    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 482.6k Views 135 Watching
    • BoxB Offline
      It will take multiple individual groups that are copies and make them instances of one component.
      So if you have arrayed a group 100 times, it will select all those 100 and make them into 100 instances of one component, which then makes it possible to use the replace selected function of components.
      • cottyC Offline
        cotty
        A little one...
        If a circle or an arc is divided by lines, it is possible to change the segments within the entity info window for all parts separately...
        my SketchUp gallery
          Ouch. Face Palm here too!
          • plot-parisP Offline
            plot-paris
            @cotty said:
            If you select several instances of the same component and use "make unique", these instances become all instances of the new component.
            I just discovered this and headed over here to post it πŸ˜„
            After years and years of SketchUp use! πŸ‘Š
            • U Offline
              unearthed
              Doh using selection tools
              I often need to select faces inside of some line, usually a very complex line (the built area of a terrain, a river plain in a valley etc.). So I was just running thru the process to make a post to this group...
              Make surface, make lines soft, smooth and turn off then group [I hadn't done this bit before]
              Drape boundary on surface.
              Enter group, click on inner area and presto it's selected:
              SelectFacesInsideLine_works with edges off anyway_just click surface inside line.JPG
              I went round and round in a lot of circles to get that!
              Growplan - People ∩ Plants ∩ Place
              windows 7 64b, 4GB RAM, SU 8.0.16846
              Gimp, QGIS, Vectorworks 12, Bricscad 11
                Aarhus8000
                Just realized yesterday that you can push faces you can't see. I've always used 'Hide Rest of Model' a lot when pushing faces to be able to see the actual face I ment to push or used normal 'Hide' on all surrounding entities to get to the one I actually wanted to modify/push. Turns out the Push tool can "see through" blocking geometry which makes the entire workflow so much quicker. Nice one!
                • Kristian
                • cottyC Offline
                  cotty
                  I didn't know that you can get non-perpendicular axes 😲
                  my SketchUp gallery
                  • fredo6F Offline
                    Easy way to get it is to apply FredoScale::PlanarShearto a component.
                    Shear transformation is conform actually, but the inconvenience is that it deforms the axes. Issues can happen in some scripts because Vector transformation is not natural when axes are not orthogonal.
                      rv1974
                      If you export a lot of pictures out of skp get the 'Smustard Scene Exporter'- it will save years of sitting in front of monitor.
                        rv1974
                        you can easily reassign keyboard keys (on Windows level) with:
                        http://sharpkeys.codeplex.com/.
                        • falkF Offline
                          falk
                          @pmiller said:
                          Probably the best SU duh!:
                          404 Not Found
                          (www.sketchucation.com)
                          (Link to the "Homer" button, which plays the "d'oh!" sound and does an undo. Sadly, it's no longer there. I don't suppose anybody kept a copy?)
                          • falkF Offline
                            falk
                            My biggest D'oh! was learning to write plugins. I had no idea it would be that easy; why didn't I do it years ago?
                            • massimoM Offline
                              massimo Moderator
                              @falk said:
                              404 Not Found
                              You can find it at Jim's blog. Scroll down the page.
                              • xiombargX Offline
                                xiombarg
                                Discovering the Outliner. All combined I probably wasted a week of my life clicking my way through nested components to get to an object when all I had to do was click on a component's name in the Outliner.
                                • falkF Offline
                                  falk
                                  Thanks. And now that I've made it to the end of this thread (Best. Thread. Ever.), here's a tiny little plugin that I use all the time. It adds a "Show shortcuts" item to the Help menu. I find it very useful when I can't remember what I've assigned keys to. Especially when you're trying to assign a shortcut, and preferences tells you that key is already in use, and you can't remember what for.
                                  show_shortcuts.rb
                                    You should try Shortcutter plugin.
                                    It is bundled with SketchUcation Tools
                                    • TK0001T Offline
                                      TK0001
                                      About this time last year, I discovered clicking on the arrow buttons locks you into that axis when moving or copying objects. Now I use the arrows religiously.
                                        rv1974
                                        To migrate 2013 Shortcuts to 2015 one should open Preferences.dat in Notepad and use 'find and replace' feature to replace all 'Plugins' words with 'Extensions'.
                                        Important: there must be only one backspace between the shortcut descriotion and the 'Extensions' word.
                                        2015 Plugins folder location:
                                        C:\Users\Your_Username\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
                                        • oceanembersO Offline
                                          oceanembers
                                          shift to lock inferences/directions/etc. was one that I found way too late x_x
                                            Never seen that! 😳
                                            Draw a circle, Select the circumference : right Click / Divide ! 😲
                                            Works only one time! πŸ€“
                                            http://sketchucation.com/forums/download/file.php?id=126133
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 34
                                            • 35
                                            • 26 / 35
