    [Plugin] SketchUV - now free
    176 Posts 62 Posters 142.5k Views 62 Watching
      Got a donation link Dale? This plugin well deserves donations!
      • romboutR Offline
        rombout
        I got a lot of erros when i export a model to blender and than back. Most of the times i get errors on faces which cant be mapped. The model is kind of a mess, triangles and quads together. Do i need to fix all of this first?
        • Rich O BrienR Online
          Have no quads on export.
          Blenders obj exporter doesn't place nice with SketchUV.
          There's the ability to import blender quads as obj with QuadFace Tools.
          • romboutR Offline
            rombout
            That seems like a dirty solution. There's a quad texture in this plugin than why cant it handle quads correct, making it triangles makes unnecessary big. Isnt there a other solution
              Do some tests on exporting obj from blender.
              You'll see that non planar quad faces are subdivided and not triangulated.
              So whilst these plugins support the QuadFace convention it doesn't work both ways unless you force it.
              The other solution which is faster is to stay entirely in Blender.
              • ToboboT Offline
                Tobobo
                Ok so I have had a read through the thread and it doesn't seem like anyone is dumb enough to try what I want to do... 😳
                I want to create a Icosahedron (triangular sided) globe. So I choose the spherical mapping and the UV maps appear to be ok but when I put the globe texture on the poles aren't quite right.
                Is it because there aren't enough faces to map to? Would sub dividing help? or is it too low poly?
                Here are the screen shots and skippy.
                Thanks in advance
                Icosahedron.skp
                Toby
                Philippians 4:13
                  That look about right to me.
                  Tri's and poles are hard for any mapping method.
                  • ToboboT Offline
                    Tobobo
                    I'm not so fussed about Antarctica but Greenland isn't quite all there.
                    Toby
                    Philippians 4:13
                      this might be better....
                      ....but it'll pinch at poles...
                      • ToboboT Offline
                        Tobobo
                        That does look better Rich, as always with this sort of thing the client wants it to be triangular faces. πŸ˜’
                        Toby
                        Philippians 4:13
                          You can have tris but that shape is hard to resolve
                          • ToboboT Offline
                            Tobobo
                            Ok thanks Rich πŸ˜„ , I will try and sort it
                            Toby
                            Philippians 4:13
                            • FrederikF Offline
                              Frederik
                              Not sure if you can use this, but that paper globe model is available for free at model+model... πŸ˜‰
                              I downloaded the OBJ and imported it to SketchUp and got this result...
                              Cheers
                              Kim Frederik
                                A hipoly lo poly version.
                                • FrederikF Offline
                                  Frederik
                                  It even looks great when rendered... πŸ˜„
                                  Cheers
                                  Kim Frederik
                                  • FrederikF Offline
                                    Frederik
                                    My pleasure... πŸ˜„
                                    Cheers
                                    Kim Frederik
                                      jamenloh
                                      Hey man, thanks for the plugin ! It solves so many problems we are facing ! I just downloaded it to try , am facing an issue with your plug in.
                                      I've followed the tutorial by clicking the surface , the iconbar , align the angles and select the context menu planar surface - but it doesn't apply the UV map ... it just applis my last texture.
                                      Have tried it many times to no avail.
                                      Any idea what happened ?
                                      • ToboboT Offline
                                        Tobobo
                                        That's great πŸ˜„
                                        Thanks mate!
                                        Toby
                                        Philippians 4:13
                                        • Z Offline
                                          Zacchia
                                          Many thanks for this nice plugin!!
                                          • romboutR Offline
                                            rombout
                                            I got a question. Ive read somewhere when import a obj mesh which gets triangulated at normal size (for me metric) better use a smaller import size. Im using meter in blender and than import it as inch into SU, cm still gives triangles and mm cuts holes.
                                            what scale do i need to use to set it back to meter. Im searching google but im not sure what keywords i need to use. Im non english person so bit harder for correct translation.
                                            Doing my own tests i came around 39.35% when i use the scale tool in SU, im still a bit off. Anyone here who knows the exact scale method
                                            • 9 / 9
