    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • fredo6F Offline
      NEW RELEASE 1.6c - 03 Mar 14
      This release is fixes a bug in the TBone curves, found by Robert Wan.
      Remember also that v1.6 is necessary for SU14 and fixes some crashes encountered on some Mac OSX configuration and SU13.
      Download latest release if BezierSpline at main post
      • robertWanR Offline
        robertWan
        Thank you for the correction.
        If it could also be chosen on which line T-bones is formed. Right now it's only on a longer one.
        Robert
        • fredo6F Offline
          Robert
          This is not possible with the current GUI. The only thing you can do is to place intermediate points to control the respective lengths of segments at corner.
          Also, I publish a small upgrade (1.6d) to make sure T-bones appears when one of the segment has the required minimum length.
          • fredo6F Offline
            NEW RELEASE 1.6d - 04 Mar 14
            This release fixes a few bugs and problem in the TBone curves, as highlighted by Robert Wan.
            Remember also that v1.6 is necessary for SU14 and also fixes some crashes encountered on some Mac OSX configuration and SU13.
            Download latest release of BezierSpline from main post
            Or the PluginStore http://sketchucation.com/pluginstore?pln=BezierSpline
              ly871108
              I have translated it into CHINESE,perfectly.I tried my best to be with it.THANK YOU!
              Here is the CHINESE version of 1.6D:
              CHINESE Version!Enjoy it! 1.6D
                pizixie
                πŸ‘
                  dedmin
                  See the video.
                  Video_2014-03-28_200608.wmv
                    matthew.robert
                    Is there any way to convert multiple welded lines (contours for example) to segmented lines with set segment lengths? I have used Bezier Spline in the past to get better "From Contour" results by converting contour lines one at a time to lines made with consistent segment lengths. This works considerably better than the "simplify contours" plugin that still creates snow drifts all over the place.
                    EDIT, kinda related... here is a video I created showing how to use the Polyfit LISP (from polyface.de) in Autocad to ultimately get a more efficient model to do a From Contour in SketchUp.
                    http://youtu.be/6bQtJhDn_lc?t=3m40s
                    (Easier to see in HD directly on Youtube, also jump to the 3:40 mark to see the polyfit part.)
                    I've done a similar thing using BezierSpline with the Polyline Divider option, but I need to weld and apply the tool to each contour line rather than all at once with the Polyfit LISP.
                    -- matt
                      MarinerSketch
                      Awesome plugin.
                      Is there any option or method to make a spline's ends to be tangent to a straight line?
                        robertWan
                        http://www.screencast.com/t/B1BJ3k1V
                        Robert
                        • SkeeterdS Offline
                          Skeeterd
                          Wonderful plugin! Is there a way to keep a tool persistent like in the tools on surface plugin?
                            tellkurt
                            How would I install the plugin for Sketchup 2014 ?
                            • fredo6F Offline
                              The strongly suggested method is that you first install the Sketchucation PluginStore tool, so that you can easily and safely install any plugin.
                              Then, you can auto-install Bezierspline and all other plugins in one click.
                                mamagroene
                                so, I just installed the plugin, but as soon as I try to use it with sketch up (my version is sketchup pro 2014, the toolbar that appears is just empty. I hope you understand my problem as I'm not a native english speaker. we tried pretty much everything to make it work, but we simply can't. I hope you can help!
                                  How did you install it ?
                                  Sounds like some files are missing...
                                  Please reinstall it using the PluginStore's AutoInstall tool, OR if you have the RBZ, then use it with v2014's Preferences > Extensions > Install... button...
                                  Also note that many of Fredo's tools need LibFredo - also install the latest version of that [also available at the PluginStore...].
                                  Restart after the installing to ensure everything is synchronized...
                                    antonio.calvo
                                    Hello Fredo, thank you for your plugin. Is fantastic and works great. Any way of making it persistent to glue to surface/or group/or edge..? Maybe be with a key stroke? Thank you so much again.
                                    • W Offline
                                      witjazz
                                      thanks
                                      • Y Offline
                                        yaseerr
                                        like it thank you
                                        • fredo6F Offline
                                          NEW RELEASE 1.7a - 19 Oct 2014
                                          This release is required for SU 2014 when your username contains non-ascii characters
                                          Note that non-ascii characters are not supported for SU13 and previous versions of Sketchup
                                          Download new release at main post
                                          • W Offline
                                            WebBeau
                                            Thanks a lot
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
