    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • fredo6F
      NEW RELEASE 1.6a - 11 Nov 2013
      This release is for future Sketchup compatibility
      Download new release at main post
      • fredo6F
        NEW RELEASE 1.6b - 12 Nov 2013
        It also fixes some crashes encountered on some Mac OSX configuration and SU13.. Thanks to Dave R for helping me troubleshoot the issue.
          Makolee
          THX FOR THIS PLUGIN
          • gonashviliG
            gonashvili
            Hi there
            So I'm using this a lot, umm is there a way to 'disable' the initial [Uniform B-Spline] dialog (with the Order parameter), so it would stay at the default '0' / automatic, or whatever value [without the dialog]?
            Cheers
            • mitcorbM
              mitcorb
              Hi.
              After reading gonashvili's post above, I opened Sketchup8 to test the spline. I placed an initial spline in an empty scene with 0 default setting. Then began to place another, but changed the parameter to 10 and OK. I got a bugsplat window. I captured the window and the response. Interestingly, I immediately repeated the process and got no error.
              Sorry, if the two images appear out of order. The splat window is first and the response window is supposed to be second.
              Also, apology to gonashvili for jumping in here. I was simply investigating.
                suHappyPills
                cool tools,Thx a lot.
                • robertWanR
                  robertWan
                  I type radius 10 mm, but have 14,1. (sqrt200 😒 )
                  Robert
                  • fredo6F
                    NEW RELEASE 1.6c - 03 Mar 14
                    This release is fixes a bug in the TBone curves, found by Robert Wan.
                    Remember also that v1.6 is necessary for SU14 and fixes some crashes encountered on some Mac OSX configuration and SU13.
                    Download latest release if BezierSpline at main post
                    • robertWanR
                      robertWan
                      Thank you for the correction.
                      If it could also be chosen on which line T-bones is formed. Right now it's only on a longer one.
                      Robert
                      • fredo6F
                        Robert
                        This is not possible with the current GUI. The only thing you can do is to place intermediate points to control the respective lengths of segments at corner.
                        Also, I publish a small upgrade (1.6d) to make sure T-bones appears when one of the segment has the required minimum length.
                        • fredo6F
                          NEW RELEASE 1.6d - 04 Mar 14
                          This release fixes a few bugs and problem in the TBone curves, as highlighted by Robert Wan.
                          Remember also that v1.6 is necessary for SU14 and also fixes some crashes encountered on some Mac OSX configuration and SU13.
                          Download latest release of BezierSpline from main post
                          Or the PluginStore http://sketchucation.com/pluginstore?pln=BezierSpline
                          • L
                            ly871108
                            I have translated it into CHINESE,perfectly.I tried my best to be with it.THANK YOU!
                            Here is the CHINESE version of 1.6D:
                            CHINESE Version!Enjoy it! 1.6D
                            • P
                              pizixie
                                dedmin
                                See the video.
                                Video_2014-03-28_200608.wmv
                                  matthew.robert
                                  Is there any way to convert multiple welded lines (contours for example) to segmented lines with set segment lengths? I have used Bezier Spline in the past to get better "From Contour" results by converting contour lines one at a time to lines made with consistent segment lengths. This works considerably better than the "simplify contours" plugin that still creates snow drifts all over the place.
                                  EDIT, kinda related... here is a video I created showing how to use the Polyfit LISP (from polyface.de) in Autocad to ultimately get a more efficient model to do a From Contour in SketchUp.
                                  http://youtu.be/6bQtJhDn_lc?t=3m40s
                                  (Easier to see in HD directly on Youtube, also jump to the 3:40 mark to see the polyfit part.)
                                  I've done a similar thing using BezierSpline with the Polyline Divider option, but I need to weld and apply the tool to each contour line rather than all at once with the Polyfit LISP.
                                  -- matt
                                    MarinerSketch
                                    Awesome plugin.
                                    Is there any option or method to make a spline's ends to be tangent to a straight line?
                                    • robertWanR
                                      robertWan
                                      (www.screencast.com)
                                      Robert
                                      • SkeeterdS
                                        Skeeterd
                                        Wonderful plugin! Is there a way to keep a tool persistent like in the tools on surface plugin?
                                        • T
                                          tellkurt
                                          How would I install the plugin for Sketchup 2014 ?
                                          • fredo6F
                                            The strongly suggested method is that you first install the Sketchucation PluginStore tool, so that you can easily and safely install any plugin.
                                            Then, you can auto-install Bezierspline and all other plugins in one click.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
