dropper thread. i am experimenting with it on a few trees. it actually makes the workflow quite a bit faster and easier, but does not keep geometry in the exact original orientation.
                                thus, i'm creating components of each leaf (painfully slow), using component dropper to make them all the same (instantaneous, even for thousands of leaves), and then using chris fullmer's scale and rotate multiple to give them a little bit of randomness. i'll show you a tree with some stats when finished - it's slow, but i think will yield a more natural chaotic result than the original trees - xfrog tends to be too fractal and perfect in my opinion.
                                a note however, your 'groups to components' works almost instantly, whereas the same function with matts plugin took several minutes. perhaps at some point this script could be updated to work on non-group entities as matts does, but with more efficiency.
                                • P
                                  publied
                                  very interesting Thom,
                                  now i'm trying it!
                                  hire me@ http://www.publied.it !
                                  • halroachH
                                    halroach
                                    Sometimes when I'm using this plugin it only converts one selected group to one component leaving all the rest as groups. Not sure what's causing that. ideas?
                                    FlexTools - Super Quick Windows, Doors, Slats...
                                    • halroachH
                                      halroach
                                      @halroach said:
                                      I copied and pasted all the groups to another sketchup model (outside of the one component they were in, and they were all converted. could it be this plugin doesn't work within a component?
                                      • tt_suT
                                        tt_su
                                        Do you have a sample scenario/model where I can reproduce this?
                                        • irwanwrI
                                          irwanwr
                                          I thought there's already Group to Components function in Selection Toys, isn't it?
                                            It's somewhat different. Selection Toys got a function to convert group copies to component instance while ensuring each instance isn't made unique.
                                            This small extension had a special purpose for preserving naming in a special way by request of some user.
                                            • 2 / 3
