    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
    • fredo6F Offline
      @robertwan said:
      Thank you for the correction.
      If it could also be chosen on which line T-bones is formed. Right now it's only on a longer one.
      Robert
      This is not possible with the current GUI. The only thing you can do is to place intermediate points to control the respective lengths of segments at corner.
      Also, I publish a small upgrade (1.6d) to make sure T-bones appears when one of the segment has the required minimum length.
      • fredo6F Offline
        NEW RELEASE 1.6d - 04 Mar 14
        This release fixes a few bugs and problem in the TBone curves, as highlighted by Robert Wan.
        Remember also that v1.6 is necessary for SU14 and also fixes some crashes encountered on some Mac OSX configuration and SU13.
        Download latest release of BezierSpline from main post
        Or the PluginStore http://sketchucation.com/pluginstore?pln=BezierSpline
          ly871108
          I have translated it into CHINESE,perfectly.I tried my best to be with it.THANK YOU!
          Here is the CHINESE version of 1.6D:
          CHINESE Version!Enjoy it! 1.6D
            pizixie
            πŸ‘
              dedmin
              See the video.
              Video_2014-03-28_200608.wmv
                matthew.robert
                Is there any way to convert multiple welded lines (contours for example) to segmented lines with set segment lengths? I have used Bezier Spline in the past to get better "From Contour" results by converting contour lines one at a time to lines made with consistent segment lengths. This works considerably better than the "simplify contours" plugin that still creates snow drifts all over the place.
                EDIT, kinda related... here is a video I created showing how to use the Polyfit LISP (from polyface.de) in Autocad to ultimately get a more efficient model to do a From Contour in SketchUp.
                http://youtu.be/6bQtJhDn_lc?t=3m40s
                (Easier to see in HD directly on Youtube, also jump to the 3:40 mark to see the polyfit part.)
                I've done a similar thing using BezierSpline with the Polyline Divider option, but I need to weld and apply the tool to each contour line rather than all at once with the Polyfit LISP.
                -- matt
                  MarinerSketch
                  Awesome plugin.
                  Is there any option or method to make a spline's ends to be tangent to a straight line?
                  • robertWanR Offline
                    robertWan
                    http://www.screencast.com/t/B1BJ3k1V
                    Robert
                    • SkeeterdS Offline
                      Skeeterd
                      Wonderful plugin! Is there a way to keep a tool persistent like in the tools on surface plugin?
                        tellkurt
                        How would I install the plugin for Sketchup 2014 ?
                        • fredo6F Offline
                          The strongly suggested method is that you first install the Sketchucation PluginStore tool, so that you can easily and safely install any plugin.
                          Then, you can auto-install Bezierspline and all other plugins in one click.
                            mamagroene
                            so, I just installed the plugin, but as soon as I try to use it with sketch up (my version is sketchup pro 2014, the toolbar that appears is just empty. I hope you understand my problem as I'm not a native english speaker. we tried pretty much everything to make it work, but we simply can't. I hope you can help!
                              How did you install it ?
                              Sounds like some files are missing...
                              Please reinstall it using the PluginStore's AutoInstall tool, OR if you have the RBZ, then use it with v2014's Preferences > Extensions > Install... button...
                              Also note that many of Fredo's tools need LibFredo - also install the latest version of that [also available at the PluginStore...].
                              Restart after the installing to ensure everything is synchronized...
                                antonio.calvo
                                Hello Fredo, thank you for your plugin. Is fantastic and works great. Any way of making it persistent to glue to surface/or group/or edge..? Maybe be with a key stroke? Thank you so much again.
                                • W Offline
                                  witjazz
                                  thanks
                                  • Y Offline
                                    yaseerr
                                    like it thank you
                                    • fredo6F Offline
                                      NEW RELEASE 1.7a - 19 Oct 2014
                                      This release is required for SU 2014 when your username contains non-ascii characters
                                      Note that non-ascii characters are not supported for SU13 and previous versions of Sketchup
                                      Download new release at main post
                                      • W Offline
                                        WebBeau
                                        Thanks a lot
                                        • E Offline
                                          Esense3d
                                          Hello Fredo
                                          I would like to translate this plugin on all German but can not find language files
                                          Bezier spline is only partially translated
                                          Fredo I now have this new address
                                          Roland F Swiss
                                          • fredo6F Offline
                                            @esense3d said:
                                            Hello Fredo
                                            Roland F Swiss
                                            Thanks for this proposal.
                                            BezierSpline is not compliant with LibFredo6. So, it is built differently. I will make a full refresh one of these days.
                                            Anyway, the current version already includes a German translation.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
